| » Whirlpool Gas Oven will not heat up to desired temperature. |
Model Number: SF315PEGQ5 Brand: Whirlpool Age: More than 10 years
Hello,
I have a original builder model Whirlpool Oven that no longer reaches desired temperature. It takes an hour to reach 400 degrees and 45 minutes to reach 350. I already replaced the oven temperature sensor and it did not help. Any other suggestions? Thanks Captjob Ads By Google Related Models |
Igniter is week and can't always light the oven when it calls for heat.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum |
You already replaced the igniter once before?
To test the igniter I would use a clamp on amp meter and see if it's in range with what is marked on the side of the gas valve.
__________________
| Display Modes | |
| JennAir oven does not reach desired temperature | acooney | Oven Repair (including Ranges and Cooktops) | 6 | 12-27-2011 06:20 AM |
| Frigidaire oven surpasses desired temperature | Michael in Des Moines | Oven Repair (including Ranges and Cooktops) | 1 | 03-19-2011 05:49 AM |
| gas oven slow to heat up/achieve desired temperature | FPF | Oven Repair (including Ranges and Cooktops) | 5 | 01-02-2011 01:16 PM |
| Maytag oven not reaching desired temperature | mvalente | Oven Repair (including Ranges and Cooktops) | 0 | 12-28-2009 11:47 AM |
| Viking Oven burners shut off; can't reach desired temperature | MiMiStan | Oven Repair (including Ranges and Cooktops) | 2 | 04-28-2009 09:44 AM |
