#1 Posted : Saturday, September 19, 2009 3:01:33 AM(UTC)
Can find no specific info on this unit with the given info.
The temperature on my oven always runs much higher than I set the dial to.
Note that most ovens allow you to calibrate the over +/- 35 degrees
The temperature sensor is intact and in the correct place.
Sensor can look OK and still be no good. See below on how to check it.
http://www.applianceaid.com/elecrange.html
See #7
The oven door is not what you call tightly shut, would this cause the problem?
Doubtful but if it is causing the temp sensor to get a draft and see a cooler temp than the rest of the oven it theoretically could.
