| » Kenmore wall elec oven |
Model Number: 9114132990 Brand: Kenmore Age: More than 10 years
I have a Kenmore double oven, the lower unit works fine but the upper does not even come on in oven or broiler mode, error code F-2 just comes on and the oven never comes on. the Lower unit is operated by knobs, but the upper unit is operated by buttons and a control panel.
Hi.
The F2 code means the over temperature condition. Check the temp. sensor and wire harness to the control board. The sensor resistance at room temperature is around 1100 ohm. The sensor Part number: WB21X5301 Thank you. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
to: Simon
On my Kenmore oven, where do I find the temp. sensor? Will a malfunctioning oven temp. sensor keep the oven from coming on at all? Also, I can't find my Oven model number in your parts department Last edited by bethschuyler@sbcglobal.ne : 07-25-2012 at 04:10 PM. |
Hi.
Look inside the oven in the upper right or left corner to locate the sensor. The control board will not function if it detected bad sensor. Unfortunately we have only limited access to the Kenmore look ups (as everybody ells). Sorry for the inconvenience. Thank you. Simon.
__________________
| Display Modes | |
| won't heat elec wall oven | rmgordon77 | Oven Repair (including Ranges and Cooktops) | 11 | 09-02-2012 09:20 PM |
| GE P7 Elec. Wall Oven, Clean latch won't close | davidgpo | Oven Repair (including Ranges and Cooktops) | 0 | 09-27-2011 08:34 PM |
| Jenn-Air wall oven how to replace Cntl-elec | TheLoneGranger | Oven Repair (including Ranges and Cooktops) | 0 | 08-07-2009 09:00 PM |
| Magic chef dual elec. wall oven | jbduvall | Oven Repair (including Ranges and Cooktops) | 1 | 04-21-2009 11:52 AM |
| amana elec wall oven turns off | amana98 | Oven Repair (including Ranges and Cooktops) | 1 | 08-27-2008 06:19 PM |
