Discuss
Whirlpool range - oven burner does not ignite
 in
I have Whirlpool range, model GW395LEGQ1, with 'oven' problems. It's been working fine for years, suddenly without any previous peculiar
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool range - oven burner does not ignite
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 07-24-2012, 01:12 PM
Junior Member
beachnik is on a distinguished road
Default Whirlpool range - oven burner does not ignite
Model Number: GW395LEGQ1   Brand: Whirlpool   Age: More than 10 years
It's been working fine for years, suddenly without any previous peculiar behavior, the oven doesn't work. One day it worked, the next time it didn't work.
What should happen when using oven...
- Press the 'Bake' button
- LED control panel advises default temperature and says 'Bake'
- Press the 'Start' button - a half second later, you hear a electronic click from the area where the Control Panel is located (I presume it's opening a connection to the igniter - sending electricity to the igniter?)
- LED control panel advises that oven is going into Preheat Mode and starts Preheat countdown. Countdown is typically 10 minutes.
- After igniter heats up, you should just barely hear gas start to flow and oven burner ignites, preheat begins.
- After 10 minutes, preheat is completed, range sounds a tone to notify that oven is ready for use.
What is actually happening when attempting to use ovenů
- Press the 'Start' button - a half second later, you hear a electronic click from the area where the Control Panel is located.
- Igniter does not glow
- Gas does not flow
- Although control panel counts down through the preheat time cycle - and gives the audible notification at the end of the time cycle, oven does not preheat, oven burner never ignites.
Miscellaneous...
- This model has the oven and broiler built into the same cabinet space. The broiler continues to operate normally.
- Everything on the LED control panel seems to be operating normally.
- The control panel does not display any error codes.
- The burners operate normally.
- Although it's 13 years old, the oven gets used about 15 times a year. The broiler gets used about 20 times a year. The only thing that looks used is the burner grates! Being a 'slide in' range, I'd hate to have to replace this beast.
Appreciate your comments.
Tags:
Whirlpool range model: GW395LEGQ1
Oven Ignitor pn: 9753108
Oven valve regulator pn: 9752698
Related Models
Whirlpool GW395LEGQ1 GAS RANGE
Whirlpool GW395LEGQ2 GAS RANGE
Whirlpool GW395LEGQ3 GAS RANGE
Whirlpool GW395LEGQ4 GAS RANGE
Whirlpool GW395LEGQ5 GAS RANGE
Whirlpool GW395LEGQ6 GAS RANGE
Whirlpool GW395LEGT2 GAS RANGE
Whirlpool GW395LEGT3 GAS RANGE
Whirlpool GW395LEGT4 GAS RANGE
Whirlpool GW395LEGT5 GAS RANGE
Whirlpool GW395LEGT6 GAS RANGE
Whirlpool GW395LEGZ0 GAS RANGE
Whirlpool GW395LEGZ1 GAS RANGE
Whirlpool GW395LEGZ2 GAS RANGE
Whirlpool GW395LEGZ3 GAS RANGE
Whirlpool GW395LEPB00 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB01 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB02 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB03 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB04 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB05 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ00 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ01 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ02 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ03 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ04 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ05 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS00 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS01 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS02 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS03 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS04 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS05 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT00 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT01 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT02 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT03 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT04 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT05 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW397LXUB0 30" Gas Slide-In
Whirlpool GW397LXUB05 30" GAS SLIDE-IN
Whirlpool GW397LXUB06 30" GAS SLIDE-IN RANGE
Whirlpool GW397LXUB1 30" GAS SLIDE-IN
Whirlpool GW397LXUB5 30" GAS SLIDE-IN
Whirlpool GW397LXUQ0 30" Gas Slide-In
Whirlpool GW397LXUQ06 30" GAS SLIDE-IN
Whirlpool GW397LXUQ1 30" GAS SLIDE-IN
Whirlpool GW397LXUQ6 30" GAS SLIDE-IN
Whirlpool GW397LXUS0 30" Gas Slide-In
Whirlpool GW397LXUS05 30" GAS SLIDE-IN
Whirlpool GW397LXUS06 30" GAS SLIDE-IN RANGE
Whirlpool GW397LXUS1 30" GAS SLIDE-IN
Whirlpool GW397LXUS5 30" GAS SLIDE-IN
Whirlpool GW397LXUT0 30" Gas Slide-In
Whirlpool GW397LXUT05 30" GAS SLIDE-IN
Whirlpool GW397LXUT06 30" GAS SLIDE-IN
Whirlpool GW397LXUT1 30" GAS SLIDE-IN
Whirlpool GW397LXUT5 30" GAS SLIDE-IN
Whirlpool GW399LXUB0 30" Gas Slide-In
Whirlpool GW399LXUB05 30" GAS SLIDE-IN
Whirlpool GW399LXUB06 30" GAS SLIDE-IN RANGE
Whirlpool GW399LXUB1 30" Gas Slide-In
Whirlpool GW399LXUB5 30" Gas Slide-In
Whirlpool GW399LXUQ0 30" Gas Slide-In
Whirlpool GW399LXUQ06 30" GAS SLIDE-IN
Whirlpool GW399LXUQ1 30" Gas Slide-In
Whirlpool GW399LXUQ6 30" Gas Slide-In
Whirlpool GW399LXUS0 30" Gas Slide-In
Whirlpool GW399LXUS04 30" GAS SLIDE-IN
Whirlpool GW399LXUS05 30" GAS SLIDE-IN
Whirlpool GW399LXUS06 30" GAS SLIDE-IN RANGE
Whirlpool GW399LXUS1 30" Gas Slide-In
Whirlpool GW399LXUS4 30" GAS SLIDE-IN
General Electric GWE23LBTBFSS REFRIGERATOR T SERIES
General Electric GWE23LGTIFSS REFRIGERATOR T SERIES
General Electric GWE23LGTJFSS REFRIGERATOR T SERIES
General Electric GWE23LGYAFSS REFRIGERATOR Y SERIES
 GWHD6500R Air Conditioner
General Electric GWR03AAMABB Refrigerator
General Electric GWRE6270H0WW WASHER
General Electric GWRE6270H1WW WASHER
General Electric GWRE6270H2WW WASHER
General Electric GWRE6270K0WW WASHER
General Electric GWRE6270K2WW WASHER
General Electric GWRE6270K3WW WASHER
General Electric GWS03ADWASS REFRIGERATOR
Gibson GWS1149AS0 Washer - Gibson
Gibson GWS1149AS1 Washer - Gibson
Gibson GWS1339CS0 Gibson/washer
Gibson GWS1339CS1 Gibson/washer
Gibson GWS1749AS0 Washer - Gibson
Gibson GWS1749AS1 Washer - Gibson
Gibson GWS1749CS0 Gibson/washer
Frigidaire GWS223RFS0 Gib(v0) / Washer
Frigidaire GWS223RFS1 Gib(v0) / Washer
Frigidaire GWS223RHS0 Gib(v0) / Washer
Frigidaire GWS223RHS1 RESIDENTIAL WASHER
Frigidaire GWS445RFS0 Gib(v0) / Washer
Frigidaire GWS445RFS1 Gib(v1)
Frigidaire GWS445RFS2 Gib(v0) / Washer
Frigidaire GWS445RHS0 Gib(v0) / Washer
Gibson GWS445RHS1 Washer - Gibson
Frigidaire GWS645RBS0 Gib(v0) / 27 " Washer
Frigidaire GWS645RBS1 Gib(v0) / Washer
Frigidaire GWS645RBS2 Gib(v0) / Washer
Frigidaire GWS645RBS3 Gib(v0) / Washer
Frigidaire GWS645RBS4 Gib(v0) / Washer
Frigidaire GWS645RFS0 Gib(v0) / Washer
Frigidaire GWS645RFS1 Gib(v0) / Washer
Frigidaire GWS645RFS2 Gib(v0) / Washer
Frigidaire GWS645RHS0 Gib(v0) / Washer
Gibson GWS645RHS1 Washer - Gibson
Gibson GWS833CS0 Gibson/washer
General Electric GWSE5240H0WW Washer
General Electric GWSE5240H1WW WASHER
General Electric GWSE5240H2WW WASHER
General Electric GWSE5240H3WW WASHER
Gibson GWT1149AS0 Washer - Gibson
Gibson GWT1749AS0 Washer - Gibson
Frigidaire GWT445RFS0 Gib(v0) / Washer
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven Burner won't ignite Judy Niznak Oven Repair (including Ranges and Cooktops) 0 01-16-2010 09:11 AM
Whirlpool gas range oven will not ignite kamzuk Oven Repair (including Ranges and Cooktops) 1 01-03-2010 04:21 AM
Pilot on-oven burner does not ignite dougmax Oven Repair (including Ranges and Cooktops) 0 10-22-2009 10:14 AM
Whirlpool gas range/oven doesn't ignite consistently jgotko Oven Repair (including Ranges and Cooktops) 0 08-18-2009 05:11 PM
Oven burner will not ignite RonnieT Oven Repair (including Ranges and Cooktops) 1 07-23-2008 08:57 AM
