Discuss
Amana ACS3350AS - Heat escapes oven door & shuts control panel off
 in
Hello all. A friend of mine has an Amana ACS3350AS gas range. They are having issues with the control panel
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Amana ACS3350AS - Heat escapes oven door & shuts control panel off
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 07-24-2012, 06:03 AM
Junior Member
mjp3475 is on a distinguished road
Default Amana ACS3350AS - Heat escapes oven door & shuts control panel off
Model Number: ACS3350AS   Brand: Amana   Age: 5 - 10 years
Hello all. A friend of mine has an Amana ACS3350AS gas range. They are having issues with the control panel shutting off when operating the oven (as similarly documented by several people on the forums).
The way they get the oven to stay on during operation is to take an ice pack (one that you would use on a sprained ankle), wrap it in foil, and place it over the control panel. This leads me to believe that the panel is OK, but excess heat is causing it to shut off.
So the other day while they were cooking, I noticed that the oven door does not completely close tightly all the way into the cavity ... the hinges seem weak. With the door "closed," there is a lot of hot air escaping out the top of the cavity, but when I push and hold the door closed, there is no heat escaping anymore. Would this excess heat be tripping a limit switch in the way of this heat & shutting off the control panel?
I had been doing a bit of reading in this thread ( Amana ACS3350AS Shuts off when hot ) about limit switches, cooling, etc, but I'm wondering given the behavior I've seen so far with the oven door, if I'm better off replacing the hinges first before going to the switches/fan to fix the control panel issue (the hinges are probably easier to replace)?
Your thoughts?
Thanks in advance!
-MP
Related Models
Amana ACS3350AS RANGE- S/C S/I GAS
Amana ACS3350AW RANGE- S/C S/I GAS
Amana ACS4140BB RANGE- S/C S/I ELE
Amana ACS4140BW RANGE- S/C S/I ELE
Amana ACS4250AB RANGE- S/C S/I ELE
Amana ACS4250AC RANGE- S/C S/I ELE
Amana ACS4250AW RANGE- S/C S/I ELE
Amana ACS4660AB RANGE- S/C S/I DDRAFT ELE
Amana ACS4660AW RANGE- S/C S/I DDRAFT ELE
Whirlpool ACS50 FREESTANDING ICE MAKERS
Whirlpool ACS501
Whirlpool ACS502 ICE CUBE MAKER
Whirlpool ACS520XA1 AIR CONDITIONER
Whirlpool ACS602XM Air-conditioner/heat pump
Whirlpool ACS602XT0 Air-conditioner/heat pump
Amana ACS7270AB RANGE- S/C S/I ELE
Amana ACS7270AS RANGE- S/C S/I ELE
Amana ACS7270AW RANGE- S/C S/I ELE
Whirlpool ACS802XM Air-conditioner/heat pump
Whirlpool ACS802XT0 Air-conditioner/heat pump
Whirlpool ACS802XV0
Whirlpool ACS802XV1
Amana ACS902W GAS CARTRIDGE
General Electric ACSK15AH01 Pers elect
General Electric ACSK15AJ01 Pers elect
Amana ACT100E RANGE- S/C S/I DDRAFT GAS
Amana ACT100W RANGE- S/C S/I DDRAFT GAS
Amana ACT100WW RANGE- S/C S/I DDRAFT GAS
Amana ACT101E RANGE- S/C S/I DDRAFT GAS
Amana ACT101E ELE CARTRIDGE
Amana ACT101WW RANGE- S/C S/I DDRAFT GAS
Amana ACT101WW ELE CARTRIDGE
Amana ACT11 Freezer - Chest
Amana ACT110E RANGE- S/C S/I DDRAFT GAS
Amana ACT110W RANGE- S/C S/I DDRAFT GAS
Amana ACT110WW RANGE- S/C S/I DDRAFT GAS
Amana ACT111E RANGE- S/C S/I DDRAFT GAS
Amana ACT111E ELE CARTRIDGE
Amana ACT111WW RANGE- S/C S/I DDRAFT GAS
Amana ACT111WW ELE CARTRIDGE
General Electric ACTK15AH01 Pers elect
General Electric ACTK15AJ01 Pers elect
Amana ACU-514 RANGE- S/C S/I DDRAFT GAS
Amana ACU-516 RANGE- S/C S/I DDRAFT GAS
General Electric ACU06LAM1 Room air conditioner
Whirlpool ACU072PK0 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU072XE0 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU072XE1 THROUGH THE WALL AIR CONDITIONER
Whirlpool ACU072XE2 THROUGH THE WALL AIR CONDITIONER
Whirlpool ACU072XE3 AIR CONDITIONER
Whirlpool ACU072XH0 AIR CONDITIONER
Whirlpool ACU072XJ0 AIR CONDITIONER
Whirlpool ACU072XJ1 AIR CONDITIONER
Whirlpool ACU082XA0 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU082XD0 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU082XD1 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU082XW0 AIR CONDITIONER
Whirlpool ACU082XX0 Air-conditioner/heat pump
Whirlpool ACU082XX1 Air-conditioner/heat pump
Whirlpool ACU088PP0 AIR CONDITIONER
Whirlpool ACU088PR0 AIR CONDITIONER
Whirlpool ACU088PR1 AIR CONDITIONER
Whirlpool ACU102PK0 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU102PK1 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU102PK2 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU102XE0 AIR CONDITIONER
Whirlpool ACU102XE1 AIR CONDITIONER
Whirlpool ACU102XE2 AIR CONDITIONER
Whirlpool ACU102XE3 AIR CONDITIONER
Whirlpool ACU102XH0 AIR CONDITIONER
Whirlpool ACU102XJ0 AIR CONDITIONER
Whirlpool ACU102XJ1 AIR CONDITIONER
Whirlpool ACU102XX0 AIR CONDITIONER
Whirlpool ACU102XX1 AIR CONDITIONER
Whirlpool ACU104PK0 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU104PK1 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU104PM0 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU104XH0 AIR CONDITIONER
Whirlpool ACU104XJ0 AIR CONDITIONER
Whirlpool ACU104XJ1 AIR CONDITIONER
Whirlpool ACU108PP0 AIR CONDITIONER
Whirlpool ACU108PR0 AIR CONDITIONER
Whirlpool ACU108PV AIR CONDITIONER
Whirlpool ACU109PP0 AIR CONDITIONER
Whirlpool ACU109PR0 AIR CONDITIONER
Whirlpool ACU114XE0 AIR CONDITIONER
Whirlpool ACU114XE1 AIR CONDITIONER
Whirlpool ACU114XE2 AIR CONDITIONER
Whirlpool ACU114XE3 AIR CONDITIONER
Whirlpool ACU114XE4 AIR CONDITIONER
Whirlpool ACU114XH0 AIR CONDITIONER
Whirlpool ACU124PK0 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU124PK1 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU124PK2
Whirlpool ACU124PM0 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU124PP0 AIR CONDITIONER
Whirlpool ACU124XA0 AIR CONDITIONER
Whirlpool ACU124XD0 AIR CONDITIONER
Whirlpool ACU124XD1 AIR CONDITIONER
Whirlpool ACU124XJ0 AIR CONDITIONER
Whirlpool ACU124XJ1 AIR CONDITIONER
Whirlpool ACU124XX0 AIR CONDITIONER
Whirlpool ACU124XX1 AIR CONDITIONER
Whirlpool ACU129PP0 AIR CONDITIONER
Whirlpool ACU129PR0 AIR CONDITIONER
Whirlpool ACU129PV AIR CONDITIONER
Whirlpool ACV052XG0 AIR CONDITIONER
Whirlpool ACV052XG1 AIR CONDITIONER
Whirlpool ACV052XH0 AIR CONDITIONER
General Electric ACV05LAB1 Room air conditioner
General Electric ACV05LAB2 Room air conditioner
General Electric ACV05LAB3 Room air conditioner
General Electric ACV05LAB4 Room air conditioner
General Electric ACV05LAD1 Room air conditioner
General Electric ACV06LAD1 Room air conditioner
Whirlpool ACV072XG0 AIR CONDITIONER
Whirlpool ACV102XG0 AIR CONDITIONER
Whirlpool ACV102XH0 AIR CONDITIONER
Whirlpool ACV122XH0 AIR CONDITIONER
  #2 (permalink)
Old 07-25-2012, 05:17 AM
Junior Member
Default
any feedback folks?
  #3 (permalink)
Old 07-25-2012, 04:28 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Definitely start with the hinges first.
The right hinge Part number: R0706011
The left hinge Part number: R0706010
Here are the breakdown diagrams and Replacement parts for Amana ACS3350AS RANGE- S/C S/I GAS | AppliancePartsPros.com
Thank you.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #4 (permalink)
Old 07-30-2012, 05:53 AM
Junior Member
Default
Update ... I replaced both hinges and they work much better and it creates a better seal with the oven cavity. We were able to preheat the oven & bake a batch of brownies without the oven shutting off. Definite progress!
However, I noticed that the cooktop and the front panel (with the burner knobs) still gets too warm to the touch while the oven is on. Reading some of the posts on here, could it be the cooling fan or its limit switch that's failed? Unfortunately it seems the cooling fan is not available, and there are two limit switches available for this oven. Which is the correct one for the cooling fan? (I assume the one that does the total shutoff of the oven is working fine since the oven didn't shut off while baking yesterday)
Is going after the cooling fan system the next logical step, or am I missing something else? A leak of hot air/seal/gasket/etc/etc?
Thanks in advance!
-MP
  #5 (permalink)
Old 07-30-2012, 05:06 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi MP,
There are two control limit thermostats shown on the diagram - #17 & #20. Unfortunately Mayatd did not specified which one is for the oven and which one is for the cooling fan. The only way how to determine it is the color of the wires connected to the thermostats. Per the wiring diagram there should be the black & the yellow wires connected to the fan limit and the black & the black/white wires connected to the oven limit. Both limits have to be checked for continuity first.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #6 (permalink)
Old 08-13-2012, 10:35 AM
Junior Member
Default
Quote:
Originally Posted by Gene View Post
Hi MP,
Thanks Gene. What specifically am I looking for on the old limit switches when I test for continuity?
I assume the fan limit is open until it gets hot enough and then it closes, and the oven limit is closed until it gets too hot when it then opens to shut it off, correct?
How would I test these? Do I need to remove the top of the oven and then start the oven to see if it gets hot enough for the fan limit to kick in?
If you could detail the troubleshooting steps for this, I would greatly appreciate it!
Thanks in advance.
-MP
  #7 (permalink)
Old 08-13-2012, 07:13 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Per the tech sheet the oven limit is closed but should be open at 240F while the fan limit is open and should close at 155F.
__________________
  #8 (permalink)
Old 11-26-2012, 08:15 AM
Junior Member
jh_on_the_cape is on a distinguished road
Default
Hi. Exact same problem here. Our door hinges were replaced under warranty right after taking delivery, about ten years ago. Should I do it again?
Any other updates to this issue?
  #9 (permalink)
Old 11-26-2012, 01:12 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Exact same problem in most cases means exact same solution. Doesn't it?
You may want to replace the door hinges and perform the same troubleshooting as described earlier.
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana ACS3350AS Shuts off when hot utahjeff Oven Repair (including Ranges and Cooktops) 23 01-03-2017 06:18 AM
Amana ACS3350AS Shuts off (repaired!) Muerte Oven Repair (including Ranges and Cooktops) 1 09-20-2016 10:42 AM
Amana gas range display/control panel shuts off Jeff Yegian Oven Repair (including Ranges and Cooktops) 0 10-22-2011 11:16 AM
Control panel clock goes to 12:00 and oven shuts off steve 1b Oven Repair (including Ranges and Cooktops) 0 02-26-2011 02:53 PM
Control panel clock goes to 12:00 and oven shuts off steve 1b Oven Repair (including Ranges and Cooktops) 0 02-20-2011 09:57 AM
