Discuss
lower oven turns on by itself
 in
The lower oven unit of my double oven will turn on by itself. I have reset the circuit breaker controlling
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » lower oven turns on by itself
  #1 (permalink)
Old 07-23-2012, 12:12 PM
Junior Member
widget925 is on a distinguished road
Default lower oven turns on by itself
Model Number: KEBC208KSS0   Brand: Kitchen Aid   Age: More than 10 years
The lower oven unit of my double oven will turn on by itself. I have reset the circuit breaker controlling the ovens, but this does not help. Not long after resetting the breaker, the oven will start up, again. It seems to be using bake and heats to approx. 325-350. There is nothing displayed on the control panel (panel stays dark), but the heat exhaust fan runs. Starting the lower oven and then shutting it down will not cause it to stop. The upper oven works just fine. I replaced the control board and panel within the last 5 years. I hope not again. The breaker is off and not using the ovens.
Ads By Google
Related Models
Whirlpool KEBC208KSS0 OVEN
Whirlpool KEBC208KSS02 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC208KSS03 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC208KSS04 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC208KSS1 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECT
Whirlpool KEBC208KWH0 OVEN
Whirlpool KEBC208KWH02 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC208KWH03 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC208KWH04 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC208KWH1 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECT
Whirlpool KEBC247KBL0 OVEN
Whirlpool KEBC247KBL02 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KBL03 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KBL04 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KBL05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KBL06 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KBL07 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KBL2 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KSS03 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KSS04 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KSS05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KSS06 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KSS07 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KWH0 OVEN
Whirlpool KEBC247KWH02 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KWH03 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KWH04 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KWH05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KWH06 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KWH07 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KWH2 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247VBL00 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247VBL02 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
KitchenAid KEBC247VBL03 24" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEBC247VSS00 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247VSS02 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247VWH00 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247VWH02 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
KitchenAid KEBC247VWH03 24" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEBC276KBL0 OVEN
Whirlpool KEBC276KBL02 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KBL03 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KBL04 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KBL05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC276KBL1 DOUBLE OVEN
Whirlpool KEBC276KSS03 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KSS04 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KSS05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC276KWH0 OVEN
Whirlpool KEBC276KWH02 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KWH03 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KWH04 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KWH05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC276KWH1 DOUBLE OVEN
Whirlpool KEBC277KBL0 OVEN
Whirlpool KEBC277KBL02 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KBL03 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KBL04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KBL05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC277KBL1 DOUBLE OVEN
Whirlpool KEBC277KBT0 OVEN
Whirlpool KEBC277KBT02 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KBT03 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KBT04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KBT05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC277KBT1 DOUBLE OVEN
Whirlpool KEBC277KSS03 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KSS04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KSS05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC277KWH0 OVEN
Whirlpool KEBC277KWH02 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KWH03 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KWH04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KWH05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC277KWH1 DOUBLE OVEN
Whirlpool KEBC278HBL0 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC278HBL1 OVEN
Whirlpool KEBC278HBL2 ELECTRIC DOUBLE OVEN
Whirlpool KEBC278HBL3 ELECTRIC DOUBLE OVEN
Whirlpool KEBC278HBT0 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC278HBT1 OVEN
Whirlpool KEBC278HBT2 ELECTRIC DOUBLE OVEN
Whirlpool KEBC278HBT3 ELECTRIC DOUBLE OVEN
Whirlpool KEBC278HWH0 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC278HWH1 OVEN
Whirlpool KEBC278HWH2 ELECTRIC DOUBLE OVEN
Whirlpool KEBC278HWH3 ELECTRIC DOUBLE OVEN
Whirlpool KEBC278KBL0 OVEN
Whirlpool KEBC278KBL02 27" Built-In Electric Thermal Convection Double Oven
Whirlpool KEBC278KBL03 27" BUILT-IN ELECTRIC RANGE THERMAL CONVECTION DOUBLE OVEN
Whirlpool KEBC278KBL04 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC278KBL1 DOUBLE OVEN
Whirlpool KEBC278KBS0 OVEN
Whirlpool KEBC278KBS1 DOUBLE OVEN
Whirlpool KEBC278KBT0 OVEN
Whirlpool KEBC278KBT02 27" Built-In Electric Thermal Convection Double Oven
Whirlpool KEBC278KBT03 27" BUILT-IN ELECTRIC RANGE THERMAL CONVECTION DOUBLE OVEN
Whirlpool KEBC278KBT04 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC278KBT1 DOUBLE OVEN
Whirlpool KEBC278KSS0 OVEN
Whirlpool KEBC278KSS02 27" Built-In Electric Thermal Convection Double Oven
Whirlpool KEBC278KSS03 27" BUILT-IN ELECTRIC RANGE THERMAL CONVECTION DOUBLE OVEN
Whirlpool KEBC278KSS04 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC278KSS1 DOUBLE OVEN
Whirlpool KEBC278KWH0 OVEN
Whirlpool KEBC278KWH02 27" Built-In Electric Thermal Convection Double Oven
Whirlpool KEBC278KWH03 27" BUILT-IN ELECTRIC RANGE THERMAL CONVECTION DOUBLE OVEN
Whirlpool KEBC278KWH04 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC278KWH1 DOUBLE OVEN
Whirlpool KEBI100BBL0 30" ELEC BUILT-IN OVEN
Whirlpool KEBI100BBL1 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100BBL2 30" ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100BBL3 30" ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100BWH0 30" ELECTRIC OVEN
Whirlpool KEBI100BWH1 30" ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100BWH2 30" ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100BWH3 30" ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100SBL0 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100SBL1 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100TBL1 ELECTRIC BUILT-IN OVEN
  #2 (permalink)
Old 07-23-2012, 03:28 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Make sure that the oven is not in the sabbath mode.
Does Sab sign is on the display. If yes - press key #6 for 5 sec. to cancel the mode.
If it's not in the sabbath mode - you need the control board.
The part number is 4453661. It's not available, contact our call center for the suggestions.
Thank you.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 08-20-2012, 09:02 AM
Junior Member
Default
I have checked the Sabbath mode and even set the preset temp down to170, but the oven still heats on its own. There is absolutely nothing displayed on the touch panel, except the time. R55 seems to be a little loose. Could a cold or broken solder joint cause this problem?
  #4 (permalink)
Old 08-20-2012, 11:18 AM
Expert
Default
Hi.
In general any broken or loose connection may be the reason.
We don't know what is R55 function is.
Simon.
__________________
  #5 (permalink)
Old 08-22-2012, 06:53 PM
Junior Member
Default
I am sorry for not making that very clear. The resistor at R55 connection directly behind the clock display on the control board
  #6 (permalink)
Old 08-23-2012, 09:32 AM
Expert
Default
Hi.
If it fills loose - solder it and see if that will help.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven control panel fritzing out (turns oven back on!) mcuth Oven Repair (including Ranges and Cooktops) 0 05-20-2011 09:05 AM
Dacor Double Wall Oven-replace lower oven relay board CatsR Oven Repair (including Ranges and Cooktops) 3 01-28-2011 07:29 AM
Surface Burners work OK, Oven dead, no control light turns on for oven Whirlyone Oven Repair (including Ranges and Cooktops) 0 06-07-2010 07:24 AM
Maytag Gemini Dual Gas Oven Lower oven won't work edlakes Microwave Repair 1 06-16-2009 06:48 PM
F9 code Oven turns off,lock light turns on,door does not lock darling132 Oven Repair (including Ranges and Cooktops) 1 11-12-2008 02:06 PM
