Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   f10 error (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/491021-f10-error.html)
bizzybeez 07-23-2012 05:24 AM
f10 error
I recently replace the eoc on my fridgedaire range/oven then afer a few times of use the f10 error code tripped again any suggestion or what the next step would be
Simon / APP Team 07-23-2012 02:39 PM
Hi.
Please provide the model number of the unit.
Simon.
bizzybeez 07-24-2012 11:02 AM
fridgedaire professional series
Simon, here is the model #plefm399dca
Sincerely, Jeff
Simon / APP Team 07-24-2012 12:11 PM
Hi.
The F10 code means the over temperature conditions. most likely the temperature probe is bad.
To test it you need a multimeter set to 10000 ohm.
Normal resistance is approx. 1100 ohm at room temp.
The sensor Part number: 316490001
Here are the breakdown diagrams and Replacement parts for Frigidaire PLEFM399DCA Frigidaire/electric Range | AppliancePartsPros.com
Thank you. Post the results.
Simon.
bizzybeez 08-06-2012 04:39 AM
Simon I ordered and replace the temp probe and used the oven 3-4 times with no error codes. Thanks for all of your help
Sincerely, Jeff
Simon / APP Team 08-06-2012 09:14 AM
You are very welcome.
Simon.
