| » Kitchen Aid Oven Keeps Beeping |
Model Number: KEBS107DBL Brand: Kitchen Aid Age: More than 10 years
the control panel display f2eo and keep beeping please help
Quote:
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board). 2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock). |
You may also want to try this:
Unplug the unit Open it up Remove the ribbon cable from the keypad to the control board at the control board. Clean the edge connector. If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive. Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here. Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates. Reconnect everything and give it a try.
__________________
| Display Modes | |
| Kenmore Oven Pop noise and then constant beeping (bad control board) | mreddy | Oven Repair (including Ranges and Cooktops) | 1 | 07-29-2010 03:20 PM |
| Double oven keeps beeping and going out | SheilaEB | Oven Repair (including Ranges and Cooktops) | 0 | 12-06-2009 03:37 PM |
| Jenn-air Beeping/oven Lock | rlolle | Oven Repair (including Ranges and Cooktops) | 2 | 08-22-2009 08:10 PM |
| beeping oven | rndbdn | Oven Repair (including Ranges and Cooktops) | 0 | 02-09-2009 02:05 PM |
| GE Oven continuos beeping | jrzfamily | Oven Repair (including Ranges and Cooktops) | 1 | 10-14-2008 05:12 PM |
