| » new oven heating element will not heat |
Replacement parts for Frigidaire FEF366EMD Frigidaire/range | AppliancePartsPros.com Here is the wiring diagram http://manuals.frigidaire.com/prodin.../316441437.pdf Do the stove top elements work? Does the broil (upper) oven element work? Odds are that the control board is toast. I would remove the rear cover and check that the wiring to the elements is OK.
__________________
Quote:
Depends on your definition of easy.
If you click on a part's picture a new page will open often with more views and a Q&A section. This often has install info. Looks like you remove the rear cover to get at it, Then it is either held in by a few screws or by clips. If clips be careful that you do not break them. You may also need a new overlay (Item20A in Section 1) Looks like it is a peel and stick. Just be sure to unplug or flip the breaker when working on it. If wires can go a couple different places be sure to swap one at a time or make a list/diagram where they go.
__________________
| Display Modes | |
| Bottom oven, bottom heating element won't heat | weber7062 | Oven Repair (including Ranges and Cooktops) | 0 | 02-28-2011 02:38 PM |
| oven wont heat after replacing heating element | jeffrey l | Oven Repair (including Ranges and Cooktops) | 7 | 12-15-2009 06:18 AM |
| oven wont heat after replacing heating element | jeffrey l | Oven Repair (including Ranges and Cooktops) | 3 | 12-15-2009 06:12 AM |
| replaced heating element yet still no heat | douglas j. hoffman | Dryer Repair | 2 | 09-08-2008 03:47 AM |
| heating element won't heat up | mark80 | Oven Repair (including Ranges and Cooktops) | 1 | 10-12-2007 02:31 AM |
