Discuss
Oven temp not working right
 in
When my wife went to make a cake, the oven had not cooked the cake... we realized something was wrong.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven temp not working right
  #1 (permalink)
Old 07-13-2012, 06:14 PM
Junior Member
udo86 is on a distinguished road
Default Oven temp not working right
Model Number: FEFB55CHSE   Brand: Frigidaire   Age: More than 10 years
When my wife went to make a cake, the oven had not cooked the cake... we realized something was wrong. I have already replaced the element in the last 5 years. When I looked for advice on the problem, I thought it might be the temp sensor. I thought it was a no brainer, ordered a probe through appliance parts pro and installed it. However, that was not the correct solution and after a 2nd spoiled cake, I'm in hot water. I need a way to figure the right part to order.
This time a did an ohm test on both elements, and they tested ok (yes, wires disconnected). The advice I have found says control or timer is to blaim. If I'm going to put $200 into a part, I want to make sure that's it.
I'm more of a plumber than an electrician, but I can think like a mechanic, I just don't know what tests I should make on the system.
Thanks for any help.
Ads By Google
Related Models
Whirlpool FGP335EQ0
Whirlpool FGP335EW0
Whirlpool FGP335GN0
Whirlpool FGP335GN1
Whirlpool FGP335GQ0
Whirlpool FGP335GQ1
Whirlpool FGP335GW0
Whirlpool FGP335GW1
Whirlpool FGP335HN0
Whirlpool FGP335HQ0
Whirlpool FGP335HW0
Whirlpool FGP335VL0
Whirlpool FGP335VL1
Whirlpool FGP335VL2
Whirlpool FGP335VL3
Whirlpool FGP335VW0
Whirlpool FGP335VW1
Whirlpool FGP335VW2
Whirlpool FGP335VW3
Whirlpool FGP335YL0
Whirlpool FGP335YL1
Whirlpool FGP335YL2
Whirlpool FGP335YW0
Whirlpool FGP335YW1
Whirlpool FGP335YW2
Whirlpool FGP337GN0
Whirlpool FGP337GN1
Whirlpool FGP337GN5
Whirlpool FGP337GQ0
Whirlpool FGP337GQ1
Whirlpool FGP337GQ5
Whirlpool FGP337GW0
Whirlpool FGP337GW1
Whirlpool FGP337GW5
Whirlpool FGP337HN0
Whirlpool FGP337HQ0
Whirlpool FGP337HW0
Whirlpool FGP337KN0
Whirlpool FGP337KQ0
Whirlpool FGP337KW0
Whirlpool FGP337KW1 30" Gas Freestanding Standard Clean Range Electro
Whirlpool FGP345VL0
Whirlpool FGP345VL1
Whirlpool FGP345VL2
Whirlpool FGP345VW0
Whirlpool FGP345VW1
Whirlpool FGP345VW2
Whirlpool FGP345YL0
Whirlpool FGP345YW0
Whirlpool FGP355VL0
Whirlpool FGP355VL1
Whirlpool FGP355VL2
Whirlpool FGP355VL3
Whirlpool FGP355VW0
Whirlpool FGP355VW1
Whirlpool FGP355VW2
Whirlpool FGP355VW3
Whirlpool FGP355YL0
Whirlpool FGP355YW0
Whirlpool FGP357XL0
Whirlpool FGP357XW0
Whirlpool FGP357YL0
Whirlpool FGP357YL1
Whirlpool FGP357YL3
Whirlpool FGP357YW0
Whirlpool FGP357YW1
Whirlpool FGP357YW2
Whirlpool FGP357YW3
Frigidaire FGQ1442ES0 Frigidaire/dryer
Frigidaire FGQ332ES0 Frigidaire/gas Dryer
Frigidaire FGQB2152FE0 Frigidaire/dryer
Frigidaire FGQB4000FS0 Frigidaire/dryer
Frigidaire FGQBB30DS0 Frigidaire/dryer
Frigidaire FGR211AS0 Dryer - Frigidaire
Frigidaire FGR211AS1 Dryer - Frigidaire
Frigidaire FGR211AS2 Frigidaire/gas Dryer
Frigidaire FGR211AS3 Frigidaire/gas Dryer
Frigidaire FGR211AS4 Frigidaire/dryer
Frigidaire FGR211MAS0 Frigidaire/dryer
Frigidaire FGR221AS0 Dryer - Frigidaire
Frigidaire FGR231AS0 Dryer - Frigidaire
Frigidaire FGR231AS1 Dryer - Frigidaire
Frigidaire FGR231AS2 Frigidaire/dryer
Frigidaire FGR231AS3 Frigidaire/gas Dryer
Frigidaire FGR231AS4 Frigidaire/dryer
Frigidaire FGR231CAS4 Frigidaire/dryer
Frigidaire FGR311FS0 Frigidaire/dryer
Frigidaire FGR331AS0 Dryer - Frigidaire
Frigidaire FGR331AS1 Dryer - Frigidaire
Frigidaire FGR331KAS1 Frigidaire/gas Dryer
Frigidaire FGR341AC0 Frigidaire/dryer
Frigidaire FGR341AC1 Frigidaire/dryer
Frigidaire FGR341AS0 Dryer - Frigidaire
Frigidaire FGR341AS1 Dryer - Frigidaire
Frigidaire FGR641FS0 Frigidaire/dryer
Frigidaire FGR6600ES0 Frigidaire/dryer
Frigidaire FGR6600FS0 Frigidaire/dryer
Frigidaire FGRB5700DS0 Frigidaire/dryer
Frigidaire FGRB6600ES0 Frigidaire/dryer
Frigidaire FGRB6600FS0 Frigidaire/dryer
Frigidaire FGRB7800DS0 Frigidaire/dryer
Whirlpool FGS325RQ0 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ1 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD0 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD1 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD3 30" Gas Freestanding Self Clean Range
Whirlpool FGS335EN0
Whirlpool FGS335EQ0
Whirlpool FGS335EW0
Whirlpool FGS337GN0
Whirlpool FGS337GN1
Whirlpool FGS337GN5
Whirlpool FGS337GQ0
Whirlpool FGS337GQ1
Whirlpool FGS337GQ5
Whirlpool FGS337GQ6
Whirlpool FGS337GQ7
Whirlpool FGS337GW0
  #2 (permalink)
Old 07-14-2012, 02:44 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for Frigidaire FEFB55CHSE Frg/electric Range | AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/prodin.../318045259.pdf
Does the oven come ready or does it stay in preheat?
Since you baked a cake, it probably comes ready. I just want to be sure.
Does it take longer to come up to the set point temperature?
If yes then odds are one of the elements is not working.
Check that the wiring/connections to the elements are OK.
Since the oven does heat some, the safety thermostat is OK.
I would get an oven thermometer and then monitor the temperature.
Most units switch back and forth between the bake and broil elements when in bake mode.
So if you see the temperature drop and an element does not come on but after a while (larger temperature drop) the other element comes on, I would say that the control board is toast. As long as the wiring is OK.
__________________
  #3 (permalink)
Old 07-14-2012, 08:25 AM
Junior Member
Default
Got an oven thermometer to test oven temp. Oven takes a few minutes to pre heat to 350 degrees, when the oven beeped that it had reached 350, it actually was 300 degrees. After that, it slowly climbed to 340. Then I tried setting it higher to 400. It got to 350 then slowly climbed to 390 after 15min. I never saw top (broiler?) element turn red... not sure if it is supposed to or not. After opening the door to bring temp down, bottom element eventually came on (turning red) to heat back up to 375.
The wiring in the back appears to be all connected and no signs of fraying or burned.
Perhaps the top (broiler) element is not working??? I unhooked the wiring on the back, leaving it in the stove, and it tested ok for Ohm test.
Is there any other way I can test?
  #4 (permalink)
Old 07-15-2012, 02:58 AM
Senior Expert
APP Volunteer
Default
Set the oven to broil. Now does the broil element come on?
If not then the board is bad since the wiring and element are OK.
Sounds like you have done a thorough test and it is pointing to a bad board.
This is assuming that the oven sensor you replaced is OK.
You could check it just to be sure. It should be about 1100 ohms at room temperature.
__________________
  #5 (permalink)
Old 07-18-2012, 06:48 PM
Junior Member
Default
I'm stumped. I turned on broiler to lo, it heated up red and got to 350.
So I borrowed a better ohm meter and the new probe i bought tested out at 1097. I decided to check out elements again, take them out completely to test and got some strange readings: .019 for bottom element and .022 for top element. Should they be around 1100 too? I didn't see anything wrong with the elements in appearance of the wiring???
  #6 (permalink)
Old 07-19-2012, 04:25 AM
Senior Expert
APP Volunteer
Default
This looks OK
No they should be around 20 ohms.
What you saw was probably due to the meter type/scale you were using.
You probably had it on a 1K (1,000) scale. so the resistance on this meter is 0.019 X 1,000 or 19 ohms.
Both elements look OK to me.
Sounds to me like the control board is toast.
__________________
  #7 (permalink)
Old 07-21-2012, 02:08 PM
Junior Member
Default
Well I ordered and installed the control board today. Went in pretty well. I tested the bake setting and I still have a problem with the preheat temp getting up high enough. I set oven baking temp at 325 and it heated up to 275. I figured I would set a little higher so I can still get baking done today and set to 375 - temp reached 350 in oven.
Is there another sensor or relay I can test?
  #8 (permalink)
Old 07-21-2012, 02:27 PM
Junior Member
Default
Later on I have been messing with the temp to try to guess which setting I need to use to get the temp I want and just use the oven thermometer in the oven to help me get the right temp. The temp has even varied above my desired temp about 25 degrees. What is the normal degrees of temp that a setting will vary? +/-5, 10, 15 degrees?
  #9 (permalink)
Old 07-22-2012, 05:44 AM
Senior Expert
APP Volunteer
Default
I am not sure what the temperature variation should be in this oven.
But yours is definitely jumping around too much.
No. The oven temperature is controlled by the oven sensor and the control board.
I am stumped as you have replaced both the parts and still have a problem.
The only other thing I can think of is the vent (Items 127 and 59 in Section 2).
Check that it is clear.
This is a long shot.
My thinking here is that the oven is holding too much heat at the top so the sensor reads this and your oven temperature is then low in the center.
__________________
  #10 (permalink)
Old 07-22-2012, 12:43 PM
Junior Member
Default
Vent is clear.
I noticed that new probe was a little longer than the old one and I had to splice the wires together because the plastic connectors were not exactly the same. A little note that came with the part said I might have to do that...which wasn't a problem.
Today I baked some bread at 400 and it worked fine... I just ignored the beeper and used the oven thermometer to judge when it was hot enough.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
oven temp light not working JaneRich Oven Repair (including Ranges and Cooktops) 1 01-20-2012 04:31 AM
oven temp selector and temp in oven varies significantly larry68417 Oven Repair (including Ranges and Cooktops) 1 11-12-2010 07:02 PM
Oven Temp Touch Pad Keys stopped working 4Given Oven Repair (including Ranges and Cooktops) 0 03-30-2010 10:41 AM
Oven Temp Not Working jmhail56 Oven Repair (including Ranges and Cooktops) 1 01-03-2010 04:54 AM
Increase oven temp control not working fioman6740 Oven Repair (including Ranges and Cooktops) 1 04-26-2009 05:56 AM
