Discuss
Gas oven will not light
 in
This is the same as my other post, but I missed the C in the previous model number. Gas oven
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Gas oven will not light
  #1 (permalink)
Old 09-16-2009, 05:59 PM
sandpointrick sandpointrick is offline
Junior Member
sandpointrick is on a distinguished road
Question Gas oven will not light
Model Number: CJ9641 A590R   Brand: Hardwick   Age: More than 10 years
This is the same as my other post, but I missed the C in the previous model number. Gas oven first indicated problems with a smell of gas before igniting, now does not ignite. However, the glow plug/ignitor still glows. Could this part be losing strength or going out? Or could it be something else?
Related Models
Hardwick CJ9641A590R Range - F/s Std Gas
Hardwick CJ9641W590R Range - F/s Std Gas
Amana CJW1008.A Commercial Microwaves
Amana CJW1008.B Commercial Microwaves
Amana CJW1008.Z Commercial Microwaves
Amana CJW1040.A Commercial Microwaves
Amana CJW1040.B Commercial Microwaves
Amana CJW1040.Z Commercial Microwaves
Gaggenau CK062-604
Gaggenau CK064-604
Gaggenau CK066-604
Gaggenau CK067-604
Gaggenau CK069-604
Gaggenau CK074-604
Gaggenau CK074-614
Gaggenau CK074-624
Gaggenau CK163-604
Gaggenau CK169-604
Gaggenau CK260-604
Gaggenau CK270-604
Maytag CK277SS-1  Misc / Accessory
Maytag CK277SS-1V  Misc / Accessory
Gaggenau CK390-615
Gaggenau CK394-615
Gaggenau CK396-615
Gaggenau CK590-615
Gaggenau CK596-615
Hardwick CKD7121810AC Walloven - Cont Clean Gas
Hardwick CKD7122810AC Walloven - Std Gas
Hardwick CKD7221819A Walloven - Cont Clean Gas
Hardwick CKD7221819AC Walloven - Std Gas
Hardwick CKD7222810AC Walloven - Std Gas
Hardwick CKD7222819A Walloven - Std Gas
Hardwick CKD7224810AC Walloven - Std Gas
Hardwick CKD7224819A Walloven - Std Gas
Hardwick CKD7241819A Walloven - Cont Clean Gas
Hardwick CKD7242819A Walloven - Std Gas
Hardwick CKD7244819A Walloven - Std Gas
Hardwick CKD9512W439R Range - F/s Cont Clean Gas
Hardwick CKD9512Y439R Range - F/s Cont Clean Gas
Hardwick CKD9516W421R Range - F/s Cont Clean Gas
Hardwick CKD9517W429R Range - F/s Cont Clean Gas
Hardwick CKD9521A439R Range - F/s Cont Clean Gas
Hardwick CKD9521W439R Range - F/s Cont Clean Gas
Hardwick CKD9521W79R Range - F/s Std Gas
Hardwick CKG4612MA539RG Range - F/s Cont Clean Gas
Hardwick CKG4612MW539RG Range - F/s Cont Clean Gas
Hardwick CKG4642MA639RG Range - F/s Cont Clean Gas
Hardwick CKG4642MW639RG Range - F/s Cont Clean Gas
Hardwick CKG8421MA729RG Walloven - Std Dbl Oven Gas
Hardwick CKG8421MW729RG Walloven - Std Dbl Oven Gas
Hardwick CKG9622W439RGB Range - F/s Cont Clean Gas
Hardwick CKG9641W589RGC Range - F/s Cont Clean Gas
Hardwick CKJ9641A580RW Range - F/s Cont Clean Gas
Hardwick CKJ9641W580RW Range - F/s Cont Clean Gas
Hardwick CKM9641A580RW Range - F/s Cont Clean Gas
Hardwick CKM9641A589RGD Range - F/s Cont Clean Gas
Hardwick CKM9641W580RW Range - F/s Cont Clean Gas
Hardwick CKM9641W589RGC Range - F/s Cont Clean Gas
Hardwick CKM9641W589RGD Range - F/s Cont Clean Gas
Amana CKS3020LL Surface Unit - Gas
Amana CKS3020WW Surface Unit - Gas
Amana CKU-617 Range - S/c S/i Ddraft Gas
Amana CKU-617A Range - S/c S/i Ddraft Gas
Frigidaire CL16CA1
Frigidaire CL16CA2
Frigidaire CL21CA1
Hardwick CL4-34A9 Surface Unit - Gas
Hardwick CL4-34B9 Surface Unit - Gas
Hardwick CL4-34W9 Surface Unit - Gas
Hardwick CL4-44A9 Surface Unit - Gas
Hardwick CL4-44B9 Surface Unit - Gas
Hardwick CL4-44SA9 Surface Unit - Gas
Hardwick CL4-44SB9 Surface Unit - Gas
Hardwick CL4-44SW9 Surface Unit - Gas
Hardwick CL4-44W9 Surface Unit - Gas
Hardwick CL4-46GA9 Surface Unit - Gas
Hardwick CL4-46GB9 Surface Unit - Gas
Hardwick CL4-46GW9 Surface Unit - Gas
Whirlpool CLAA7700W2
 CLCG500FW0 CROSLEY/LAUNDRY CENTER
 CLCG900FW0 CROSLEY/LAUNDRY CENTER
Maytag CLE700 Range - Std Mwave Ele
Maytag CLE750 Range - Std Mwave Ele
Maytag CLG600 Range - Std Mwave Gas
Maytag CLG601 Range - Std Mwave Gas
Magic Chef CLL1101ADW Range - S/c F/s Ele
Magic Chef CLL1120ADH Range - F/s Std Gas
International CLR1100AJQ Range - F/s Std Gas
International CLR1100AJW Range - F/s Std Gas
Magic Chef CLY1610ADB Rv Range - Gas
Magic Chef CLY1610ADQ Rv Range - Gas
Magic Chef CLY1610ADW Rv Range - Gas
Magic Chef CLY1610BDB Rv Range - Gas
Magic Chef CLY1610BDQ Rv Range - Gas
Magic Chef CLY1610BDW Rv Range - Gas
Magic Chef CLY1611BDH Rv Range - Gas
Magic Chef CLY1612ADH Rv Range - Gas
Magic Chef CLY1612BDH Rv Range - Gas
Magic Chef CLY1620ADB Rv Range - Gas
Magic Chef CLY1620ADQ Rv Range - Gas
Magic Chef CLY1620ADS Rv Range - Gas
Magic Chef CLY1620ADW Rv Range - Gas
Magic Chef CLY1620BDB Rv Range - Gas
Magic Chef CLY1620BDS Rv Range - Gas
Magic Chef CLY1620BDW Rv Range - Gas
Magic Chef CLY1628ADB Rv Range - Gas
Magic Chef CLY1628BDB Rv Range - Gas
Magic Chef CLY1631ADB Rv Range - Gas
Magic Chef CLY1631ADH Rv Range - Gas
Magic Chef CLY1631ADL Rv Range - Gas
Magic Chef CLY1631BDB Rv Range - Gas
Magic Chef CLY1631BDH Rv Range - Gas
Magic Chef CLY1631BDL Rv Range - Gas
Magic Chef CLY1631BDT Rv Range - Gas
Magic Chef CLY1632ADB Rv Range - Gas
Magic Chef CLY1632ADH Rv Range - Gas
Magic Chef CLY1632ADL Rv Range - Gas
Magic Chef CLY1632BDB Rv Range - Gas
Magic Chef CLY1632BDH Rv Range - Gas
  #2 (permalink)
Old 09-17-2009, 06:42 AM
kayakcrzy kayakcrzy is offline
Senior Expert
APP Volunteer
kayakcrzy is on a distinguished road
Default
Quote:
Originally Posted by sandpointrick View Post
this is the same as my other post, but i missed the c in the previous model number. gas oven first indicated problems with a smell of gas before igniting, now does not ignite. however, the glow plug/ignitor still glows. could this part be losing strength or going out? or could it be something else?
replace the glow plug. that is the problem. it is not strong enough to open the gas valve, and if it does, it opens it up a little, causing the gas smell and no ignition. tom
  #3 (permalink)
Old 09-17-2009, 04:42 PM
Junior Member
Default oven won't ignite
Thank you. I ordered a new ignitor, however, I was quite disappointed I could not do it through your service. My model number pulled up Maytag parts and ignitors were nowhere to be found. I even called your 877 phone number and the person was unable to help me. I will, however, keep you in mind in the future. The model, by the way, was a Hardwick gas oven. I am currently at work and don't have the numbers handy, but you might want to get someone on being able to buy parts after things get figured out.
'Till sometime in the hopefully not too near future, but something is bound to go wrong in one of my appliances again... - Rick
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven doesn't light, Broil and Preheat will light tisears Oven Repair (including Ranges and Cooktops) 1 09-09-2009 01:38 PM
Blinking Blue Lights (Oven ON Light & Oven Heating Light bubbah2os Oven Repair (including Ranges and Cooktops) 0 01-04-2009 01:51 PM
magic chef propane oven won't light (has pilot light) A and J Oven Repair (including Ranges and Cooktops) 3 09-19-2008 01:36 PM
Oven burner wont light or takes a long time to light shadyray Oven Repair (including Ranges and Cooktops) 1 09-16-2008 01:37 PM
oven ignitor not clicking, but pilot will light manually and then the oven will work rosscol Oven Repair (including Ranges and Cooktops) 0 09-10-2008 06:37 PM
