| » Kenmore Elite Oven control |
Model Number: 790.99123704 Brand: Kenmore Age: 5 - 10 years
Just replaced the clock/timer control #316418750 as oven would not heat up. Set oven at 350 and it went to 400 and would not shut off without tripping the breaker. Any help would be appreciated. Used great care during installation.
Hi.
It sounds like the clock you just replaced is bad. Can you stop the oven by pressing the stop/cancel button? Does the clock displaying the "run away" temperature? Check if all the connections are correct, check the resistance of the temperature probe. Thank you. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
I am having no error messages. I set the oven at 350, using a thermometer I saw the temp at 400. I then tried to hit the off button and it went back to 350. Still could not turn off. Had to trip breaker. After oven cooled I turned it on and was able to turn it off without it going to full set temp. Are Sears parts tha tunreliable? jjjjj
Hi.
What kind thermometer did you use? Was the clock displaying the 400*F temperature? Thank you. Simon.
__________________
Hi, I used a tent shaped metal oven thermometer. All of my readings were from the thermometer and the display on the range read 350. What kind of resistance should the temp probe have at room temp? Thanks, JJ
Hi.
You can not calibrate the oven based on the thermostat you are using. Try this test: set the oven for 350F and when it'll rich the temperature turn it off. Open the door for a few minutes and restart the oven set for 350F. What temp. will it display and will it stop at 350F? Thank you. Simon. PS. The temperature sensor resistance at room temp. should be approx. 1100ohm.
__________________
| Display Modes | |
| Kenmore Elite Microwave Oven | pwilkes | Microwave Repair | 1 | 01-15-2011 12:39 PM |
| kenmore elite dishwasher control panel has gone bonkers..?? | tvlensman | Dishwasher Repair | 5 | 09-14-2010 07:11 AM |
| Burnt Electronic Control Kenmore Elite dishwasher | jazzy | Dishwasher Repair | 0 | 05-19-2010 05:41 AM |
| Kenmore Elite oven - PF error, oven not working | virginia3 | Oven Repair (including Ranges and Cooktops) | 1 | 06-24-2009 11:29 AM |
| Kenmore Elite Control Board Replacement | TAEHARVEY | Washer Repair | 1 | 01-06-2008 04:32 PM |
