| » Burners work, oven & broiler do not |
Model Number: sf362lxss0 Brand: Whirlpool Age: 1 - 5 years
Greetings,
I've read a couple of other threads on this problem (specifically Whirlpool Oven won't heat up), and ran the recommended test on the solenoid on the gas valve. The reading is supposed to be 216 ohms between each of oven/broil and common, and mine are both reading 201-202 ohms. As the title says, the top burners work but neither the oven nor broiler will light. No error codes. When attempting to start the oven, there are 2 clicks from the control panel, but no other noises/clicks. Preheat timer counts down like it has started and completes with a single beep, as it normally does. Does this sound like the gas valve, or is the reading close enough? Could the spark module and/or control board also be the culprit with these symtoms? Thanks in advance. You guys have a great site here. Jeff Ads By Google Related Models |
| Display Modes | |
| Oven won't heat right, broiler and burners work | piglet59645 | Oven Repair (including Ranges and Cooktops) | 1 | 09-27-2011 02:42 AM |
| oven and broiler won't work burners do this is gas range | flowerfarmer | Oven Repair (including Ranges and Cooktops) | 3 | 01-19-2011 02:49 PM |
| top burners work oven and broiler does not | kevin121 | Oven Repair (including Ranges and Cooktops) | 1 | 11-02-2010 09:56 AM |
| GE gas stove broiler and top burners work, but alas, no oven | pschutte | Oven Repair (including Ranges and Cooktops) | 5 | 05-17-2009 07:02 PM |
| Gas Range: Oven and broiler doesn't work, burners do | patchen | Oven Repair (including Ranges and Cooktops) | 0 | 02-09-2008 10:10 AM |
