Discuss
Thermodar PRL366EG/09 oven refusing to ignite
 in
The stove has really only been in operation maybe 3 years at most, but the oven stopped igniting. All the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Thermodar PRL366EG/09 oven refusing to ignite
  #1 (permalink)
Old 07-04-2012, 12:45 PM
Junior Member
nemonik is on a distinguished road
Unhappy Thermodar PRL366EG/09 oven refusing to ignite
Model Number: PRL366EG/09   Brand: Thermador   Age: 1 - 5 years
All the burners work including the ones that cycle off and on to provide that low flame setting Thermador likes to brag about. The oven broiler works fine too. All this leads me to believe the PC Board is fine, or maybe just the relay to the oven ignitor on the board is bad.
Thermador-blessed repair man came out and replaced part 610364 labelled the "Control Unit" described as the "CONTROL UNIT, HSI". The smaller board under the burners, accessible by taking right most two burners and spill tray out. I got all these part names from Thermador's own parts site, but they're obviously more expensive.
This failed to solve the problem and he claimed it was likely part 649291 labelled the "PC board" described as the "SERVICE KIT, CONTROL BOARD W/ UNIV MODEL SELECTOR, '09" just north of the smaller board. Paid him $250 and he went on his merry way. We've been without an oven for several months now.
I took out the igniter and OHMS tested it, and everything reads fine. I also attached my RMS meter to the power line that plugs into the base of the ignitor and grounded the meter to essentially the same place the ignitor grounds to, and then turned the oven on. It dumps 100 VAC into meter each time it tries to ignite. What should this reading be? 100 VAC sounds low.
I believe part 644424 labelled the "Ignition Device" described as "IGNITOR HSI, NITRIDE" is a heat sensor and not sensing any heat indicating ignited gas tells the PC Board as much and the board shuts off the gas, and then PC Board cycles turning the gas back on, attempts to ignite the gas, gives up... again, and again... It would do this forever if I left it to it own devices.
I've emailed Thermador for my wiring diagram. It seemed to go missing the day the repair man was here... Any idea where I could get that if Thermador is not forthcoming?
Any thoughts.
Also, the oven's blue indicator lights don't blink to indicate a problem.
-Michael
Ads By Google
Related Models
Thermador PRSE304S
Thermador PRSE364GDS
Thermador PRSE364GLS
Thermador PRSE366S
Thermador PRSE484GGS
Thermador PRSE486GDS
Thermador PRSE486GLS
Thermador PRSG304
Thermador PRSG364GD
Thermador PRSG366
Frigidaire PRT134PCD0 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT134PCD1 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT134PCD2 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT134PCD3 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT134PCH0 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT134PCH1 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT134PCH2 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT134PCW0 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT134PCW1 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT134PCW2 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT134PCW3 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT154MCD0 Wwh(v5) / Top Mount Refrigerator
Frigidaire PRT154MCD1 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT154MCD2 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT154MCD3 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT154MCD4 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT154MCD5 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT154MCF0 Wwh(v4) / Top Mount Refrigerator
Frigidaire PRT154MCH0 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT154MCH1 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT154MCH2 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT154MCH3 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT154MCV0 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT154MCW0 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT154MCW1 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT154MCW2 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT154MCW3 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT154MCW4 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT154MCW5 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT173HD0 Wwh(v5) / Top Mount Refrigerator
Frigidaire PRT173HF0 Wwh(v4) / Top Mount Refrigerator
Frigidaire PRT173HH0 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT173HV0 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT173HW0 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT173MCD0 Wwh(v5) / Top Mount Refrigerator
Frigidaire PRT173MCD1 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT173MCD2 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT173MCD3 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT173MCD4 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT173MCF0 Wwh(v4) / Top Mount Refrigerator
Frigidaire PRT173MCH0 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT173MCH1 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT173MCH2 Wwh(v4) / Top Mount Refrigerator
Frigidaire PRT173MCH3 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT173MCV0 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT173MCW0 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT173MCW1 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT173MCW2 Wwh(v6) / Top Mount Refrigerator
Frigidaire PRT173MCW3 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT173MCW4 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT193HD0 Wwh(v5) / Top Mount Refrigerator
Frigidaire PRT193HF0 Wwh(v4) / Top Mount Refrigerator
Frigidaire PRT193HH0 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT193HV0 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT193HW0 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT193MCD0 Wwh(v5) / Top Mount Refrigerator
Frigidaire PRT193MCD1 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT193MCD2 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT193MCD3 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT193MCD4 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT193MCD6 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT193MCF0 Wwh(v4) / Top Mount Refrigerator
Frigidaire PRT193MCH0 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT193MCH1 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT193MCH3 Wwh(v4) / Top Mount Refrigerator
Frigidaire PRT193MCH4 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT193MCV0 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT193MCW0 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT193MCW1 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT193MCW2 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT193MCW3 Wwh(v5) / Top Mount Refrigerator
Frigidaire PRT193MCW4 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT193MCW6 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT215MCD5 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT215MCW5 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT217HD0 Wwh(v5) / Top Mount Refrigerator
Frigidaire PRT217HF0 Wwh(v4) / Top Mount Refrigerator
Frigidaire PRT217HH0 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT217HV0 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT217HW0 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT217MCD0 Wwh(v5) / Top Mount Refrigerator
Frigidaire PRT217MCD1 Wwh(v5) / Top Mount Refrigerator
Frigidaire PRT217MCD2 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT217MCD3 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT217MCF0 Wwh(v4) / Top Mount Refrigerator
Frigidaire PRT217MCF1 Wwh(v4) / Top Mount Refrigerator
Frigidaire PRT217MCH0 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT217MCH1 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT217MCH2 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT217MCH3 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT217MCV0 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT217MCV1 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT217MCW0 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT217MCW1 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT217MCW2 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT217MCW3 Wwh(v3) / Top Mount Refrigerator
Bosch PS035-005
Bosch PS055-005
Bosch PS060-055
Bosch PS065-005
Bosch PS075-001
General Electric PSA22MIMCFBB Refrigerator
General Electric PSA22MIMCFWW Refrigerator
General Electric PSA22MIMDFBB Refrigerator
General Electric PSA22MIMDFWW Refrigerator
General Electric PSA22MIPAFBB Refrigerator
General Electric PSA22MIPAFWW Refrigerator
General Electric PSA22MIPCFBB Refrigerator
General Electric PSA22MIPCFWW Refrigerator
General Electric PSA22MIPDFBB Refrigerator
  #2 (permalink)
Old 07-07-2012, 07:13 AM
Junior Member
Steven M. Mauro is on a distinguished road
Default Thermador Oven glitz
I have a Thermador PRGS366 and my oven heats up but then it stops maintaining the proper temp in the oven. I see the glow plug is on so Im assuming its the gas valve. Any with a similar problem? Anyone know the proper fix?
thanks
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven won't ignite; front burners won't ignite SweetMary Oven Repair (including Ranges and Cooktops) 0 07-25-2011 11:32 AM
Oven Won't Ignite ssorenson Oven Repair (including Ranges and Cooktops) 0 04-03-2010 08:53 AM
gas oven doesn't ignite edegroff50 Oven Repair (including Ranges and Cooktops) 0 03-28-2010 09:01 AM
Oven will not ignite Steph5900 Oven Repair (including Ranges and Cooktops) 0 12-17-2009 10:56 AM
Oven won't ignite under 350 holtzlou Oven Repair (including Ranges and Cooktops) 0 09-13-2007 05:39 AM
