| » Whirlpool double oven |
Hi.
You need to remove the control panel and make sure that flex ribbon connector is in all the way. Pull it out and reconnect. If that not going to solve the problem - replace the control panel. Now the most interesting thing is: Per manufacturer if replacing of the control panel not taking care of the problem - replace the control board. If you get the parts from APP you may return any unused one even if they been installed. Here are the breakdown diagrams and Replacement parts for Whirlpool RBD275PDT14 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER | AppliancePartsPros.com Thank you. Post the results. Simon. .
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Hi, Simon. Thanks for the quick response. We did take the front panel-that's the control panel, right? off and unplugged and replugged the flex ribbon connector and that did not fix it. It was a little difficult to seat in, how can you tell if you've got it all the way inserted?
So if I understand correctly, the control panel should have been replaced first, then if that didn't fix it, THEN the control board should have been replaced next? I wish I had found this forum before! |
Hi.
If you already removed the control panel then all you need to do is take off the control board and reinstall it on the new control panel. Simon.
__________________
Thank you very much.
Simon.
__________________
I ordered the control panel on Thursday lunch time, it was on my front porch Friday when I got home from work. My fiance installed it, and it resolved the problem.
Thanks for your excellent customer service and surprisingly quick delivery! |
You are very welcome.
Now you know who is the best appliance parts company in the universe. Simon.
__________________
| Display Modes | |
| whirlpool double oven not getting hot | scottrobyn | Oven Repair (including Ranges and Cooktops) | 1 | 12-24-2011 05:58 AM |
| Whirlpool Double Oven help | ARON A | Oven Repair (including Ranges and Cooktops) | 0 | 02-27-2011 07:36 PM |
| Whirlpool Double Oven | sapmickey | Oven Repair (including Ranges and Cooktops) | 0 | 09-06-2010 12:18 PM |
| whirlpool double oven | apsmooth | Oven Repair (including Ranges and Cooktops) | 1 | 01-22-2010 07:27 PM |
| E6 F2 on Whirlpool Double Oven | cdleblan | Oven Repair (including Ranges and Cooktops) | 1 | 09-23-2009 10:58 AM |
