Discuss
replace burner/heating element switch
 in
the LF burner indicator light will not stop. it is located below the knob that operater the burner. the use
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » replace burner/heating element switch
  #1 (permalink)
Old 06-29-2012, 08:31 AM
Junior Member
mountain is on a distinguished road
Default replace burner/heating element switch
Model Number: KESC300BWH6   Brand: Kitchen Aid   Age: More than 10 years
the LF burner indicator light will not stop. it is located below the knob that operater the burner. the use of the burner is still ok. i think the switch needs replacement. i believe i have identified the correct PN of the switch thru sears. how do i get to the switch under the control panel so i can replace it?
Ads By Google
Related Models
Whirlpool KESC300BWH6
Whirlpool KESC300BWH8
Whirlpool KESC300BWH9
Whirlpool KESC300HBL0
Whirlpool KESC300HBL1
Whirlpool KESC300HBL3
Whirlpool KESC300HBL4
Whirlpool KESC300HBL5
Whirlpool KESC300HBL6
Whirlpool KESC300HBL8
Whirlpool KESC300HBT0
Whirlpool KESC300HBT1
Whirlpool KESC300HBT3
Whirlpool KESC300HBT4
Whirlpool KESC300HBT5
Whirlpool KESC300HBT6
Whirlpool KESC300HBT8
Whirlpool KESC300HWH0
Whirlpool KESC300HWH1
Whirlpool KESC300HWH3
Whirlpool KESC300HWH4
Whirlpool KESC300HWH5
Whirlpool KESC300HWH6
Whirlpool KESC300HWH8
Whirlpool KESC307BAL1
Whirlpool KESC307BAL2
Whirlpool KESC307BAL3
Whirlpool KESC307BAL4
Whirlpool KESC307BAL5
Whirlpool KESC307BAL6
Whirlpool KESC307BAL8
Whirlpool KESC307BAL9
Whirlpool KESC307BWH1
Whirlpool KESC307BWH2
Whirlpool KESC307BWH3
Whirlpool KESC307BWH4
Whirlpool KESC307BWH5
Whirlpool KESC307BWH6
Whirlpool KESC307BWH8
Whirlpool KESC307BWH9
Whirlpool KESC307GAL0
Whirlpool KESC307GAL1
Whirlpool KESC307GBL0
Whirlpool KESC307GBL1
Whirlpool KESC307GBS0
Whirlpool KESC307GBS1
Whirlpool KESC307GBT0
Whirlpool KESC307GBT1
Whirlpool KESC307GWH0
Whirlpool KESC307GWH1
Whirlpool KESC307HBL0
Whirlpool KESC307HBL1
Whirlpool KESC307HBL3
Whirlpool KESC307HBL4
Whirlpool KESC307HBL6
Whirlpool KESC307HBL8
Whirlpool KESC307HBS0
Whirlpool KESC307HBS1
Whirlpool KESC307HBS3
Whirlpool KESC307HBS4
Whirlpool KESC307HBS5
Whirlpool KESC307HBS6
Whirlpool KESC307HBS8
Whirlpool KESC307HBT0
Whirlpool KESC307HBT1
Whirlpool KESC307HBT3
Whirlpool KESC307HBT4
Whirlpool KESC307HBT5
Whirlpool KESC307HBT6
Whirlpool KESC307HBT8
Whirlpool KESC307HWH0
Whirlpool KESC307HWH1
Whirlpool KESC307HWH3
Whirlpool KESC307HWH4
Whirlpool KESC307HWH5
Whirlpool KESC307HWH6
Whirlpool KESC307HWH8
Whirlpool KESC307HWW4
Whirlpool KESC307HWW6
Whirlpool KESC307HWW8
Whirlpool KESC308LSS0 30" Slide - in Range Designer Style Convection Oven
Whirlpool KESH307BAL1
Whirlpool KESH307BAL2
Whirlpool KESH307BAL3
Whirlpool KESH307BAL4
Whirlpool KESH307BAL5
Whirlpool KESH307BAL6
Whirlpool KESH307BAL8
Whirlpool KESH307BAL9
Whirlpool KESH307BBL1
Whirlpool KESH307BBL2
Whirlpool KESH307BBL3
Whirlpool KESH307BBL4
Whirlpool KESH307BBL5
Whirlpool KESH307BBL6
Whirlpool KESH307BBL8
Whirlpool KESH307BBL9
Whirlpool KESH307BWH1
Whirlpool KESH307BWH2
Whirlpool KESH307BWH3
Whirlpool KESH307BWH4
Whirlpool KESH307BWH5
Whirlpool KESH307BWH6
Whirlpool KESH307BWH8
Whirlpool KESH307BWH9
Whirlpool KESH307GAL0
Whirlpool KESH307GAL1
Whirlpool KESH307GBL0
Whirlpool KESH307GBL1
Whirlpool KESH307GBS0
Whirlpool KESH307GBS1
Whirlpool KESH307GBT0
Whirlpool KESH307GBT1
Whirlpool KESH307GWH0
Whirlpool KESH307GWH1
Whirlpool KESH307HBL0
Whirlpool KESH307HBL1
Whirlpool KESH307HBL3
Whirlpool KESH307HBL4
Whirlpool KESH307HBL5
  #2 (permalink)
Old 06-29-2012, 01:34 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Pull off the knobs and take off the 4 mounting nuts, lift the glass pad.
Here are the breakdown diagram and Control panel replacement parts for Whirlpool KESC300BWH6 30" SLIDE-IN ELECTRONIC RANGE | AppliancePartsPros.com
Thank you.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 07-02-2012, 02:04 PM
Junior Member
Default a couple of questions
Quote:
Originally Posted by Simon / APP Team View Post
Hi.
Thank you.
Simon.
thanks for the idea. do the 3 screws above the oven door and under the front part panel have to be removed first? also do the end caps have to be taken off before i try to lift the glass?
thank you mountain
  #4 (permalink)
Old 07-02-2012, 03:18 PM
Expert
Default
Hi.
Take the glass off first, then you should be able to get to the switch.
Simon.
__________________
  #5 (permalink)
Old 07-08-2012, 10:32 AM
Junior Member
Default Job Done
Successful replacement of LF Switch. Steps followed. TURN OFF POSWER AT THE BREAKERS OR UNPLUG 1- remove (slide)range forward out of location in countertop far enough (6-8 inches so the end caps are totally free of the countertop. 2-remove screws in side of R and L end caps of control panel. 3- remove three screws on underside and front of control pane. 4- carefully raise the front of the control panel enough to gain access to the switch. 5- remove the LF knob, nut and washer on the top of glass which holds the switch in place. 6- remove the crimping devices/wires one at a time from the old switch (there are 5 of them) and attach to new switch. 7 - reverse the steps. Thanks to all who sent in their suggestions. mountain
  #6 (permalink)
Old 07-08-2012, 12:23 PM
Expert
Default
You are welcome.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Need to replace the R/F burner switch union1127 Oven Repair (including Ranges and Cooktops) 0 06-16-2011 11:29 AM
How do I replace burner switch? brigham Oven Repair (including Ranges and Cooktops) 1 12-09-2010 10:39 AM
Replace Jenn-air gas burner switch mzjnk Oven Repair (including Ranges and Cooktops) 0 11-07-2010 03:55 PM
Need to replace top burner switch brando Oven Repair (including Ranges and Cooktops) 0 02-10-2009 06:20 PM
How to replace burner element Bob M Oven Repair (including Ranges and Cooktops) 1 03-10-2008 08:57 AM
