| » oven door will not close |
Model Number: JT952SK2SS Brand: GE Age: 1 - 5 years
I'm stumped ... The bottom door stays open an inch ... I switch the bottom door with the top door and same thing ... Top door closes and bottom door stays open an inch ... Lookin and the recieving brakets on the top and bottom they both look the same ... nothin broken or out of place ... What am I missing
Ads By Google Related Models
__________________
Case Appliance Repair College Station,Texas- |
Hi gabe1981,
I can see only two possibilities in such situation: slightly bend oven door frame or dislodged and/or damaged hinge receivers. Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
To put the door back properly, you must move the hing lock tab away from the door, then, with a screwdriver, pull the door hing back, then slip the door lock tab in place to lock the hing in place, then you can put the door back in properly. The owners manual helps for this.
__________________
| Display Modes | |
| Oven door won't close | DottieH | Oven Repair (including Ranges and Cooktops) | 1 | 05-29-2012 02:54 PM |
| Oven door won't close | mhamil1017 | Oven Repair (including Ranges and Cooktops) | 4 | 04-28-2012 03:32 PM |
| Oven door won't close all the way... | RN2010 | Oven Repair (including Ranges and Cooktops) | 4 | 11-23-2010 01:08 PM |
| Oven door will not close | dkoakes | Oven Repair (including Ranges and Cooktops) | 0 | 11-01-2009 12:10 PM |
| My Oven Door Latch Won't unlock so the door won"t close | Victorine Ravenell | Oven Repair (including Ranges and Cooktops) | 1 | 11-14-2007 10:40 AM |
