Hi All, My oven quit working last night, when I set the temp. it will ignite and start to pre-heat but after about one or two minutes the clock resets to 12:00 and the oven shuts down, I reset the clock and tried it again but with the same result each time. I suspect the temperature probe but I don't know why the clock would reset also, any suggestions?
