Discuss
Oven not baking
 in
Originally Posted by junkyard38 Amanna Gas range oven heating problems/ Amanna Model ARG7600WW P1143333NWW. Cleaned the unit and all went
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven not baking
  #11 (permalink)
Old 07-22-2009, 08:05 AM
gringa gringa is offline
Junior Member
gringa is on a distinguished road
Unhappy Amana oven Model:ARG7600ww Oven wont heat up
Quote:
Cleaned the unit and all went fine this is the last time the oven worked prior.
Broiler works fine and lites off .Canceled the operation.
Cleaning feature works fine an lites off. Canceled the operation.
Stove top functions fine.
Remedies I have tried per a repair man.
Replaced the electronic module, oven does not function.
Because the unit did not bake at the required temp I needed to add 5-10 degrees to the temp setting, I also replaced the temp probe at the same time.
I cannot find a in line fuse nor any other part that has anything to do with the baking cycle. There are no burnt off wires at the terminals.
This repair advice i received has cost over $200.00 and still no oven to bake in. If anyone out there can shed some light what I need to do it would be appreciated to get this oven functioning.
Thank you ,Don
I am basically having the same problem with my oven. I smell a little bit of gas when I try to use the oven and the temperature wont go over 100 now. everything else works fine. Ive had this oven 11 years and never has a problem with it. the endcap came off about a year ago and so the top part of the stove moves a little bit when you push the settings. Not sure if this would have anything to do with this problem. Really cant afford to get a repair person to come look at it. Can you help me.
  #12 (permalink)
Old 07-22-2009, 02:01 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Quote:
Most likely the problem is a bad Bake igniter (#16 on the diagram). It comes without the mounting bracket and you have to use the old bracket. Be careful not to touch the igniter coil.
- The Bake igniter Part number: AP4041245
Here are the breakdown diagrams and Replacement parts for AMANA ARG7600WW | AppliancePartsPros.com
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
wiring up new baking element coosacat Oven Repair (including Ranges and Cooktops) 2 01-23-2008 07:11 AM
Baking Element all of sudden does not head Andi Oven Repair (including Ranges and Cooktops) 1 12-19-2007 08:21 AM
Oven stopped Baking CoreyS Oven Repair (including Ranges and Cooktops) 1 12-19-2007 08:18 AM
baking lm144 Oven Repair (including Ranges and Cooktops) 1 10-17-2007 11:52 AM
Not Baking - Literally! Not Baking Oven Repair (including Ranges and Cooktops) 3 09-11-2007 10:05 AM
