Discuss
One gas burner not lighting: No spark
 in
Recently had pot overflow while boiling water and cooktop became wet. Immediately after, heard clicking sound (like when igniting) which
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » One gas burner not lighting: No spark
  #1 (permalink)
Old 06-25-2012, 09:03 AM
Junior Member
djrosen is on a distinguished road
Default One gas burner not lighting: No spark
Model Number: GLT3615LB02   Brand: Whirlpool   Age: 5 - 10 years
Recently had pot overflow while boiling water and cooktop became wet. Immediately after, heard clicking sound (like when igniting) which I understand is normal when wet. The sound continued for about 6 hours and finally stopped. Since then I have the center rear burner which will not lite. All other burners work normally. The non functioning burner will lite with a match, but it will not spark and ignite on its own. I have checked the wire harness connecting that burner and cleaned the igniter. I do not see any cracks on the igniter and the wire seems in good condition. I disconnected the wire and cleaned the contacts to the igniter. I am not sure if the spark module, wiring harness, or some other part needs to be replaced. If someone could please help with troubleshooting this problem.
Ads By Google
Related Models
Whirlpool GLT3615LB02 36" Gas Glass Surface Cooktop
Whirlpool GLT3615LQ0
Whirlpool GLT3615LQ01 36" Gas Glass Surface Cooktop
Whirlpool GLT3615LQ02 36" Gas Glass Surface Cooktop
Whirlpool GLT3615LT0
Whirlpool GLT3615LT01 36" Gas Glass Surface Cooktop
Whirlpool GLT3615LT02 36" Gas Glass Surface Cooktop
Whirlpool GLT3634LB0
Whirlpool GLT3634LQ0
Whirlpool GLT3634LT0
Whirlpool GLT3657RB00 36" Gas Glass Surface Cooktop
Whirlpool GLT3657RB01 36" Gas Glass Surface Cooktop
Whirlpool GLT3657RB02 36" Sealed Gas Cooktop
Whirlpool GLT3657RQ00 36" Gas Glass Surface Cooktop
Whirlpool GLT3657RQ01 36" Gas Glass Surface Cooktop
Whirlpool GLT3657RQ02 36" Sealed Gas Cooktop
Whirlpool GLT3657RT00 36" Gas Glass Surface Cooktop
Whirlpool GLT3657RT01 36" Gas Glass Surface Cooktop
Whirlpool GLT3657RT02 36" Sealed Gas Cooktop
Frigidaire GLTF1040AS0 Frtld Wshr - Frig Gallery
Frigidaire GLTF1240AS0 Frtld Washer - Frig Gallery
Frigidaire GLTF1570ES0 Frigidaire/washer
Frigidaire GLTF1570ES1 Frigidaire/washer
Frigidaire GLTF1570FS0 Frigidaire/washer
Frigidaire GLTF1670AS0 Frtld Wshr - Frigidaire Gal
Frigidaire GLTF1670AS1 Frigidaire/washer
Frigidaire GLTF2070CS0 Frigidaire/washer
Frigidaire GLTF2070DS0 Frigidaire/washer
Frigidaire GLTF2940EE0 Frigidaire/washer
Frigidaire GLTF2940ES0 Frigidaire/washer
Frigidaire GLTF2940ES1 Frigidaire/washer
Frigidaire GLTF2940ES2 Frigidaire/washer
Frigidaire GLTF2940ES3 Frigidaire/washer
Frigidaire GLTF2940FE0 Frigidaire/washer
Frigidaire GLTF2940FS0 Frigidaire/washer
Frigidaire GLTF530DS0 Frigidaire/washer
Frigidaire GLTF530DS1 Frigidaire/washer
Frigidaire GLTR1670AS0 Frtld Wshr - Frigidaire Gallery
Frigidaire GLTR1670AS1 Frigidaire/washer
Whirlpool GLWA6900W0
Whirlpool GLWA6900W1
Whirlpool GLWA6900W2
Frigidaire GLWS1233AQ1 Washer - Frig Gallery
Frigidaire GLWS1233AQ2 Frigidaire/washer
Frigidaire GLWS1233AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1233AS1 Washer - Gallery
Frigidaire GLWS1233AS2 Frigidaire/washer
Frigidaire GLWS1233AS3 Frigidaire/washer
Frigidaire GLWS1339CC0 Frigidaire/washer
Frigidaire GLWS1339CS0 Frigidaire/washer
Frigidaire GLWS1339CS1 Frigidaire/washer
Frigidaire GLWS1339EC0 Frigidaire/washer
Frigidaire GLWS1339EC1 Frigidaire/washer
Frigidaire GLWS1339ES0 Frigidaire/washer
Frigidaire GLWS1339ES1 Frigidaire/washer
Frigidaire GLWS1349AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1349AS1 Washer - Frig Gallery
Frigidaire GLWS1649AS0 Washer - Frig Gallery
Frigidaire GLWS1649AS1 Washer - Frig Gallery
Frigidaire GLWS1649AS2 Frigidaire/washer
Frigidaire GLWS1649AS4 Frigidaire/washer
Frigidaire GLWS1749AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1749AS2 Washer - Frig Gallery
Frigidaire GLWS1749AS4 Frigidaire/washer
Frigidaire GLWS1749AS5 Frigidaire/washer
Frigidaire GLWS1939AS0 Frigidaire/washer
Frigidaire GLWS1939AS1 Frigidaire/washer
Frigidaire GLWS1979AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1979AS2 Washer - Frig Gallery
Frigidaire GLWS1979AS3 Frigidaire/washer
Frigidaire GLWY1343AS0 Frigidaire/washer
Frigidaire GLWY1343AS1 Frigidaire/washer
Whirlpool GLXA6900W0
Whirlpool GLXA6900W1
Whirlpool GLXA6900W2
Whirlpool GLXA6900W3
Gaggenau GM104-710
Gaggenau GM104-714
International GM1110PRW Range - F/s Std Gas
Gaggenau GM215-721
Gaggenau GM215-760
Gaggenau GM215-761
Gaggenau GM286-710
Gaggenau GM286-720
Gaggenau GM286-760
Gaggenau GM288-710
Gaggenau GM288-714
International GM3110MPAW Range - F/s Std Gas
International GM3110MXAW Range - F/s Std Gas
International GM3110PRAM Range - F/s Std Gas
International GM3110PRWM Range - F/s Std Gas
International GM31113WAM Range - F/s Std Gas
International GM31113WAV Range - F/s Std Gas
International GM3111GXAW Range - F/s Std Gas
International GM3111SXAW Range - F/s Std Gas
International GM31211XAW Range - F/s Std Gas
International GM3167WUA Range - F/s Std Gas
International GM3167WUV Range - F/s Std Gas
International GM3210MXAW Range - F/s Cont Clean Gas
International GM3211GXAA Range - F/s Cont Clean Gas
International GM3211GXAW Range - F/s Cont Clean Gas
International GM3211SXAA Range - F/s Cont Clean Gas
International GM3211SXAW Range - F/s Cont Clean Gas
International GM3216WRWM Range - F/s Cont Clean Gas
International GM32211XAW Range - F/s Cont Clean Gas
International GM3267WUAM Range - F/s Cont Clean Gas
International GM3267WUWM Range - F/s Cont Clean Gas
International GM3267XUA Range - F/s Cont Clean Gas
International GM3267XUAM Range - F/s Cont Clean Gas
International GM3267XUW Range - F/s Cont Clean Gas
International GM3267XUWM Range - F/s Cont Clean Gas
Gaggenau GM335-760
Maytag GM3468XUW-X Range - S/c F/s Gas
Maytag GM3468XUWX Range - S/c F/s Gas
International GM3510PRW Range - F/s Std Ele
International GM3531WUV Range - S/c F/s Ele
International GM3531WUW Range - S/c F/s Ele
International GM3631XUA Range - F/s Std Ele
International GM3631XUW Range - F/s Std Ele
International GM3862XUW Range - S/c F/s Ele
  #2 (permalink)
Old 06-25-2012, 11:52 AM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
When you turn the burner on does the other ignitors spark?
When you turn on any other burners does the one in question sparks?
Switch around the ignitor wires at the spark module to determine if that is module or the ignitor.
Here are the breakdown diagrams and Replacement parts for Whirlpool GLT3615LB02 36" GAS GLASS SURFACE COOKTOP | AppliancePartsPros.com
Thank you. Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 06-26-2012, 12:53 PM
Junior Member
Default
The other burners ignite normally, just the center back is not sparking. Thank you for your suggestion. I will try switching the wiring harness to see if it is the module or wiring harness.
  #4 (permalink)
Old 06-26-2012, 02:16 PM
Expert
Default
Please, post the results.
Simon.
__________________
  #5 (permalink)
Old 08-21-2012, 04:34 PM
Junior Member
Default Success
Replaced wiring harness and problem solved. Unfortunately broke 4 screw heads removing burners. Turned easy job into long hard job having to extract broken screws before being able to lift up cooktop to replace wiring harness.
Sorry it took so long to post results.
Quote:
Simon.
  #6 (permalink)
Old 08-21-2012, 05:54 PM
Expert
Default
Hi.
Don't feel bad about the screws - you are not along.
Congratulations on the job done.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Spark on Igniter for top burner Spark is WEAK or sometimes NO spark!! mobfather Oven Repair (including Ranges and Cooktops) 0 02-11-2011 10:10 AM
Top burner not lighting backloop Oven Repair (including Ranges and Cooktops) 0 06-10-2010 11:08 AM
No spark at burner - is it spark module or switch? Schoeman Oven Repair (including Ranges and Cooktops) 0 05-28-2010 01:18 PM
Top Burner Not Lighting andrewpfeifer Oven Repair (including Ranges and Cooktops) 0 04-23-2010 09:33 AM
GE cooktop burner not lighting up wen214 Oven Repair (including Ranges and Cooktops) 0 01-08-2010 11:22 PM
