Discuss
Whirpool oven broiler element not working
 in
Broiler element does not work on either broil or bake. I removed the broiler element and it reads 18 ohms.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirpool oven broiler element not working
  #1 (permalink)
Old 06-23-2012, 01:32 PM
Junior Member
Dr_Paul is on a distinguished road
Default Whirpool oven broiler element not working
Model Number: RM770PXBQ2   Brand: Whirlpool   Age: More than 10 years
Broiler element does not work on either broil or bake. I removed the broiler element and it reads 18 ohms. After removing the element I tested the voltage on the leads - with either broil or bake on the leads read 220 volts. Any ideas would be most appreciated. Thanks.
Ads By Google
Related Models
Whirlpool RM770PXBQ2
Whirlpool RM778PXT0
Whirlpool RM778PXT1
Whirlpool RM778PXT2
Whirlpool RM778PXT3
Whirlpool RM778PXT4
Whirlpool RM778PXT5
Whirlpool RM778PXXB0
Whirlpool RM778PXXB1
Whirlpool RM778PXXQ0
Whirlpool RM778PXXQ1
Whirlpool RM955PXKW0
Whirlpool RM955PXLW0
Whirlpool RM955PXLW1
Whirlpool RM955PXLW2
Whirlpool RM955PXPW0
Whirlpool RM955PXPW1
Whirlpool RM973BXPT0
Whirlpool RM973BXPT1
Whirlpool RM973BXST0
Whirlpool RM973PXKT0
Whirlpool RM973PXLT0
Whirlpool RM973PXLT1
Whirlpool RM973PXLT2
Whirlpool RM975PXKW0
Whirlpool RM975PXLW0
Whirlpool RM975PXLW1
Whirlpool RM975PXLW2
Whirlpool RM978BXPW0
Whirlpool RM978BXPW1
Whirlpool RM978BXSW0
Whirlpool RM978BXVF1
Whirlpool RM978BXVF2
Whirlpool RM978BXVM1
Whirlpool RM978BXVM2
Whirlpool RM978BXVN0
Whirlpool RM978BXVN1
Whirlpool RM978BXVN2
Whirlpool RM978BXVW0
Whirlpool RM978BXVW1
Whirlpool RM978BXVW2
Whirlpool RM980PXYN0
Whirlpool RM980PXYN1
Whirlpool RM980PXYW0
Whirlpool RM980PXYW1
Whirlpool RM988PXKW0
Whirlpool RM988PXLW0
Whirlpool RM988PXLW2
Whirlpool RM988PXLW9
Whirlpool RM988PXPW0
Whirlpool RM988PXPW1
Whirlpool RM988PXSW0
Whirlpool RM988PXVF1
Whirlpool RM988PXVF2
Whirlpool RM988PXVF3
Whirlpool RM988PXVF4
Whirlpool RM988PXVF5
Whirlpool RM988PXVM1
Whirlpool RM988PXVM2
Whirlpool RM988PXVM3
Whirlpool RM988PXVM4
Whirlpool RM988PXVM5
Whirlpool RM988PXVN0
Whirlpool RM988PXVN1
Whirlpool RM988PXVN2
Whirlpool RM988PXVN3
Whirlpool RM988PXVN4
Whirlpool RM988PXVN5
Whirlpool RM988PXVN6
Whirlpool RM988PXVW0
Whirlpool RM988PXVW1
Whirlpool RM988PXVW2
Whirlpool RM988PXVW3
Whirlpool RM988PXVW4
Whirlpool RM988PXVW5
Whirlpool RM988PXVW6
Whirlpool RM996PXVN1
Whirlpool RM996PXVN2
Whirlpool RM996PXVN3
Whirlpool RM996PXVN4
Whirlpool RM996PXVW1
Whirlpool RM996PXVW2
Whirlpool RM996PXVW3
Whirlpool RM996PXVW4
Amana RMA312 Range - S/c S/i Ddraft Gas
Amana RMA313 Range - S/c S/i Ddraft Gas
Amana RMA314 Range - S/c S/i Ddraft Gas
Amana RMA315 Range - S/c S/i Ddraft Gas
Amana RMA319 Range - S/c S/i Ddraft Gas
Amana RMA335 Range - S/i Std Gas
Amana RMA339 Range - S/i Std Gas
Amana RMA353 Range - S/c S/i Ddraft Gas
Amana RMA366 Range - S/c S/i Ddraft Gas
Amana RMA393 Range - S/i Std Gas
Amana RMA395 Range - S/i Std Gas
Amana RMA397 Range - S/c S/i Ddraft Gas
Amana RMA668 Range - S/c S/i Ddraft Gas
Amana RMC-20 Microwave - Convection
Amana RMC-20B Microwave - Convection
Amana RMC-20C Microwave - Convection
Amana RMC-20C-ET Microwave - Convection
Amana RMC-20C-ET6 Microwave - Convection
Amana RMC-30 Mwave - Family Size (60 Hz)
Amana RMC-30A Microwave - Convection
Amana RMC1TK Misc / Accessory
Whirlpool RMC275PDB1
Whirlpool RMC275PDB2
Whirlpool RMC275PDB4
Whirlpool RMC275PDQ1
Whirlpool RMC275PDQ2
Whirlpool RMC275PDQ4
Whirlpool RMC305PDB1
Whirlpool RMC305PDB2
  #2 (permalink)
Old 06-24-2012, 02:45 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for Whirlpool RM770PXBQ2 ELECTRIC RANGE AND OVEN | AppliancePartsPros.com
I could not find a wiring diagram for this unit.
18 ohms seems correct . It would work out to a 2700 watt element.
You have continuity and voltage so it should heat up.
The only thing I can think of is that another component (probably the broil control relay's contacts) have a high resistance. So you see the voltage but when the lower resistance element is connected all or most of the voltage is dropped across the contacts and the element gets little or nothing.
The way to check this is to now test with the element connected and see what the 220 does.
Another possibility is that the heating wire in the element has a break and when it heats up a bit this break opens. This has very low odds as usually the element will blow at the break.
__________________
  #3 (permalink)
Old 06-24-2012, 03:04 PM
Junior Member
Default
Thanks for your reply.
Could it possibly be the thermostat? While I see a thermostat listed on the parts list, it is no where to be found. Is it behind the oven box?
I replaced the oven sensor about a year ago so that should be OK.
Lastly, I remember that over the years we found honeycomb like pieces in the oven. Were these standoffs of some type for the broiler element? Does this have any relevance?
Thanks again for your help.
  #4 (permalink)
Old 06-24-2012, 04:36 PM
Senior Expert
APP Volunteer
Default
I cannot say if the thermostat is the problem as I cannot find a wiring diagram. Also it it was open you should not see 220 at the elements wires but it may have a high resistance and may be for the broil element.
It may be worth removing power from the unit and checking it with a meter.
I am not sure but that is a common place for them to be.
A sensor problem would probably show up as the oven coming ready when in fact it is not.
I do not think so. I think it was from the smoke eliminator. Click on it's picture (Item 9 in Section 7) for a better view of it
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
top element-broiler not working jwisnewski Oven Repair (including Ranges and Cooktops) 0 11-29-2011 05:54 AM
Oven Broiler element not working pdxjj Oven Repair (including Ranges and Cooktops) 0 11-10-2011 07:42 AM
Oven And Broiler Element both not working EddyAMiller Oven Repair (including Ranges and Cooktops) 0 10-06-2011 09:06 PM
oven element/broiler element not working stove top is MD110772 Oven Repair (including Ranges and Cooktops) 3 07-05-2011 01:23 AM
Whirpool heating element replaced. dryer not working at all azbabeliz Dryer Repair 1 06-20-2010 05:21 AM
