I have a kenmore 79092209014 electric oven that does not heat. the brolier and cook top work. can anyone tell me what the problem may be to fix it. the oven is just a year old.
Unplug the range and remove the Bake heating element. Disconnect the wires from it's terminals and check the heating element for continuity. If the heating element is good, replace the control board (aka a clock/timer). - The bake heating element Part number: 316407501
