Discuss
GE XL44 gas oven not achieving set temperature
 in
Dear Forum, I have the GE XL44 JGB920SEC4SS natural gas oven. The oven does not achieve the set temperature in
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE XL44 gas oven not achieving set temperature
  #1 (permalink)
Old 06-20-2012, 04:57 PM
Junior Member
wambo is on a distinguished road
Default GE XL44 gas oven not achieving set temperature
Model Number: JGB920SEC4SS   Brand: GE   Age: 5 - 10 years
Dear Forum,
I have the GE XL44 JGB920SEC4SS natural gas oven. The oven does not achieve the set temperature in the BAKE mode. The oven's igniter clearly glows, and the main oven burner lights briefly, but the flame flickers after about 10 seconds, as though the oven were cycling the gas value on and off. The broiler's burner works normally, as do the stove burners, so the problem is not likely a gas supply issue.
I recently (about 4 months ago) replaced a failing oven temperature sensor. The oven has worked well since then.
The "TruTemp" (that is, the temperature the oven measures, as displayed on the control panel) shows that the oven temperature gets to about 120 deg. F., but no higher. It feels like this is an accurate reflection of the actual oven temperature. Therefore, the temperature sensor seems to be working.
Could this be an igniter problem, despite the fact that it continues to glow, or should I be looking for some other issue?
Thanks for your advice.
Best Regards,
Wambo
Ads By Google
Related Models
General Electric JGB920SEC4SS Gas range
General Electric JGB920SEF1SS Gas range
General Electric JGB920SEF2SS Gas range
General Electric JGB920TEC1WW Gas range
General Electric JGB920TEC2WW Gas range
General Electric JGB920TEC3WW Gas range
General Electric JGB920TEF1WW Gas range
General Electric JGB920TEF2WW Gas range
General Electric JGB920WEC1WW Gas range
General Electric JGB920WEC2WW Gas range
General Electric JGB928BEK1BB Gas range
General Electric JGB928BEK2BB Gas range
General Electric JGB928BEK3BB Gas range
General Electric JGB928BEK4BB Gas range
General Electric JGB928BEK5BB Gas range
General Electric JGB928KEK1CC Gas range
General Electric JGB928KEK2CC Gas range
General Electric JGB928KEK3CC Gas range
General Electric JGB928KEK4CC Gas range
General Electric JGB928KEK5CC Gas range
General Electric JGB928SEK1SS Gas range
General Electric JGB928SEK2SS Gas range
General Electric JGB928SEK3SS Gas range
General Electric JGB928SEK4SS Gas range
General Electric JGB928SEK5SS Gas range
General Electric JGB928SEL1SS Gas range
General Electric JGB928TEK1WW Gas range
General Electric JGB928TEK2WW Gas range
General Electric JGB928TEK3WW Gas range
General Electric JGB928TEK4WW Gas range
General Electric JGB928TEK5WW Gas range
General Electric JGBC12GEN1 Gas range
General Electric JGBC12GEN2 Gas range
General Electric JGBC15GEK1 Gas range
General Electric JGBC15GEK3 Electric range
General Electric JGBC15GEK4 Gas range
General Electric JGBC15GEN1 Gas range
General Electric JGBC15GEN2 Gas range
General Electric JGBC15GER1 Gas range
General Electric JGBC15GER2 Gas range
General Electric JGBC15GER3 Gas range
General Electric JGBC15GER4 Gas range
General Electric JGBC15GER5 Gas range
General Electric JGBC15GER6 Gas range
General Electric JGBC16GEH1 Electric range
General Electric JGBC16GEH2 Gas range
General Electric JGBC16GEH3 Gas range
General Electric JGBC16GEH4 Gas range
General Electric JGBC16GEJ1 Electric range
General Electric JGBC16GEJ2 Gas range
General Electric JGBC16GEJ3 Gas range
General Electric JGBC16GEJ4 Gas range
General Electric JGBC16GEJ5 Gas range
General Electric JGBC16GEJ6 Gas range
General Electric JGBC16GEJ7 Gas range
General Electric JGBC16GEP1 Gas range
General Electric JGBC16GEP2 Gas range
General Electric JGBC16GEP3 Gas range
General Electric JGBC16GEP4 Gas range
General Electric JGBC16GEP5 Gas range
General Electric JGBC16GEP6 Gas range
General Electric JGBC16GEP7 Gas range
General Electric JGBC16GPH1 Gas range
General Electric JGBC16GPH2 Electric range
General Electric JGBC16GPH3 Gas range
General Electric JGBC16GPJ1 Gas range
General Electric JGBC16GPJ2 Gas range
General Electric JGBC16GPJ3 Gas range
General Electric JGBC16GPJ4 Gas range
General Electric JGBC16GPJ5 Gas range
General Electric JGBC16GPJ6 Gas range
General Electric JGBC17EV1AD Gas range
General Electric JGBC17EV1WH Gas range
General Electric JGBC17EV2AD Gas range
General Electric JGBC17EV2WH Gas range
General Electric JGBC17EV3AD Gas range
General Electric JGBC17EV3WH Gas range
General Electric JGBC17EV4AD Gas range
General Electric JGBC17EV4WH Gas range
General Electric JGBC17GEH1 Gas range
General Electric JGBC17GEH2 Gas range
General Electric JGBC17GEH3 Gas range
General Electric JGBC17GEJ1 Gas range
General Electric JGBC17GEJ2 Gas range
General Electric JGBC17GEJ3 Gas range
General Electric JGBC17GEJ4 Gas range
General Electric JGBC17GEJ5 Gas range
General Electric JGBC17GEK1 Gas range
General Electric JGBC17GEK2 Gas range
General Electric JGBC17GEK3 Gas range
General Electric JGBC17GER1 Gas range
General Electric JGBC17GER2 Gas range
General Electric JGBC17GER3 Gas range
General Electric JGBC17GER4 Gas range
General Electric JGBC17GPH1 Gas range
General Electric JGBC17GPH2 Electric range
General Electric JGBC17GPH3 Gas range
General Electric JGBC17PEA1AD Gas range
General Electric JGBC17PEA1WH Gas range
General Electric JGBC17PEA2AD Gas range
General Electric JGBC17PEA2WH Gas range
General Electric JGBC17PEA3AD Gas range
General Electric JGBC17PEA3WH Gas range
General Electric JGBC17PEW1AD Gas range
General Electric JGBC17PEW1WH Gas range
General Electric JGBC17PEW2AD
General Electric JGBC17PEW2WH
General Electric JGBC18EV1WW Gas range
General Electric JGBC18EV2WW Gas range
General Electric JGBC18EV3WW Gas range
General Electric JGBC18EV4WW Gas range
General Electric JGBC20BEA1AD Gas range
General Electric JGBC20BEA1CT Gas range
General Electric JGBC20BEA1WH Gas range
General Electric JGBC20BEA2AD Gas range
General Electric JGBC20BEA2CT Gas range
General Electric JGBC20BEA2WH Gas range
General Electric JGBC20BEA3AD Gas range
General Electric JGBC20BEA3CT Gas range
General Electric JGBC20BEA3WH Gas range
  #2 (permalink)
Old 06-21-2012, 05:06 AM
Junior Member
Default Solution to XL44 oven not heating
In the spirit of occasionally doing something right, it occurred to me that the broiler's igniter was interchangeable with the oven's igniter. After replacing the oven's igniter with the (much less used) broiler's igniter, the oven worked perfectly. Even though the oven's igniter APPEARED to be in adequate condition, I can only assume that, upon heating, the resistance measured in it is out of spec, thus causing the oven to shut off the gas flow.
If you choose to try this at home, be aware that the modular connector for the oven's igniter was, in my oven, below the lower heat shield. It took a little fancy finger work to pull the connector past the heat shield (through the hole for the gas burner), but it was not too difficult. More challenging was finding a way not to allow the oven side of the modular connector to fall back through the hole while replacing the igniter. If you drop the modular connector back below the heat shield, I suspect you'll have to remove a lot more sheet metal to find it again. This is a serious pain (prior experience), so be sure to hold the connector or tie a string to it or something.
Part for repair:
Item Number: AP2020569
Manufacturer's Number: WB13K21
Made by GE
Read more: GE WB13K21 Range Oven Igniter, AP2020569 | AppliancePartsPros.com
Appliance Parts Pros.com Discount Appliance Parts
Best Regards,
Wambo
PS: The price for the igniter on this Web site is very reasonable and their support is great, so consider patronizing them. I'm ordering one now so my broiler will again work.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE XL44 not maintaining temperature pfabian Oven Repair (including Ranges and Cooktops) 0 04-13-2011 04:07 PM
GE Oven Sprecta XL44 bigjoshracing Oven Repair (including Ranges and Cooktops) 1 02-21-2011 01:44 AM
GE XL44 Oven out - tried everything! scott2020 Oven Repair (including Ranges and Cooktops) 7 01-22-2009 05:56 PM
GE XL44 oven issue, a little different snashmcsd Oven Repair (including Ranges and Cooktops) 3 01-20-2009 02:34 PM
Oven not achieving set temperature Concep Oven Repair (including Ranges and Cooktops) 0 12-15-2008 09:52 AM
