| » Range dual element for whirlpool Stove |
Model Number: GR455LXMS Brand: Whirlpool Age: 5 - 10 years
I am trying to locate the safety heat limiter by itself for part number 4453909. This part number is the heat limiter and the dual element. The problem is that the element heats up but does not turn off. I have tried buying the surface element with the limiter through Part Select and they keep sending me a single surface element. If I have to buy the element with limiter I will I just need to be sure it will be the dual surface element.
Hi.
From the information you provided I don't think the problem is the element. Most likely there is the bad infinite burner switch. For the part numbers and more accurate assistance please provide the correct complete model number. Thank you. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Simon,
Thanks for your answer My stove is a whirlpool range model GR445LXMS serial Number RP4412793 |
Hi.
This is the infinite switch Part number: 9761048 Here are the breakdown diagrams and Replacement parts for Whirlpool GR445LXMS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN | AppliancePartsPros.com Good luck. Post the results. Simon.
__________________
Hi Simon,
Ordered the infinite switch from Appliance parts Pro and it arrived today. Took me 15 minutes to install and the stove is back to normal. I spent $45.00 on the part including shipping. A repair company would have easily charged between 1-2 hundred dollars. If I had come to you first I would have saved myself a lot of agravation Thanks a bunch Simon Quote:
You are welcome, ATMBUS.
Simon.
__________________
| Display Modes | |
| Jenn-Air range dual element burner limiter | rterrass | Oven Repair (including Ranges and Cooktops) | 1 | 03-18-2011 02:40 AM |
| Whirlpool LF dual element temperature control | guiness_2007 | Oven Repair (including Ranges and Cooktops) | 1 | 02-17-2010 06:21 PM |
| Replacing Dual Element Glass Top Slide In Range | jack141 | Oven Repair (including Ranges and Cooktops) | 4 | 12-19-2009 06:55 AM |
| Dacor electric stove dual burner element | gratefulsouth | Oven Repair (including Ranges and Cooktops) | 0 | 11-13-2009 11:22 AM |
| Kenmore dual-element range | pianimal | Oven Repair (including Ranges and Cooktops) | 0 | 04-20-2009 01:45 PM |
