Discuss
FC error code on Jenn Air range
 in
My electric range started displaying an error coce a few months back after running the oven through a cleaning cycle.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » FC error code on Jenn Air range
  #1 (permalink)
Old 06-20-2012, 09:16 AM
Junior Member
jayjohn is on a distinguished road
Default FC error code on Jenn Air range
Model Number: SVE87600   Brand: Jenn-Air   Age: More than 10 years
My electric range started displaying an error coce a few months back after running the oven through a cleaning cycle. Unfortunately I don't recall what that code was now, but after the oven cooled down some, the alarm and code went away and all functioned normally (until last weekend). We were cooking something at 400 degrees and upon turning the oven off, it started displaying the F1 code and beeping. I cut the power and turned it back on only to receive the same result. I let the oven sit overnight and tried it again to no avail, same error code and beeping. I found on this website that the F1 code indicated a failed ERC board (after running through the F1 test). I ordered and replaced the ERC board. Upon applying power, I'm now receiving and FC code. I've tried cleaning the contacts of the ribbon cable with a pencil eraser but that didn't help. I also see that I need to check the J2 cable for continuity (haven't done this yet as I'm not sure where the other end is). Suggestions, opinions, ?? Any help would be appreciated. Thanks, Jay.
Ads By Google
Related Models
Jenn-Air SVE87600B Range - S/c S/i Ddraft Ele
Jenn-Air SVE87600W Range - S/c S/i Ddraft Ele
Whirlpool SVF100W0
Whirlpool SVF100W1
Whirlpool SVF12FRHW00
Whirlpool SVF15NRHW00
Whirlpool SVF15NRHW01
Whirlpool SVF15NRHW02
Whirlpool SVF15NRJW00
Whirlpool SVF20NRKQ00
Whirlpool SVF60W0
Whirlpool SVF60W1
Whirlpool SVF70W0
Whirlpool SVF70W1
Whirlpool SVF75W0
Whirlpool SVF75W1
Whirlpool SVF75W2
Whirlpool SVF80W0
Whirlpool SVF80W1
Whirlpool SVF90W0
Whirlpool SVF90W1
Whirlpool SVP100W0
Whirlpool SVP50W0
Whirlpool SVP60W0
Whirlpool SVP60W1
Whirlpool SVP70W0
Whirlpool SVP75W0
Whirlpool SVP80W0
Whirlpool SVP90W0
Whirlpool SVU100W0
Whirlpool SVU100W1
Whirlpool SVU100W2
Whirlpool SVU60W0
Whirlpool SVU60W1
Whirlpool SVU60W2
Whirlpool SVU70W0
Whirlpool SVU70W1
Whirlpool SVU70W2
Whirlpool SVU80W0
Whirlpool SVU80W1
Whirlpool SVU80W2
Whirlpool SVU90W0
Whirlpool SVU90W1
Whirlpool SVU90W2
Amana SW22H Ref - SXS/I&W
Amana SW22MBG Ref - SXS/I&W
Amana SW22MBL Ref - SXS/I&W
Amana SW22MBW Ref - SXS/I&W
Amana SW25H Ref - SXS/I&W
Amana SWDT22H Ref - SXS/I&W
Amana SWDT25H Ref - SXS/I&W
Whirlpool SWF100W0
Whirlpool SWF100W2
Whirlpool SWF60W0
Whirlpool SWF60W2
Whirlpool SWF70W0
Whirlpool SWF70W2
Whirlpool SWF80W0
Whirlpool SWF80W2
Whirlpool SWF80W8
Whirlpool SWF80W9
Whirlpool SWF90W0
Whirlpool SWF90W1
Whirlpool SWF90W2
Amana SWP25H Ref - SXS/I&W
Whirlpool SWP70W0
Whirlpool SWP80W0
Whirlpool SWP90W0
Amana SWPD25H Ref - SXS/I&W
White Westinghouse SWS1233CQ0 White Westinghouse/washer
White Westinghouse SWS1233CQ1 White Westinghouse/washer
White Westinghouse SWS1233CS0 White Westinghouse/washer
White Westinghouse SWS1233CS1 White Westinghouse/washer
White Westinghouse SWS1339CC1 White Westinghouse/washer
White Westinghouse SWS1339CC2 White Westinghouse/washer
White Westinghouse SWS1549AQ0 Washer - W.westinghouse
White Westinghouse SWS1549AQ1 Washer - West/grupo Famsa
White Westinghouse SWS1549AQ2 White Westinghouse/washer
White Westinghouse SWS1549AS0 Washer - W.westinghouse
White Westinghouse SWS1549AS1 Washer - West/grupo Famsa
White Westinghouse SWS1549AS2 White Westinghouse/washer
White Westinghouse SWS1649CQ0 White Westinghouse/washer
White Westinghouse SWS1649CQ1 White Westinghouse/washer
White Westinghouse SWS1649CS0 White Westinghouse/washer
White Westinghouse SWS1649CS1 White Westinghouse/washer
White Westinghouse SWS933AQ0 Washer - W.westinghse
White Westinghouse SWS933AQ1 Washer - West/grupo Famsa
White Westinghouse SWS933AQ2 White Westinghouse/washer
White Westinghouse SWS933AS0 Washer - W.westinghse
White Westinghouse SWS933AS1 Washer - West/grupo Famsa
White Westinghouse SWS933AS2 White Westinghouse/washer
White Westinghouse SWSG1031DQ0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DQ1 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS1 White Westinghouse/laundry Center
White Westinghouse SWT1549AQ0 Washer - W.westinghouse
White Westinghouse SWT1549AS0 Washer - W.westinghouse
White Westinghouse SWT933AQ0 Washer - W.westinghouse
White Westinghouse SWT933AS0 Washer - W.westinghouse
Whirlpool SWU100W0
Whirlpool SWU100W2
Whirlpool SWU60W0
Whirlpool SWU60W2
Whirlpool SWU70W0
Whirlpool SWU70W2
Whirlpool SWU80W0
Whirlpool SWU80W2
Whirlpool SWU90W0
Whirlpool SWU90W2
White Westinghouse SWX703AQ0 Washer - W.westinghouse
White Westinghouse SWX703AQ1 Washer - West/grupo Famsa
White Westinghouse SWX703AQ2 White Westinghouse/washer
White Westinghouse SWX703AS0 Washer - W.westinghouse
White Westinghouse SWX703AS1 Washer - West/grupo Famsa
White Westinghouse SWX703AS2 White Westinghouse/washer
  #2 (permalink)
Old 06-20-2012, 04:45 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Jay,
How old is it? What is the serial number of the range?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn air error code F1 hkillgore Oven Repair (including Ranges and Cooktops) 1 03-13-2012 02:23 PM
Jenn-Air Range Error Code GHServices Oven Repair (including Ranges and Cooktops) 0 10-11-2011 03:13 PM
Jenn Air Over with F5 error code jimwhitingtx Oven Repair (including Ranges and Cooktops) 0 01-16-2010 08:37 AM
Jenn-Air Range Error code FF TonyW Oven Repair (including Ranges and Cooktops) 1 04-04-2009 12:59 PM
Jenn Air range error code F1-8 when hot JimSimpson Oven Repair (including Ranges and Cooktops) 1 09-25-2008 09:19 PM
