Discuss
Burner Switch
 in
Problem with left front burner stopped working. Replaced control switch went to turn on breaker will not reset. Removed wires
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Burner Switch
  #1 (permalink)
Old 09-13-2009, 04:13 PM
Mrozinski Mrozinski is offline
Junior Member
Mrozinski is on a distinguished road
Default Burner Switch
Model Number: kerc507yal2   Brand: Kitchen Aid   Age: More than 10 years
Problem with left front burner stopped working. Replaced control switch went to turn on breaker will not reset. Removed wires to control switch reset breaker other 3 burners work fine. Should burner element be replaced?
Related Models
Whirlpool KERC507YAL2
Whirlpool KERC507YAL3
Whirlpool KERC507YAL4
Whirlpool KERC507YAL5
Whirlpool KERC507YWH0
Whirlpool KERC507YWH1
Whirlpool KERC507YWH2
Whirlpool KERC507YWH3
Whirlpool KERC507YWH4
Whirlpool KERC507YWH5
Whirlpool KERC508LSS0 30" Electronic Range Freestanding Designer Style
Whirlpool KERC600EAL0
Whirlpool KERC600EAL1
Whirlpool KERC600EAL2
Whirlpool KERC600EAL5
Whirlpool KERC600EWH0
Whirlpool KERC600EWH1
Whirlpool KERC600EWH2
Whirlpool KERC600EWH5
Whirlpool KERC600GAL0
Whirlpool KERC600GAL1
Whirlpool KERC600GBS0
Whirlpool KERC600GBS1
Whirlpool KERC600GWH0
Whirlpool KERC600GWH1
Whirlpool KERC600HBS0
Whirlpool KERC600HBT0
Whirlpool KERC600HWH0
Whirlpool KERC601HBL4
Whirlpool KERC601HBL6
Whirlpool KERC601HBL8
Whirlpool KERC601HBT0
Whirlpool KERC601HBT1
Whirlpool KERC601HBT3
Whirlpool KERC601HBT4
Whirlpool KERC601HBT5
Whirlpool KERC601HBT6
Whirlpool KERC601HBT8
Whirlpool KERC601HWH0
Whirlpool KERC601HWH1
Whirlpool KERC601HWH3
Whirlpool KERC601HWH4
Whirlpool KERC601HWH5
Whirlpool KERC601HWH6
Whirlpool KERC601HWH8
Whirlpool KERC607EAL0
Whirlpool KERC607EAL1
Whirlpool KERC607EAL2
Whirlpool KERC607EAL4
Whirlpool KERC607EAL5
Whirlpool KERC607EWH0
Whirlpool KERC607EWH1
Whirlpool KERC607EWH2
Whirlpool KERC607EWH4
Whirlpool KERC607EWH5
Whirlpool KERC607GAL0
Whirlpool KERC607GAL1
Whirlpool KERC607GBL0
Whirlpool KERC607GBL1
Whirlpool KERC607GBS0
Whirlpool KERC607GBS1
Whirlpool KERC607GBT0
Whirlpool KERC607GBT1
Whirlpool KERC607GWH0
Whirlpool KERC607GWH1
Whirlpool KERC607HBL0
Whirlpool KERC607HBL1
Whirlpool KERC607HBL10 30" Free - Standing Designer Style Convection Oven
Whirlpool KERC607HBL3
Whirlpool KERC607HBL4
Whirlpool KERC607HBL5
Whirlpool KERC607HBL6
Whirlpool KERC607HBL8
Whirlpool KERC607HBS0
Whirlpool KERC607HBS1
Whirlpool KERC607HBS10 30" Free - Standing Designer Style Convection Oven
Whirlpool KERC607HBS3
Whirlpool KERC607HBS4
Whirlpool KERC607HBS5
Whirlpool KERC607HBS6
Whirlpool KERC607HBS8
Whirlpool KERC607HBT0
Whirlpool KERC607HBT1
Whirlpool KERC607HBT10 30" Free - Standing Designer Style Convection Oven
Whirlpool KERC607HBT3
Whirlpool KERC607HBT4
Whirlpool KERC607HBT5
Whirlpool KERC607HBT6
Whirlpool KERC607HBT8
Whirlpool KERC607HWH0
Whirlpool KERC607HWH1
Whirlpool KERC607HWH10 30" Free - Standing Designer Style Convection Oven
Whirlpool KERC607HWH3
Whirlpool KERC607HWH4
Whirlpool KERC607HWH5
Whirlpool KERC607HWH6
Whirlpool KERC607HWH8
Whirlpool KERC607HWW10 30" Free - Standing Designer Style Convection Oven
Whirlpool KERC607HWW4
Whirlpool KERC607HWW6
Whirlpool KERC607HWW8
Whirlpool KERC608LSS0 30" Free - Standing Designer Style Convection Oven
Whirlpool KERC700LBL0
Whirlpool KERC700LBS0
Whirlpool KERC700LBT0
Whirlpool KERC700LWH0
Whirlpool KERH507YAL0
Whirlpool KERH507YAL1
Whirlpool KERH507YAL2
Whirlpool KERH507YAL3
Whirlpool KERH507YAL4
Whirlpool KERH507YAL5
Whirlpool KERH507YBL0
Whirlpool KERH507YBL1
Whirlpool KERH507YBL2
Whirlpool KERH507YBL3
Whirlpool KERH507YBL4
Whirlpool KERH507YBL5
Whirlpool KERH507YWH0
Whirlpool KERH507YWH1
  #2 (permalink)
Old 09-13-2009, 04:29 PM
glen65 glen65 is offline
Senior Expert
APP Volunteer
glen65 is on a distinguished road
Default
Quote:
Look at the switch and its markings where the terminals are at.
They should be marked L1, L2, H1, H2 and P. List for me which
color wires you have hooked to each of these terminals.
  #3 (permalink)
Old 09-13-2009, 09:54 PM
Junior Member
Default
L1= two heavy blk wires (L1 on wire). L2= three wires purple,red & org (L2 on wire). H1= blk (H1 on wire). H2= blk. P= org (P on wire).
  #4 (permalink)
Old 09-14-2009, 10:23 AM
Senior Expert
APP Volunteer
Default
Just wanted to make sure you had the switch hooked up correctly.
I wouldn't suspect the burner unless you actually had it turned on at the
time you tried to set the breaker. You most likely just got a hold a bad
switch.
  #5 (permalink)
Old 09-14-2009, 06:39 PM
Junior Member
Default
What about the limit switch called out on the parts diagram on this site?
  #6 (permalink)
Old 09-14-2009, 09:12 PM
Senior Expert
APP Volunteer
Default
For some reason its not even showing limit switches on the schematic.
But a limit switch is usually 2 switches in 1. One is simply in series with the burner. If you have the burner switch off there's no power going to it,
so that wouldn't trip the breaker unless you had the burner switch on
when you tried to turn on the breaker. The second, is for the hot surface
lamp and is in series directly to the line. It still has voltage going to it
even if you pull the wires off of the burner switch, because I don't believe
they have those separated at the switch terminals.
Reply
« Stove | element »
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Burner switch maggic Oven Repair (including Ranges and Cooktops) 0 08-14-2009 11:23 PM
Switch or burner bad maytagproblems Oven Repair (including Ranges and Cooktops) 0 11-08-2008 08:03 AM
burner or switch royonthehill Oven Repair (including Ranges and Cooktops) 0 08-14-2008 02:03 PM
Burner or Switch BurchillB Oven Repair (including Ranges and Cooktops) 1 07-25-2008 05:57 PM
Burner or Switch roncasl Refrigerator & Freezer Repair 1 04-08-2008 12:26 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
