| » Oven won't light |
Model Number: 9122XUB Brand: Magic Chef Age: More than 10 years
Hi all,
My oven broiler won't light, I have removed the oven from the cabinet and found the insulation on the pink wire burned off and the connection plug is burned up, I have checked continuity on the igniter and it reads open, am I correct in assuming the igniter needs to be replaced and is there some other part I need to test that could of been the cause for the short circuit? Thanks, marite Ads By Google Related Models |
Hi Marite,
If there is no continuity, replace the igniter. Quote:
Before you'll do it, check for 120 VAC to the igniter wile the oven thermostat calls for Bake and then do the same for Broil. If any of the readings is incorrect, replace the oven thermostat too. - The oven igniter Part number: 12400035 - The oven thermostat Part number: 7404P098-60 Here are the breakdown diagrams and Replacement parts for Magic Chef 9122XUB WALLOVEN- STD GAS | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| Oven will not light, no light on control panel but timer works (Gene) | Xray39 | Oven Repair (including Ranges and Cooktops) | 1 | 10-30-2011 09:42 AM |
| Magic Chef oven pilot light won't light. | dugduzrepairs | Oven Repair (including Ranges and Cooktops) | 0 | 10-20-2011 09:08 PM |
| Oven burner wont light or takes a long time to light | shadyray | Oven Repair (including Ranges and Cooktops) | 4 | 01-30-2011 08:26 PM |
| Blinking Blue Lights (Oven ON Light & Oven Heating Light | bubbah2os | Oven Repair (including Ranges and Cooktops) | 1 | 02-05-2010 01:07 PM |
| magic chef propane oven won't light (has pilot light) | A and J | Oven Repair (including Ranges and Cooktops) | 3 | 09-19-2008 12:36 PM |
