Discuss
oven turns off
 in
hi my oven goes on but on its own turns off. spesifically when i bake a second time in the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven turns off
  #1 (permalink)
Old 06-19-2012, 09:26 PM
Junior Member
mlevy770 is on a distinguished road
Default oven turns off
Model Number: RGB508PPH2WH-   Brand: Hotpoint   Age: 5 - 10 years
spesifically when i bake a second time in the same day it just wont stay on.
I think it is the thermostat. what do you say?
Ads By Google
Related Models
General Electric RGB508PS1 Gas range
General Electric RGB508PS2 Gas range
General Electric RGB508PT1AD Gas range
General Electric RGB508PT1WH Gas range
General Electric RGB508PT2AD Gas range
General Electric RGB508PT2WH Gas range
General Electric RGB508PT3AD Gas range
General Electric RGB508PT3WH Gas range
General Electric RGB523PPH1CT Gas range
General Electric RGB523PPH1WH Gas range
General Electric RGB523PPH2CT Gas range
General Electric RGB523PPH2WH Gas range
General Electric RGB5241F0 Gas range
General Electric RGB5241F1 Gas range
General Electric RGB524EH1 Electric range
General Electric RGB524EJ1 Gas range
General Electric RGB524EJ2 Gas range
General Electric RGB524EJ3 Gas range
General Electric RGB524EN1 Gas range
General Electric RGB524ER1 Gas range
General Electric RGB524ER2 Gas range
General Electric RGB524ER3 Gas range
General Electric RGB524ER4 Gas range
General Electric RGB524ET1AD Gas range
General Electric RGB524ET1WH Gas range
General Electric RGB524EV1AD Gas range
General Electric RGB524EV1WH Gas range
General Electric RGB524EV2AD Gas range
General Electric RGB524EV2WH Gas range
General Electric RGB524EV3AD Gas range
General Electric RGB524EV3WH Gas range
General Electric RGB524EV4AD Gas range
General Electric RGB524EV4WH Gas range
General Electric RGB524EV5AD Gas range
General Electric RGB524EV5WH Gas range
General Electric RGB524F0 Gas range
General Electric RGB524F1 Gas range
General Electric RGB524GES1 Gas range
General Electric RGB524GES2 Gas range
General Electric RGB524GPS1 Gas range
General Electric RGB524GPS2 Gas range
General Electric RGB524PEA1AD Gas range
General Electric RGB524PEA1WH Gas range
General Electric RGB524PEA2AD Gas range
General Electric RGB524PEA2CT Gas range
General Electric RGB524PEA2WH Gas range
General Electric RGB524PEA3AD Gas range
General Electric RGB524PEA3WH Gas range
General Electric RGB524PEA4AD Gas range
General Electric RGB524PEA4WH Gas range
General Electric RGB524PEA5AD Gas range
General Electric RGB524PEA5WH Gas range
General Electric RGB524PEA6WH Gas range
General Electric RGB524PEH1CT Gas range
General Electric RGB524PEH1WH Gas range
General Electric RGB524PEH2CT Gas range
General Electric RGB524PEH2WH Gas range
General Electric RGB524PEH3CT Gas range
General Electric RGB524PEH3WH Gas range
General Electric RGB524PH1 Gas range
General Electric RGB524PJ1 Gas range
General Electric RGB524PJ2 Gas range
General Electric RGB524PJ3 Gas range
General Electric RGB524PN1 Gas range
General Electric RGB524PPA1AD Gas range
General Electric RGB524PPA1WH Gas range
General Electric RGB524PPA2AD Gas range
General Electric RGB524PPA2CT Gas range
General Electric RGB524PPA2WH Gas range
General Electric RGB524PPA3AD Gas range
General Electric RGB524PPA3WH Gas range
General Electric RGB524PPA4AD Gas range
General Electric RGB524PPA4WH Gas range
General Electric RGB524PPA5WH Gas range
General Electric RGB524PPH1CT Gas range
General Electric RGB524PPH1WH Gas range
General Electric RGB524PPH2CT Gas range
General Electric RGB524PPH2WH Gas range
General Electric RGB524PR1 Gas range
General Electric RGB524PR2 Gas range
General Electric RGB524PR3 Gas range
General Electric RGB524PT1AD Gas range
General Electric RGB524PT1WH Gas range
General Electric RGB524PV1AD Gas range
General Electric RGB524PV1WH Gas range
General Electric RGB524PV2AD Gas range
General Electric RGB524PV2WH Gas range
General Electric RGB524PV3AD Gas range
General Electric RGB524PV3WH Gas range
General Electric RGB524PV4AD Gas range
General Electric RGB524PV4WH Gas range
General Electric RGB525ES1 Gas range
General Electric RGB525ET1WW Gas range
General Electric RGB525ET2WW Gas range
General Electric RGB525ET3WW Gas range
General Electric RGB525ET4WW Gas range
General Electric RGB525PEA1WW Gas range
General Electric RGB525PEA2WW Gas range
General Electric RGB525PPA1WW Gas range
General Electric RGB525PS1 Gas range
General Electric RGB525PT1WW Gas range
General Electric RGB525PT2WW Gas range
General Electric RGB525PT3WW Gas range
General Electric RGB526ET1AD Gas range
General Electric RGB526ET1WH Gas range
General Electric RGB526ET2AD Gas range
General Electric RGB526ET2WH Gas range
General Electric RGB526ET3AD Gas range
General Electric RGB526ET3WH Gas range
General Electric RGB526ET4AD Gas range
General Electric RGB526ET4WH Gas range
General Electric RGB526GES1 Gas range
General Electric RGB526PEA1AD Gas range
General Electric RGB526PEA1CT Gas range
General Electric RGB526PEA1WH Gas range
General Electric RGB526PEA2AD Gas range
General Electric RGB526PEA2CT Gas range
General Electric RGB526PEA2WH Gas range
General Electric RGB526PEA3AD Gas range
General Electric RGB526PEA3CT Gas range
  #2 (permalink)
Old 06-20-2012, 03:40 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Most likely the problem is a bad thermostat but I would recommend to replace the pilot assembly at the same time because there is definitely a lot of build-ups inside. It will make the repair more reliable.
- The thermostat Part number: WB20K10013
- The pilot assembly Part number: WB16K10061
Here are the breakdown diagrams and Replacement parts for General Electric RGB508PPH2WH Gas range | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven control panel fritzing out (turns oven back on!) mcuth Oven Repair (including Ranges and Cooktops) 0 05-20-2011 09:05 AM
Surface Burners work OK, Oven dead, no control light turns on for oven Whirlyone Oven Repair (including Ranges and Cooktops) 0 06-07-2010 07:24 AM
F9 code Oven turns off,lock light turns on,door does not lock darling132 Oven Repair (including Ranges and Cooktops) 1 11-12-2008 02:06 PM
Clock turns on when the oven is turned on but oven doesn't work LMesey Oven Repair (including Ranges and Cooktops) 2 08-22-2008 11:20 AM
Oven Turns On All By Itself!!! CHRISTOPHER Oven Repair (including Ranges and Cooktops) 3 11-29-2007 11:44 AM
