Discuss
Jenn Air SVE47600W partial function
 in
Hi there; This range is at our vacation home and doesn't get a lot of use. We also have frequent
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn Air SVE47600W partial function
  #1 (permalink)
Old 06-19-2012, 02:34 PM
Junior Member
rick rutkowski is on a distinguished road
Default Jenn Air SVE47600W partial function
Model Number: SVE47600W   Brand: Jenn-Air   Age: More than 10 years
Hi there;
This range is at our vacation home and doesn't get a lot of use. We also have frequent power outages. Range stopped working in 2009 and I replaced the control panel located behind the Touch Panel.
Recently only a couple of the Touch buttoms respond...Convection Roast, Clock and Fan...No beeps from other buttons.
I checked ribbon connector and other connections.
Will the Touch Membrane reset ( stop +clear x 15 seconds ) help or do I need a new Touch Control Membrane ..(or perhaps a new Control Panel although I recently replaced it). Range top burners OK. When use oven ...convection roast...temp seems fine and digital display is OK. Have to turn oven off by throwing breaker switch...
Looking forward to your reply
Ads By Google
Related Models
Jenn-Air SVE47600W RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47600WC RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE87600B RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE87600W RANGE- S/C S/I DDRAFT ELE
Whirlpool SVF12FRHW00 VERTICAL FREEZER
Whirlpool SVF15NRHW00 VERTICAL FREEZER
Whirlpool SVF15NRHW01 VERTICAL FREEZER
Whirlpool SVF15NRHW02 FREEZER
Whirlpool SVF15NRJW00 FREEZER
Whirlpool SVF20NRKQ00 FREEZER
Amana SW22H REF - SXS/I&W
Amana SW22MBG REF - SXS/I&W
Amana SW22MBL REF - SXS/I&W
Amana SW22MBW REF - SXS/I&W
Amana SW25H REF - SXS/I&W
Amana SWDT22H REF - SXS/I&W
Amana SWDT25H REF - SXS/I&W
Amana SWP25H REF - SXS/I&W
Amana SWPD25H REF - SXS/I&W
White Westinghouse SWS1233CQ0 White Westinghouse/washer
White Westinghouse SWS1233CQ1 White Westinghouse/washer
White Westinghouse SWS1233CS0 White Westinghouse/washer
White Westinghouse SWS1233CS1 White Westinghouse/washer
White Westinghouse SWS1233HQ0 WASHER
White Westinghouse SWS1233HQ1 WASHER
White Westinghouse SWS1233HS0 WASHER
White Westinghouse SWS1233HS1 WASHER
White Westinghouse SWS1339CC1 White Westinghouse/washer
White Westinghouse SWS1339CC2 White Westinghouse/washer
White Westinghouse SWS1339HQ0 WASHER
White Westinghouse SWS1339HQ1 WASHER
White Westinghouse SWS1339HS0 WASHER
White Westinghouse SWS1339HS1 WASHER
White Westinghouse SWS1549AQ0 Washer - W.westinghouse
White Westinghouse SWS1549AQ1 Washer - West/grupo Famsa
White Westinghouse SWS1549AQ2 White Westinghouse/washer
White Westinghouse SWS1549AS0 Washer - W.westinghouse
White Westinghouse SWS1549AS1 Washer - West/grupo Famsa
White Westinghouse SWS1549AS2 White Westinghouse/washer
White Westinghouse SWS1649CQ0 White Westinghouse/washer
White Westinghouse SWS1649CQ1 White Westinghouse/washer
White Westinghouse SWS1649CS0 White Westinghouse/washer
White Westinghouse SWS1649CS1 White Westinghouse/washer
White Westinghouse SWS1649HQ0 WASHER
White Westinghouse SWS1649HQ1 WASHER
White Westinghouse SWS1649HS0 WASHER
White Westinghouse SWS1649HS1 WASHER
White Westinghouse SWS833HQ0 WASHER
White Westinghouse SWS833HQ1 WASHER
White Westinghouse SWS833HS0 WASHER
White Westinghouse SWS833HS1 WASHER
White Westinghouse SWS933AQ0 Washer - W.westinghse
White Westinghouse SWS933AQ1 Washer - West/grupo Famsa
White Westinghouse SWS933AQ2 White Westinghouse/washer
White Westinghouse SWS933AS0 Washer - W.westinghse
White Westinghouse SWS933AS1 Washer - West/grupo Famsa
White Westinghouse SWS933AS2 White Westinghouse/washer
White Westinghouse SWSG1031DQ0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DQ1 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS1 White Westinghouse/laundry Center
White Westinghouse SWSG1031HQ0 LAUNDRY CENTER
White Westinghouse SWSG1031HQ2 LAUNDRY CENTER
White Westinghouse SWSG1031HQ4 LAUNDRY CENTER
White Westinghouse SWSG1031HS0 LAUNDRY CENTER
White Westinghouse SWSG1031HS1 LAUNDRY CENTER
White Westinghouse SWSG1031HS2 LAUNDRY CENTER
White Westinghouse SWSG1031HS4 LAUNDRY CENTER
White Westinghouse SWT1549AQ0 Washer - W.westinghouse
White Westinghouse SWT1549AS0 Washer - W.westinghouse
White Westinghouse SWT933AQ0 Washer - W.westinghouse
White Westinghouse SWT933AS0 Washer - W.westinghouse
White Westinghouse SWX703AQ0 Washer - W.westinghouse
White Westinghouse SWX703AQ1 Washer - West/grupo Famsa
White Westinghouse SWX703AQ2 White Westinghouse/washer
White Westinghouse SWX703AS0 Washer - W.westinghouse
White Westinghouse SWX703AS1 Washer - West/grupo Famsa
White Westinghouse SWX703AS2 White Westinghouse/washer
White Westinghouse SWX703CQ0 White Westinghouse/washer
White Westinghouse SWX703CQ1 White Westinghouse/washer
White Westinghouse SWX703CS0 White Westinghouse/washer
White Westinghouse SWX703CS1 White Westinghouse/washer
White Westinghouse SWX703HQ0 WASHER
White Westinghouse SWX703HQ1 WASHER
White Westinghouse SWX703HS0 WASHER
White Westinghouse SWX703HS1 WASHER
White Westinghouse SWXG831DQ0 White Westinghouse/laundry Center
White Westinghouse SWXG831DQ1 White Westinghouse/laundry Center
White Westinghouse SWXG831DS0 White Westinghouse/laundry Center
White Westinghouse SWXG831DS1 White Westinghouse/laundry Center
White Westinghouse SWXG831HQ1 LAUNDRY CENTER
White Westinghouse SWXG831HQ2 LAUNDRY CENTER
White Westinghouse SWXG831HQ4 LAUNDRY CENTER
White Westinghouse SWXG831HS0 LAUNDRY CENTER
White Westinghouse SWXG831HS1 LAUNDRY CENTER
White Westinghouse SWXG831HS2 LAUNDRY CENTER
White Westinghouse SWXG831HS4 LAUNDRY CENTER
Amana SX1021.000 COMMERCIAL MICROWAVES
Amana SX1051.000 COMMERCIAL MICROWAVES
Amana SX19ML REF - SXS/I&W
Amana SX19MW REF - SXS/I&W
Amana SX19NL REF - SXS/I&W
Amana SX19NW REF - SXS/I&W
Amana SX22H REF - SXS/I&W
Amana SX22J REF - SXS/I&W
Amana SX22J Ref - SXS/I&W
Amana SX22MG REF - SXS/I&W
Amana SX22ML REF - SXS/I&W
Amana SX22MW REF - SXS/I&W
Amana SX22NE REF - SXS/I&W
  #2 (permalink)
Old 06-19-2012, 04:30 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Turn the power off. Open the control panel and disconnect the flex ribbon connector from the control board.
Using the pencil eraser clean the edge of the connector.
If that doesn't help - replace the touch membrane
Part number: 71002033
Here are the breakdown diagrams and Replacement parts for Jenn-Air SVE47600W RANGE- S/C S/I DDRAFT ELE | AppliancePartsPros.com
Thank you. Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 06-19-2012, 04:51 PM
Junior Member
Default
Thanks Simon..will try...
  #4 (permalink)
Old 06-19-2012, 05:58 PM
Expert
Default
You are welcome.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Help with Jenn Air SVE47600W A41 Oven Repair (including Ranges and Cooktops) 1 02-06-2010 02:50 AM
Jenn-Air Touch Pad Partial Fail shaygonen Oven Repair (including Ranges and Cooktops) 6 09-15-2009 07:27 AM
Jenn-Air SVE47600W: Oven fan won't shut off TigerDriver Oven Repair (including Ranges and Cooktops) 0 06-23-2009 12:18 PM
Partial heating bdeboard Dryer Repair 27 11-08-2008 11:48 AM
Partial ice cubes stan1 Refrigerator & Freezer Repair 0 06-26-2008 09:27 AM
