| » error code F2:E3 |
Model Number: KEBS107DWH6 Brand: Kitchen Aid Age: More than 10 years
My trouble started with the bake button not working. I used the convection bake with worked ok. Next day the bake button work but the beeped and shutoff. Tried the convection and it started but started beeping then I got code F2:E3. Now no matter what button I use I end up getting that same code. I can not find what this code means.
Thank you, Brian Ads By Google Related Models |
Replacement parts for Whirlpool KEBS107DWH6 BUILT - IN ELECTRIC OVEN | AppliancePartsPros.com See the attachment for the tech sheet. F2:E3 looks like a shorted key on the control pane (Item 1 in Section 1). Unfortunately they do not publish the ribbon cable outputs so you cannot confirm this. I would try removing power from the unit for a couple minutes to see if the microcomputer will reset itself.
__________________
| Display Modes | |
| Duet error code FH and diagnostic code C03 | angelo78 | Washer Repair | 0 | 03-21-2012 08:12 AM |
| error code F22 | sparks87144 | Washer Repair | 1 | 08-20-2011 09:57 AM |
| LG error code OE - drain error | JPotter | Washer Repair | 0 | 04-01-2011 07:20 AM |
| frigidaire error code F10 - not listed in your error codes | Skully26 | Oven Repair (including Ranges and Cooktops) | 2 | 02-16-2010 04:29 AM |
| F1 error code | Tim Lim | Oven Repair (including Ranges and Cooktops) | 11 | 12-30-2009 01:58 AM |
