Discuss
Frigidaire oven takes 45 minutes to preheat
 in
My Frigidaire oven takes at least 45 minutes to reach temp. The glow stick glows and the oven lights. It
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Frigidaire oven takes 45 minutes to preheat
  #1 (permalink)
Old 09-13-2009, 10:29 AM
Junior Member
nanmar535 is on a distinguished road
Unhappy Frigidaire oven takes 45 minutes to preheat
Model Number: FGF337AUF   Brand: Frigidaire   Age: 5 - 10 years
My Frigidaire oven takes at least 45 minutes to reach temp. The glow stick glows and the oven lights. It also cycles on and off, so you would think it is at correct temp. The other day, I was making stuffed shells (frozen). I put them in the oven after a 15 minute wait for preheat. The oven signaled that it had reached temp after they had been in for 40 minutes (a total of 55 minutes from when I turned it on!!). After they had been in the oven for 45 minutes (the recommended time), they were just barely warm. Sometimes, I will light one of the stovetop burners, and that seems to speed things up, but it doesn't always work. What do you think the problem is?
Related Models
Frigidaire FGF337AUF Frigidaire/gas Range
Frigidaire FGF337AUH Frigidaire/gas Range
Frigidaire FGF337AUJ Frigidaire/gas Range
Frigidaire FGF337AUL Frigidaire/range
Frigidaire FGF337AWA Frigidaire/gas Range
Frigidaire FGF337AWC Frigidaire/gas Range
Frigidaire FGF337AWD Frigidaire/gas Range
Frigidaire FGF337AWE Frigidaire/gas Range
Frigidaire FGF337AWF Frigidaire/gas Range
Frigidaire FGF337AWH Frigidaire/gas Range
Frigidaire FGF337AWJ Frigidaire/gas Range
Frigidaire FGF337AWL Frigidaire/range
Frigidaire FGF337BCA Frigidaire/gas Range
Frigidaire FGF337BCB Frigidaire/gas Range
Frigidaire FGF337BCC Frigidaire/gas Range
Frigidaire FGF337BCD Frigidaire/gas Range
Frigidaire FGF337BCE Frigidaire/gas Range
Frigidaire FGF337BCF Frigidaire/gas Range
Frigidaire FGF337BCG Frigidaire/range
Frigidaire FGF337BCH Frigidaire/range
Frigidaire FGF337BCL Frigidaire/range
Frigidaire FGF337EBA Frigidaire/gas Range
Frigidaire FGF337EBC Frigidaire/gas Range
Frigidaire FGF337EBD Frigidaire/range
Frigidaire FGF337ECA Frigidaire/gas Range
Frigidaire FGF337ECC Frigidaire/gas Range
Frigidaire FGF337ECD Frigidaire/range
Frigidaire FGF337ESA Frigidaire/gas Range
Frigidaire FGF337ESC Frigidaire/gas Range
Frigidaire FGF337ESD Frigidaire/range
Frigidaire FGF337EUA Frigidaire/gas Range
Frigidaire FGF337EUC Frigidaire/gas Range
Frigidaire FGF337EUD Frigidaire/range
Frigidaire FGF337EWA Frigidaire/gas Range
Frigidaire FGF337EWC Frigidaire/gas Range
Frigidaire FGF337EWD Frigidaire/range
Frigidaire FGF337GBA Frigidaire/range
Frigidaire FGF337GBB GAS RANGE
Frigidaire FGF337GBC GAS RANGE
Frigidaire FGF337GBD GAS RANGE
Frigidaire FGF337GBE GAS RANGE
Frigidaire FGF337GBF GAS RANGE
Frigidaire FGF337GBG GAS RANGE
Frigidaire FGF337GCA Frigidaire/range
Frigidaire FGF337GCB GAS RANGE
Frigidaire FGF337GCC GAS RANGE
Frigidaire FGF337GCD GAS RANGE
Frigidaire FGF337GCE GAS RANGE
Frigidaire FGF337GCF GAS RANGE
Frigidaire FGF337GCG GAS RANGE
Frigidaire FGF337GCH GAS RANGE
Frigidaire FGF337GCJ GAS RANGE
Frigidaire FGF337GCK GAS RANGE
Frigidaire FGF337GSA Frigidaire/range
Frigidaire FGF337GSB GAS RANGE
Frigidaire FGF337GSC GAS RANGE
Frigidaire FGF337GSD GAS RANGE
Frigidaire FGF337GSE GAS RANGE
Frigidaire FGF337GSF GAS RANGE
Frigidaire FGF337GSG GAS RANGE
Frigidaire FGF337GUA Frigidaire/range
Frigidaire FGF337GUB GAS RANGE
Frigidaire FGF337GUC GAS RANGE
Frigidaire FGF337GUD GAS RANGE
Frigidaire FGF337GUE GAS RANGE
Frigidaire FGF337GUF GAS RANGE
Frigidaire FGF337GWA Frigidaire/range
Frigidaire FGF337GWB GAS RANGE
Frigidaire FGF337GWC GAS RANGE
Frigidaire FGF337GWD GAS RANGE
Frigidaire FGF337GWE GAS RANGE
Frigidaire FGF337GWF GAS RANGE
Frigidaire FGF343BADA Frg(v2) / Gas Range
Frigidaire FGF343BADB Frg(v3) / Gas Range
Frigidaire FGF343BAWA Frg(v1) / Gas Range
Frigidaire FGF343BAWB Frg(v4) / Gas Range
Frigidaire FGF345BHWA Frg(v4) / Gas Range
Frigidaire FGF345BHWB Frigidaire/gas Range
Frigidaire FGF345BHWC Frigidaire/gas Range
Frigidaire FGF345GSA GAS RANGE
Frigidaire FGF345GSB GAS RANGE
Frigidaire FGF345GSC GAS RANGE
Frigidaire FGF345GSD GAS RANGE
Frigidaire FGF348KBA GAS RANGE
Frigidaire FGF348KBB GAS RANGE
Frigidaire FGF348KCA GAS RANGE
Frigidaire FGF348KCB GAS RANGE
Frigidaire FGF348KCC GAS RANGE
Frigidaire FGF348KCD GAS RANGE
Frigidaire FGF348KCE GAS RANGE
Frigidaire FGF348KCF GAS RANGE
Frigidaire FGF348KCG GAS RANGE
Frigidaire FGF348KCH GAS RANGE
Frigidaire FGF348KCJ GAS RANGE
Frigidaire FGF348KCK GAS RANGE
Frigidaire FGF348KMA GAS RANGE
Frigidaire FGF348KMB GAS RANGE
Frigidaire FGF348KSA GAS RANGE
Frigidaire FGF348KSB GAS RANGE
Frigidaire FGF348KSC GAS RANGE
Frigidaire FGF348KSD GAS RANGE
Frigidaire FGF348KSE GAS RANGE
Frigidaire FGF348KSF GAS RANGE
Frigidaire FGF348KSG GAS RANGE
Frigidaire FGF348KSH GAS RANGE
Frigidaire FGF348KSJ GAS RANGE
Frigidaire FGF350BBDA Frg(v1) / Gas Range
Frigidaire FGF350BBDB Frg(v1) / Gas Range
Frigidaire FGF350BBDC Frg(v1) / Gas Range
Frigidaire FGF350BBDD Frg(v2) / Gas Range
Frigidaire FGF350BBDE Frg(v1) / Gas Range
Frigidaire FGF350BBWA Frg(v2) / Gas Range
Frigidaire FGF350BBWB Frg(v2) / Gas Range
Frigidaire FGF350BBWC Frg(v3) / Gas Range
Frigidaire FGF350BBWD Frg(v4) / Gas Range
Frigidaire FGF350BBWE Frg(v2) / Gas Range
Frigidaire FGF350BFDA Frg(v1) / Gas Range
Frigidaire FGF350BFWA Frg(v2) / Gas Range
Frigidaire FGF350MXASA Frigidaire/gas Range
Frigidaire FGF350MXASB Frigidaire/gas Range
  #2 (permalink)
Old 09-13-2009, 11:25 AM
Senior Expert
APP Volunteer
glen65 is on a distinguished road
Default
Quote:
You would need to gain access to the burner so that you can
see how its working while the oven burner is on. Not exactly
sure how you gain access on this particular model, but it
would either be a case of removing the bottom floor cover
inside of the oven or you have to remover the storage drawer.
You then would need to observe the flame. First, does it stay
on until the thermostat clicks off? Second, how does the flame
look? The burner should put out enough flame from
each side to where it can travel up a good portion of the distance
of the metal flame spreader that sits on top of it.
  #3 (permalink)
Old 09-13-2009, 01:00 PM
Junior Member
Default
Flame looks okay to me. It takes 2-3 minutes once the glow bar comes on for the flames. Then they stay on about 3 minutes and go out for a few minutes, then glow bar starts to glow again, another 2-3 minutes for flames. This goes on and on.
  #4 (permalink)
Old 09-13-2009, 03:04 PM
Senior Expert
APP Volunteer
Default
The next thing that needs to be established is when it goes off,
whether its because the range control itself is actually turning the burner off,
or if the range control is actually trying to keep the burner turned on
and the burner simply wont stay lit. When the burner shuts down is
it accompanied by a "click sound" coming from the clock/control area?
  #5 (permalink)
Old 09-13-2009, 04:00 PM
Junior Member
Default
Yes, there is a click when it goes off, and another click when it comes back on again.
  #6 (permalink)
Old 09-13-2009, 04:48 PM
Senior Expert
APP Volunteer
Default
That narrows down to either the sensor or the control itself.
something you might try is to unplug the range or shut the power completely
off to the unit for about an hour and see if this makes any difference.
  #7 (permalink)
Old 09-13-2009, 07:39 PM
Junior Member
Default
Okay, left unplugged for a few hours. It seems to be lighting quicker, just a minute or so after the glow stick comes on. Still cycling on and off every minute or two. Is this normal? I really don't know how it worked when it did work! It did beep after the 2nd time it shut down, signaling that it was preheated. I wish I had an oven thermometer to check it.
  #8 (permalink)
Old 09-14-2009, 08:29 AM
Senior Expert
APP Volunteer
Default
The short cycles may very well be a normal part of its preheat programming.
I've seen the preheat cycle on some of these electronic ranges do
some pretty strange things. Before we go much further some temperature testing is going to need to be done to this oven to see if its coming up to its set temp.
  #9 (permalink)
Old 09-15-2009, 06:24 PM
Junior Member
Default
Thank you so much for all your help. I used the oven tonight and it seems to be fine. (First time in a long time!) I guess it just needed reset. I'll post again if I have any other problems.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven takes too long to Preheat DPetras Oven Repair (including Ranges and Cooktops) 2 02-17-2010 04:44 AM
Takes forever to preheat Jakedog67 Oven Repair (including Ranges and Cooktops) 3 01-08-2010 04:48 PM
Frigidaire oven takes 5 minutes to light riopel Oven Repair (including Ranges and Cooktops) 2 07-19-2009 12:59 PM
Frigidaire gas stove oven takes too long to light tski2 Oven Repair (including Ranges and Cooktops) 1 12-12-2008 12:37 PM
Oven takes longer to preheat than before graciesmom Oven Repair (including Ranges and Cooktops) 0 09-08-2007 08:53 AM
