Discuss
Jenn-Air Electric Range problem
 in
The Receptacle that attaches one of the heating elements broke. As my son was moving the element around to make
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn-Air Electric Range problem
  #1 (permalink)
Old 06-13-2012, 01:47 PM
Junior Member
Anthonytigre is on a distinguished road
Default Jenn-Air Electric Range problem
Model Number: C236B   Brand: Jenn-Air   Age: More than 10 years
The Receptacle that attaches one of the heating elements broke. As my son was moving the element around to make a connection sparks shot out. I flicked off the circuit breaker, unplugged the case that holds both elements, opened it, replaced both receptacle's and new elements. I turned on the circuit breaker and even though the unit that holds both elements is not plugged in yet, and both of the Infinite switches are off, the led light is on indicating that one or both of the heating elements are on. Plugging in the unit that holds both heating elements makes no difference. If I remove the unit on the left side of the range that holds the hot plates and plug in the unit from the troubled side which holds the elements it works fine on the left side. So I have a problem with the right side which is keeping the led light on and no power to the terminal block that the unit plugs into. What do you think the problem could be?
Ads By Google
Related Models
Jenn-Air C236B Surface Unit - Ddraft Ele
Jenn-Air C236B-C Surface Unit - Ddraft Ele
Jenn-Air C236B-E Surface Unit - Ddraft Ele
Jenn-Air C236NGB Surface Unit - Ddraft Ele
Jenn-Air C236NGS Surface Unit - Ddraft Ele
Jenn-Air C236NGW Surface Unit - Ddraft Ele
Jenn-Air C236W Surface Unit - Ddraft Ele
Jenn-Air C236W-C Surface Unit - Ddraft Ele
Jenn-Air C236W-E Surface Unit - Ddraft Ele
Jenn-Air C238 Surface Unit - Ddraft Ele
Jenn-Air C238B-C Surface Unit - Ddraft Ele
Amana C23B Freezer - Chest
Amana C23B-1 Freezer - Chest
Amana C23B-1-A Freezer - Chest
Amana C23B-1-C Freezer - Chest
Amana C23B-1-G Freezer - Chest
Amana C23B-1-L Freezer - Chest
Amana C23B-A Freezer - Chest
Amana C23B-C Freezer - Chest
Amana C23B-G Freezer - Chest
Amana C23B-L Freezer - Chest
Amana C23B1 Freezer - Chest
Amana C23B1L Freezer - Chest
Amana C23F Freezer - Chest
Amana C23F-A Freezer - Chest
Amana C23F-AG Freezer - Chest
Amana C23F-C Freezer - Chest
Amana C23W Freezer - Chest
Amana C23W-A Freezer - Chest
Amana C23W-AG Freezer - Chest
Amana C23W-C Freezer - Chest
Whirlpool C2557W0
Whirlpool C2557^0
Maytag C25AALWH Freezer - Chest
Maytag C25ABLWH Freezer - Chest
Maytag C25ACLWH Freezer - Chest
Maytag C25ADLWH Freezer - Chest
Maytag C25D  Freezer - Chest
Thermador C271U
Thermador C272U
Whirlpool C2757W0
Whirlpool C2757^0
Amana C28 Freezer - Chest
Amana C28B Freezer - Chest
Amana C28B-1 Freezer - Chest
Amana C28B-1-A Freezer - Chest
Amana C28B-1-C Freezer - Chest
Amana C28B-1-G Freezer - Chest
Amana C28B-1-L Freezer - Chest
Amana C28B-A Freezer - Chest
Amana C28B-C Freezer - Chest
Amana C28B-G Freezer - Chest
Amana C28B-L Freezer - Chest
Amana C28B1 Freezer - Chest
Amana C28B1L Freezer - Chest
Amana C28F Freezer - Chest
Amana C28F-A Freezer - Chest
Amana C28F-AG Freezer - Chest
Amana C28F-C Freezer - Chest
Amana C28W Freezer - Chest
Amana C28W-A Freezer - Chest
Amana C28W-AG Freezer - Chest
Amana C28W-C Freezer - Chest
  #2 (permalink)
Old 06-13-2012, 03:10 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
One of the infinite switches is shorted. The one witch controls the element in question.
Here is the part Part number: 703650
Part number: 703650
Good luck. Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 06-14-2012, 03:16 PM
Junior Member
Default Are the switches wired in series or parallel?
There's only one red LED but there are two switches for the elements on the right side. Are they wired in series? If I disconnect one will I be able to determine which one is bad, and is it likely that two went at the same time?
  #4 (permalink)
Old 06-14-2012, 03:59 PM
Expert
Default
Hi.
There are wired in parallel. Most likely it's only one bad switch, the one witch controls the broken receptacle.
Thank you. Post the results.
Simon.
__________________
  #5 (permalink)
Old 06-18-2012, 06:50 AM
Junior Member
Default Could there be a relay or some other component with a problem
I ask this because I replaced both elements and both receptacles in the draw. Led light is on, and no power. If I plug the repaired draw into the left side of the range it works fine. So the repairs to the receptacles were done correctly.
I understand that it's unlikely that both switches are burned out. That's why I asked if they are wired in parallel because neither one now works. If they're not wired in parallel and one shorts out will that stop the other one from working? Because the led light is on and neither element will work.
Is the fact that the led light is on because of a shorted switch stopping the other one from working?
I'll buy the two switches if that's what it takes to fix the problem, just don't want to do that and find out that there is a relay or some other park that's the culprit.
Thanks for your expert advice.
  #6 (permalink)
Old 06-18-2012, 11:09 AM
Expert
Default
Hi.
Disconnect the power, open the control panel, locate the P
contact at the switches and then take them off one at the time.
This way you can establish with one is bad (when the indicator light turns off).
Thank you.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn Air Electric Range Clicks phdirt Oven Repair (including Ranges and Cooktops) 2 04-26-2012 04:08 PM
Jenn Air Gas-Electric Grill-Range Dave J. Oven Repair (including Ranges and Cooktops) 2 04-11-2011 05:47 PM
Jenn-air Electric Range Key Panel rtaaron Oven Repair (including Ranges and Cooktops) 0 03-24-2011 11:19 AM
Jenn-Air Electric Range Code F3 John Cham Oven Repair (including Ranges and Cooktops) 3 03-21-2011 08:04 PM
Wiring foul-up for Jenn-Air Gas Electric range? bongo_geff Oven Repair (including Ranges and Cooktops) 6 11-05-2009 06:38 AM
