Discuss
Control Panel not working
 in
Last night my double wall oven made a series of beeps and then the display went blank. The oven does
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Control Panel not working
  #1 (permalink)
Old 06-13-2012, 08:46 AM
Junior Member
tmjenkins11 is on a distinguished road
Default Control Panel not working
Model Number: rbd306pdb14   Brand: Whirlpool   Age: 5 - 10 years
Last night my double wall oven made a series of beeps and then the display went blank. The oven does not turn on but the inside light works when the door is opened and the buttons beep when pressed. When I switched the circuit breaker off and back on, it made another series of beeps and sounded like it was trying to heat up, but then turned off.
What do you suspect the problem is and how much do you estimate that the part(s) would cost to fix the problem?
Thanks.
Ads By Google
Related Models
Whirlpool RBD306PDB14 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDB15 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDB2
Whirlpool RBD306PDB4
Whirlpool RBD306PDB6
Whirlpool RBD306PDB7
Whirlpool RBD306PDB8
Whirlpool RBD306PDB9
Whirlpool RBD306PDQ1
Whirlpool RBD306PDQ10
Whirlpool RBD306PDQ11
Whirlpool RBD306PDQ12
Whirlpool RBD306PDQ13
Whirlpool RBD306PDQ14 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDQ15 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDQ2
Whirlpool RBD306PDQ4
Whirlpool RBD306PDQ6
Whirlpool RBD306PDQ7
Whirlpool RBD306PDQ8
Whirlpool RBD306PDQ9
Whirlpool RBD306PDT11
Whirlpool RBD306PDT12
Whirlpool RBD306PDT13
Whirlpool RBD306PDT14 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDT15 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDZ1
Whirlpool RBD306PDZ10
Whirlpool RBD306PDZ2
Whirlpool RBD306PDZ4
Whirlpool RBD306PDZ6
Whirlpool RBD306PDZ7
Whirlpool RBD306PDZ8
Whirlpool RBD306PDZ9
Whirlpool RBD307PDB1
Whirlpool RBD307PDB2
Whirlpool RBD307PDQ1
Whirlpool RBD307PDQ2
Whirlpool RBD307PDQ4
Maytag RBE170PA  Ref - Top Mount
Maytag RBE170PW  Ref - Top Mount
Maytag RBE170TA Ref - Top Mount
Maytag RBE170TM Ref - Top Mount
Maytag RBE170TV Ref - Top Mount
Maytag RBE170TW Ref - Top Mount
Maytag RBE17KA-0A  Ref - Top Mount
Maytag RBE17KN-0A  Ref - Top Mount
Maytag RBE193PA  Ref - Top Mount
Maytag RBE193PW  Ref - Top Mount
Maytag RBE193TA Ref - Top Mount
Maytag RBE193TM Ref - Top Mount
Maytag RBE193TV Ref - Top Mount
Maytag RBE193TW Ref - Top Mount
Maytag RBE19KA-3A  Ref - Top Mount
Maytag RBE19KN-3A  Ref - Top Mount
Maytag RBE19KY-3A  Ref - Top Mount
Maytag RBE214AFM Ref - Top Mount
Maytag RBE214AFV Ref - Top Mount
Maytag RBE214RFA  Ref - Top Mount
Maytag RBE214RFV  Ref - Top Mount
Maytag RBE214TFA Ref - Top Mount
Maytag RBE214TFM Ref - Top Mount
Maytag RBE214TFV Ref - Top Mount
Maytag RBE21KA-4AF  Ref - Top Mount
Maytag RBE21KA4AF  Ref - Top Mount
Maytag RBE21KN-4AF  Ref - Top Mount
Maytag RBE21KN4AF  Ref - Top Mount
Frigidaire RBF136CL Frg(v1) / Electric Cooktop
Frigidaire RBF139CE1 Frg(v1) / Cooktop
Frigidaire RBF139CE2 Frg(v1) / Cooktop
Amana RBG322T Mwave - Cntrtp / Stand Alone
Amana RBG322T1 Mwave - Cntrtp / Stand Alone
Amana RBG358P Mwave - Cntrtp / Stand Alone
Amana RBG622T Mwave - Cntrtp / Stand Alone
Amana RBG635T Mwave - Cntrtp / Stand Alone
Frigidaire RBGF119E1 BLACK Frg(v8) / Electric Cooktops and Control Box
Frigidaire RBGF119EL1 Frg(v7) / Electric Cooktops and Control Box
Frigidaire RBGF119EW1 Frg(v6) / Electric Cooktops and Control Box
Amana RBK22AA0 Range - S/i Std Gas
Amana RBK22AA093M Range - S/i Std Gas
Amana RBK22AA5 Range - S/i Std Gas
Amana RBK22AAL Range - S/c S/i Ddraft Gas
Amana RBK22AAW Range - S/c S/i Ddraft Gas
Amana RBK24AA Range - S/i Std Gas
Amana RBK24AA0 Range - S/i Std Gas
Amana RBK24AA093M Range - S/i Std Gas
Amana RBK24AA5 Range - S/i Std Gas
Amana RBK24AAL Range - S/c S/i Ddraft Gas
Amana RBK24AAW Range - S/c S/i Ddraft Gas
Amana RBK26AA Range - S/i Std Gas
Amana RBK26AA0 Range - S/i Std Gas
Amana RBK26AA093M Range - S/i Std Gas
Amana RBK26AA5 Range - S/i Std Gas
Amana RBK26AAL Range - S/c S/i Ddraft Gas
Amana RBK26AAW Range - S/c S/i Ddraft Gas
Amana RBK26CBL Range - S/c S/i Ddraft Gas
Amana RBK26CBW Range - S/c S/i Ddraft Gas
  #2 (permalink)
Old 06-13-2012, 07:30 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Open the control panel and check the control panel thermal fuse, which is a part of the wire harness and plugged into the control board, for continuity.
Check the control power transformer on the right side behind the control panel. Normally it should read: between the terminals where the red wires connected -75 Ohms to 95 Ohms and between the terminals where the blue wires connected -less than 1 Ohm.
If there is nothing wrong, replace the control board.
There are two different kind of the control panel thermal fuse used in such ovens. You have to figure out bu the following pictures which one is good for your oven.
- The control panel thermal fuse with two flat terminals Part number: 4451042
- The control panel thermal fuse with one flat terminal and a hook on the other end Part number: 4456654
- The control transformer Part number: 9760587
- The control board Part number: W10406070
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool range control panel/oven not working but burners are working tacoman Oven Repair (including Ranges and Cooktops) 0 05-08-2012 09:59 AM
control panel not working tinab Oven Repair (including Ranges and Cooktops) 1 01-08-2012 06:04 AM
Control Panel Not Working GeoTheMagicChef Microwave Repair 5 07-11-2011 06:52 AM
Control Panel Not Working ecwilson Dishwasher Repair 0 01-05-2010 05:51 PM
Control Panel NOT Working johnmou Oven Repair (including Ranges and Cooktops) 0 11-16-2008 11:14 AM
