Discuss
oven won't light
 in
I Have A Coloric Stove & Oven, When I Turn The Oven Control Knob To The Bake Position & The
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven won't light
  #1 (permalink)
Old 01-25-2008, 06:00 AM
fishyfingers fishyfingers is offline
Junior Member
fishyfingers is on a distinguished road
Default oven won't light
Brand: Caloric   Age: 5 - 10 years
I Have A Coloric Stove & Oven, When I Turn The Oven Control Knob To The Bake Position & The Temp Up To Lets Say 350 Degrees The Oven No Longer Heats Up, I Removed The Drip Pan Covering The Ignighter At The Bottom Of The Oven, The Ignighter Which Is Electric, It Is Glowing Orange, But No Gas Is Flowing Thru The Gas Tube Near The Ignighter, And There Is No Flame. The Propane Tank Is Ok Because All 4 Top Burners Work Fine.
Where Should I Start Looking For The Problem??????
Fishyfingers
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-25-2008, 06:35 AM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
you should start by measuring amperage of the ignitor ... ( usually, if you leave the oven on for 5-15 minutes, it may actually come on ) most often that is the indication that the ignitor is not drawing enough amperage to actually open the valve. HOWEVER, we dont suggest that with LP ... I'd begin with the ignitor ...
__________________
regards
jim
  #3 (permalink)
Old 01-25-2008, 08:28 AM
Junior Member
Default
thanks kawfeeman!!
what should the amperage measure? and what wires do you test, both wires at the ignitor or 1 wire and ground, the ignitor is glowing bright orange and i left it on for 25 min and still did'nt light.
thanks again
  #4 (permalink)
Old 01-25-2008, 09:10 AM
Senior Expert
APP Volunteer
Default
just measure one wire going to the ignitor with an AMPROBE, not a volt meter .. you'll need a clamp on device to measure inductively the current draw... ( remember "bright orange" is relative... may not be as bright as a newer ignitor )
__________________
regards
jim
  #5 (permalink)
Old 01-25-2008, 09:53 AM
Junior Member
Default
i will measure the amperage when i get home, what amperage should i be looking for at the ignitor feed wire . i have an amprobe and i will test that tonight. i have an electrical background from the marine field 26 years, it helps a bit. if you can give me an amperage # to look for when testing and it tests good, where would i look next. i will write down the mod# to help in the future, but i do not have the mod # with me today.
thanks in advance!!!!!!
fishyfingers
  #6 (permalink)
Old 01-28-2008, 05:50 AM
Junior Member
Default
Hello Kawfeeman
Hope You Can Help!!
I Did Test The Amperage At The Ignitor Wire And Found 3.42 Amps While The Ignitor Was Glowing, Tested Both Wires, 1 At A Time And The Reading Is The Same.
Thanks In Advance!!
Fishyfingers.
  #7 (permalink)
Old 01-28-2008, 11:24 AM
RegUS_PatOff RegUS_PatOff is offline
Member
RegUS_PatOff is on a distinguished road
Default
that seems about right, but a model number would be more helpful
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven igniter clicks twice but oven does not light smanager Oven Repair (including Ranges and Cooktops) 5 01-10-2008 09:28 PM
Oven will not light G-money Oven Repair (including Ranges and Cooktops) 0 11-12-2007 06:47 PM
GE Oven won't light stallters Oven Repair (including Ranges and Cooktops) 1 11-05-2007 06:50 PM
Gas Oven Won't Light esjay Oven Repair (including Ranges and Cooktops) 0 09-26-2007 05:51 PM
oven will not light keith Oven Repair (including Ranges and Cooktops) 0 09-25-2007 06:32 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
