| » Jenn-Air oven JGR8875QDS beeps,enters 00:00 HOLD, turns off |
Model Number: JGR8875QDS Brand: Jenn-Air Age: 5 - 10 years
I have a Jenn-Air oven model JGR8875QDS. First, it started to beep and would enter "Cook and Hold" mode by itself. The oven was not in use at the time. When it enters this mode none of the buttons work except for "Cancel" which beeps when pressed and returns you to the time of day clock but still none of the other buttons work. Pressing "Cancel" and "Cook and Hold" at the same time will restore functionality to ALL buttons on the keypad. At this point, you can even turn the oven on & set the temperature. The oven will begin to heat but within a few minutes it will flash 00:00 HOLD again (Cook and HOLD mode) and eventually (within a couple minutes) the oven will turn off and you will be back to the time of day clock.
I tried replacing the clock control unit but the problem is still the same. Any ideas? It would seem odd if the issue is the touchpad itself since pressing "Cancel" and "Cook and Hold" restores the buttons functionality temporarily. Is it possible that the replacement clock control I received is also faulty? Thanks, Jason Ads By Google Related Models |
| Display Modes | |
| Jenn-Air range turns itself off for no reason, beeps continually | ljc2 | Oven Repair (including Ranges and Cooktops) | 0 | 11-02-2011 06:19 PM |
| Kenmore Oasis Turns on by itself/beeps/arbitrarily changes settings | kingirp | Washer Repair | 1 | 02-16-2011 06:53 AM |
| Jenn-Air Wall Oven - Beeps with Code 'FC' | Janmon | Oven Repair (including Ranges and Cooktops) | 1 | 10-29-2010 03:14 PM |
| Whirlpool Double Builtin Oven LED OUT, TURNS ON FOR ABOUT 10 SECONDS THEN BEEPS | bearingrnwd | Oven Repair (including Ranges and Cooktops) | 0 | 12-20-2009 07:17 PM |
| F4/F3 Error Sensor; Turns on automatically and beeps | jnchay | Microwave Repair | 0 | 05-03-2009 09:31 AM |
