Discuss
Jenn-Air W30400B Oven won't heat up
 in
Hi, I have replaced the clock on the oven twice and it is working fine still. Recently, however the oven
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn-Air W30400B Oven won't heat up
  #1 (permalink)
Old 09-12-2009, 03:33 PM
Junior Member
1coolguy is on a distinguished road
Default Jenn-Air W30400B Oven won't heat up
Model Number: W30400B   Brand: Jenn-Air   Age: More than 10 years
Hi, I have replaced the clock on the oven twice and it is working fine still. Recently, however the oven would not heat up in bake mode, but when turning it to broil, the broiler element would come on and I could switch it to bake and the temp would stablize. Now the broiler will not come on. When in broil mode, the fan comes on only. I disconnected the clock and when re-connecting it I get the F- error code. I do not get any other codes. I suspect it may be the relay board but though I would ask before sinking another $150 into this oven. I should give up and dump it, but I like the oven, bakes well and still looks good. Any advice?
Thanks in advance for your time.
Ads By Google
Related Models
Jenn-Air W30400B Walloven - S/c Ele
Jenn-Air W30400BC Walloven - S/c Ele
Jenn-Air W30400P Walloven - S/c Ele
Jenn-Air W30400PC Walloven - S/c Ele
Jenn-Air W30400PF Walloven - S/c Ele
Jenn-Air W30400PG Walloven - S/c Ele
Jenn-Air W30400PK Walloven - S/c Ele
Jenn-Air W30400PR Walloven - S/c Ele
Jenn-Air W30400PU Walloven - S/c Ele
Jenn-Air W30400W Walloven - S/c Ele
Jenn-Air W30400WC Walloven - S/c Ele
Frigidaire WA24F4DTFB Gib(v4) / Top Load Washer
Frigidaire WA24F4WTFA Gib(v2) / Automatic Washer
Frigidaire WA24F4WTFB Gib(v3) / Top Load Washer
Frigidaire WA24P2DTFB Gib(v2) / Top Load Washer
Frigidaire WA24P2DVFA Gib(v2) / Top Load Washer
Frigidaire WA24P2WSFA Gib(v1)
Frigidaire WA24P2WSFB Gib(v2)
Frigidaire WA24P2WTFA Gib(v1) / Automatic Washer
Frigidaire WA24P2WTFB Gib(v1) / Top Load Washer
Frigidaire WA24P2WVFA Gib(v1) / Top Load Washer
Frigidaire WA24P2WVMB Gib(v1) / 24 " Washer
Frigidaire WA24P2WYMA Gib(v1) / 24 " Washer
Frigidaire WA24P2WYMB Gib(v1) / 24 " Washer
Frigidaire WA24P2WYMC Gib(v1) / 24 " Washer
Frigidaire WA27F2WAFA Gib(v2) / 27 " Top Load Washer
Frigidaire WA27F2WAFB Gib(v2) / 27 " Top Load Washer
Frigidaire WA27F2WXFA Gib(v2) / 27 " Top Load Washer
Frigidaire WA27F2WXFB Gib(v2) / 27 " Top Load Washer
Frigidaire WA27F4WAFA Gib(v1) / 27 " Top Load Washer
Frigidaire WA27F4WAFB Gib(v1) / 27 " Top Load Washer
Frigidaire WA27F4WXFA Gib(v1) / 27 " Top Load Washer
Frigidaire WA27F4WXFB Gib(v1) / 27 " Top Load Washer
Frigidaire WA27M4WAFA Gib(v2) / 27 " Top Load Washer
Frigidaire WA27M4WAFB Gib(v2) / 27 " Top Load Washer
Frigidaire WA27M4WXFA Gib(v2) / 27 " Top Load Washer
Frigidaire WA27M4WXFB Gib(v2) / 27 " Top Load Washer
Frigidaire WA27M6WXFA Gib(v1) / 27 " Top Load Washer
Frigidaire WA27M6WXFB Gib(v1) / 27 " Top Load Washer
Frigidaire WA27M8WAFA Gib(v1) / 27 " Top Load Washer
Frigidaire WA27M8WAFB Gib(v1) / 27 " Top Load Washer
Frigidaire WA27S1WAFA Gib(v1) / 27 " Top Load Washer
Frigidaire WA27S1WAFB Gib(v1) / 27 " Top Load Washer
Frigidaire WA27S1WXFA Gib(v1) / 27 " Top Load Washer
Frigidaire WA27S1WXFB Gib(v1) / 27 " Top Load Washer
Frigidaire WA28D3WSFA Gib(v3)
Frigidaire WA28D4WSFA Gib(v4)
Frigidaire WA28D4WTFA Gib(v1) / Automatic Washer
Frigidaire WA28D5WSFA Gib(v5)
Frigidaire WA28D7WSFA Gib(v6)
Frigidaire WA28F2DTFB Gib(v5) / Top Load Washer
Frigidaire WA28F2WTFA Gib(v5) / Automatic Washer
Frigidaire WA28F2WTFB Gib(v1) / Top Load Washer
Frigidaire WA28F2WTFC Gib(v1) / Top Load Washer
Frigidaire WA28M2DTFB Gib(v6) / Top Load Washer
Frigidaire WA28M2WTFA Gib(v4) / Automatic Washer
Frigidaire WA28M2WTFB Gib(v2) / Top Load Washer
Frigidaire WA28M2WTFC Gib(v2) / Top Load Washer
Frigidaire WA28M4DTFB Gib(v7) / Top Load Washer
Frigidaire WA28M4WTFA Gib(v3) / Automatic Washer
Frigidaire WA28M4WTFB Gib(v3) / Top Load Washer
Frigidaire WA28M4WTFC Gib(v3) / Top Load Washer
Frigidaire WA28M4YTFB Gib(v9) / Top Load Washer
Frigidaire WA28M6DTFB Gib(v8) / Top Load Washer
Frigidaire WA28M6WTFA Gib(v2) / Automatic Washer
Frigidaire WA28M6WTFB Gib(v4) / Top Load Washer
Frigidaire WA28M6WTFC Gib(v4) / Top Load Washer
Frigidaire WA28S2WSFA Gib(v7)
Frigidaire WA3900AWL1 Frg(v4) / 27 " Washer
Frigidaire WA3900AWL2 Frg(v4) / 27 " Washer
Frigidaire WA3900AWW1 Frg(v3) / 27 " Washer
Frigidaire WA3900AWW2 Frg(v3) / 27 " Washer
Frigidaire WA3900AWW3 Frg(v1) / 27 " Washer
Frigidaire WA4720RW1 Frg(v1) / 27 " Washer
Frigidaire WA4720RW2 Frg(v1) / 27 " Washer
Frigidaire WA4900ADD1 Frg(v2) / 27 " Washer
Frigidaire WA4900ADD2 Frg(v2) / 27 " Washer
Frigidaire WA4900ADD3 Frg(v2) / 27 " Washer
Frigidaire WA4900AWW1 Frg(v1) / 27 " Washer
Frigidaire WA4900AWW2 Frg(v1) / 27 " Washer
Frigidaire WA4900AWW3 Frg(v3) / 27 " Washer
Frigidaire WA4900RW1 Frg(v1) / 27 " Washer
Frigidaire WA5800ADD1 Frg(v4) / 27 " Washer
Frigidaire WA5800ADD2 Frg(v4) / 27 " Washer
Frigidaire WA5800ADD3 Frg(v1) / 27 " Washer
Frigidaire WA5800AWW1 Frg(v3) / 27 " Washer
Frigidaire WA5800AWW2 Frg(v3) / 27 " Washer
Frigidaire WA5800AWW3 Frg(v2) / 27 " Washer
Frigidaire WA5800RW1 Frg(v2) / 27 " Washer
Frigidaire WA5820RW1 Frg(v1) / 27 " Washer
Frigidaire WA5820RW2 Frg(v1) / 27 " Washer
Frigidaire WA6500ADD1 Frg(v2) / 27 " Washer
Frigidaire WA6500ADD2 Frg(v2) / 27 " Washer
Frigidaire WA6500ADD3 Frg(v3) / 27 " Washer
Frigidaire WA6500AWW1 Frg(v1) / 27 " Washer
Frigidaire WA6500AWW2 Frg(v1) / 27 " Washer
Frigidaire WA6500AWW3 Frg(v4) / 27 " Washer
Frigidaire WA6520AL1 Frg(v2) / 27 " Washer
Frigidaire WA6520AL2 Frg(v2) / 27 " Washer
Frigidaire WA6520AW1 Frg(v1) / 27 " Washer
Frigidaire WA6520AW2 Frg(v1) / 27 " Washer
Frigidaire WA6620RW1 Frg(v1) / 27 " Washer
Frigidaire WA6620RW2 Frg(v1) / 27 " Washer
Frigidaire WA6900RW1 Frg(v3) / 27 " Washer
Frigidaire WA7200ADD1 Frg(v2) / 27 " Washer
Frigidaire WA7200ADD2 Frg(v2) / 27 " Washer
Frigidaire WA7200ADD3 Frg(v1) / 27 " Washer
Frigidaire WA7200AWW1 Frg(v1) / 27 " Washer
Frigidaire WA7200AWW2 Frg(v1) / 27 " Washer
Frigidaire WA7200AWW3 Frg(v2) / 27 " Washer
Frigidaire WA7400PW0 Frg(v1) / 27 " Washer
Frigidaire WA7400PW1 Frg(v1) / 27 " Washer
Frigidaire WA7400PW2 Frg(v2) / 27 " Washer
Frigidaire WA8600PW0 Frg(v1) / 27 " Washer
Frigidaire WA8600PW1 Frg(v1) / 27 " Washer
Frigidaire WA8600PW2 Frg(v2) / 27 " Washer
Frigidaire WA8800PW0 Frg(v1) / 27 " Washer
Frigidaire WA8800PW1 Frg(v1) / 27 " Washer
Frigidaire WA8800PW2 Frg(v2) / 27 " Washer
Frigidaire WAA053M7A1 White Westinghouse Air Conditioner
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas Jenn-Air oven will not heat up? Tony3 Oven Repair (including Ranges and Cooktops) 2 12-18-2009 08:28 AM
Jenn Air oven won't heat POtt Oven Repair (including Ranges and Cooktops) 1 10-27-2009 04:39 AM
Jenn-Air Wall Oven Won't Heat EORR1976 Oven Repair (including Ranges and Cooktops) 0 07-19-2009 08:58 PM
Can't find manual for Jenn-Air W30400B printie General Talk 2 03-14-2009 05:32 PM
Jenn Air gas oven won't heat kkenaga Oven Repair (including Ranges and Cooktops) 1 11-20-2007 12:45 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
