Discuss
Need to replace left hinge on wall oven
 in
We need to replace the left hinge on a Hotpoint wall oven. After removing the door, the hinges are in
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Need to replace left hinge on wall oven
  #1 (permalink)
Old 06-11-2012, 10:38 AM
Junior Member
nana67502@yahoo.com is on a distinguished road
Default Need to replace left hinge on wall oven
Brand: Hotpoint   Age: More than 10 years
We need to replace the left hinge on a Hotpoint wall oven. After removing the door, the hinges are in the body of the oven...not in the door. Is there a way to remove the hinges without disassembling the whole oven?
Ads By Google
  #2 (permalink)
Old 06-11-2012, 04:02 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
What is the complete model number of the oven?
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 06-11-2012, 04:43 PM
Junior Member
Simon,
I didn't find a model number, but the serial number is SG 42252 and the Cat. number is 10 RL 40G. It is a Hotpoint, wall unit.
Thanks,
Linda
  #4 (permalink)
Old 06-11-2012, 06:09 PM
Expert
Default
For any research I'd need the model number. Look for the tag around the oven door cavity.
Thank you.
Simon.
__________________
  #5 (permalink)
Old 06-11-2012, 08:26 PM
Junior Member
Default
Simon,
I'll look again tomorrow and try to find the model number.
Thanks!
Linda
  #6 (permalink)
Old 06-13-2012, 08:49 AM
Junior Member
Default Oven Repair
Simon,
I looked at the oven and didn't find anything that specified model number. Besides the serial and catalogue number, there was a number 327867, but I don't think it was a model number.
I took a picture of the oven and the tag with the numbers, but don't know how to attach them.
Linda
  #7 (permalink)
Old 06-13-2012, 01:36 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Linda,
The Model Number Locator should help you.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #8 (permalink)
Old 06-19-2012, 09:34 AM
Junior Member
Default
Gene,
I found the metal tag on the right side of the oven, but it only lists the numbers I have previously stated. It doesn't give a model number. This house was built in 1967, so this is a very old, Copper, Hotpoint, wall oven. The only numbers are Serial - SG 42252, Cat. number - 10RL 40G. This must be the model number even though it doesn't call it that. We pulled the oven out of the wall, hoping to be able to get to the hinge assembly, but there are side panels that will need to be taken off. I am assuming we will have to take the oven clear out in order to get to the hinge assembly, and even then I am not sure we will be able to purchase the correct hinge. I am worried that we might just have to call a repairman, which will be expensive.
  #9 (permalink)
Old 06-19-2012, 12:29 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Linda,
Unfortunately, we are not able to help you without valid model number.
__________________
  #10 (permalink)
Old 06-25-2012, 08:58 AM
Junior Member
Default Oven hinge
Gene,
We pulled the oven completely out of the wall, removed the side panels and found there was a broken spring. We purchased two new springs and installed them. The oven door works great!
Thanks for your help.
Linda
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Hinge adjustment on GE Monogram wall oven ZET1038? mwinton Oven Repair (including Ranges and Cooktops) 0 03-30-2012 01:10 PM
replace oven door hinge!! tbandme Oven Repair (including Ranges and Cooktops) 15 11-28-2010 10:07 PM
replace oven door hinge brcmarzette Oven Repair (including Ranges and Cooktops) 0 11-22-2010 09:50 AM
Oven hinge replace Fla Geezer Oven Repair (including Ranges and Cooktops) 0 11-25-2009 08:23 PM
Front Loader: How to reverse door swing / right hinge to left hinge Three3walkers Washer Repair 3 05-31-2009 04:14 PM
