| » F2 codes on whirlpool oven |
Model Number: RBD305PDQ7 Brand: Whirlpool Age: More than 10 years
On my Whirlpool double oven I sometimes have an F2 code. Other times it beeps and the screen in blank. I searched on the internet and read for an F2 codes that I needed to replace the oven temperature sensor. My husband replaced it and I'm still have problems with the blank control panel or F2 code. If there is an F2 code, I can push start and the clock will come on and the oven will work. Other times, when the screen is blank, I can't get the oven to work. Any suggestions on what it would be??
Replacement parts for Whirlpool RBD305PDQ7 ELECTRIC OVEN | AppliancePartsPros.com See the attachment for the tech sheet. I could not find one for a PDQ7 so the tech sheet is for a PDQ6, the closest I could find. Odds are high that it will apply to your unit. It shows F2 as a keypad error not a oven sensor error. I would try the following. Connector Cleaning / Checking Unplug the unit Open it up Remove the ribbon cable from the keypad to the control board at the control board. Clean the edge connector. If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive. If it has a connector on it use electronics contact cleaner or isopropyl alcohol. Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here. Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates. Reconnect everything and give it a try.
__________________
| Display Modes | |
| Whirlpool Double Oven Error Codes E1 & F5 | mlindsey3418 | Oven Repair (including Ranges and Cooktops) | 0 | 03-23-2011 06:15 AM |
| Whirlpool oven fault codes E3 and F1 | txtrisha | Oven Repair (including Ranges and Cooktops) | 0 | 02-08-2011 07:51 PM |
| Whirlpool Electic oven error codes | fcarrelli | Oven Repair (including Ranges and Cooktops) | 9 | 09-23-2010 06:20 AM |
| Whirlpool Double Oven Error Codes | alaucks | Oven Repair (including Ranges and Cooktops) | 2 | 01-15-2009 09:31 PM |
| Error Codes Whirlpool Oven | brummel | Oven Repair (including Ranges and Cooktops) | 0 | 08-25-2008 12:27 PM |
