| » Frigidaire Gallery Oven will not start, broiler and burners work fine |
Model Number: GLGF376DCC Brand: Frigidaire Age: 5 - 10 years
Hello,
Last week I noticed that my oven would not fire. I was taken by surprise as I've not had any problems with it. I tapped on the control panel, tried locking and unlocking the door, swore at it, and for some odd reason it began to work once again. This only lasted until last night. It quit again, and no banging or words can make it work. The broiler works fine, as does the burners on the top. I am stumped as to why or what caused it to stop. Any ideas or steps to isolate the problem would be greatly appreciated... Thank you. Ads By Google Related Models |
Remove the oven floor and the flame spreader. Check if the igniter glows while the control calls for Bake. If it does then, most likely, the igniter is too weak to open the gas valve and has to be replaced.
If it does not glow, check for 120 VAC to the igniter while the control calls for Bake and post the results. - The igniter Part number: 316489400 Here are the breakdown diagrams and Replacement parts for Frigidaire GLGF376DCC Frigidaire/range | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Hey Gene,
It measures 119v at the connector in the oven. The wires are frayed and exposed but not shorting the element. Thank you for assisting me with this. Does this mean the igniter has failed? Thanks, Scott |
Hi Scott,
The voltage reading is correct. So, the igniter is the culprit. Gene.
__________________
Hey Gene,
First of all - THANK YOU!!! I got the part in today (shock because I ordered it yesterday from APP standard shipping) and was able to replace it with no problem. Was rather interesting that after I pulled the rear panel I discovered the connector was under the unit and not behind the panel. Also, the part that arrived did not have a full shield over the element/igniter yet I assumed it would be fine underneath all the metal and such. Should I be concerned that the igniter was not completely covered by a shield? Anyway the oven works like a champ and I have you to thank. If you have a PayPal account let me know and I will donate a few dollars your way for your kind assistance! This is probably the 3rd appliance you have assisted me with. Is Frigidaire a good brand as they all have started to develop a problem after they turned six years old? Scott |
You are welcome Scott. I'm glad you were able to fix it. I don't think you have to worry about the new igniter. It should last a few more years.
Six years for any appliances is a time when they start to give a problems. It's pretty normal. Gene.
__________________
| Display Modes | |
| GE Profile gas oven doesnt work broiler and top work fine | repondtomehere | Oven Repair (including Ranges and Cooktops) | 3 | 05-01-2011 11:45 AM |
| top burners work oven and broiler does not | kevin121 | Oven Repair (including Ranges and Cooktops) | 1 | 11-02-2010 09:56 AM |
| oven won't work but burners fine | Stan Kutnicki | Oven Repair (including Ranges and Cooktops) | 7 | 10-04-2009 05:38 PM |
| Oven heats to 100 degrees only. Broiler and top burners work fine. | Casseopia | Oven Repair (including Ranges and Cooktops) | 1 | 03-24-2009 05:34 PM |
| Oven won't work, but the broiler and top fine | Eric Schuetz | Oven Repair (including Ranges and Cooktops) | 1 | 11-28-2008 04:38 AM |
