| » How To Check Continuity With Ohmmeter |
LinkBack (4) | Thread Tools | Search this Thread | Display Modes |
Greetings...
Wirlpool #ler4634eq2... Everthing runs - except there is no heat... I replaced the heating element - did not fix the problem.... Pruchased a multi-meter today so I don't waste any more money on replacing parts I do not need... Problem is what to set the meter on...everything I read says rx1...the meter I have does not have a Rx1...under the OHM's dail it has X1k and X10...Help???...which do I use??.. And, what parts should I check??..thermostat, thermal cut off, thermal fuse??...am I on the right track here.. Thanks so much for your help... |
Hi George,
Set the meter range to the X10 scale. You have to check a few parts as listed in one of our previous posts: dryer willnotheat & timer wont turn off The reference numbers can be different, but here are the breakdown diagrams and Replacement parts for WHIRLPOOL LER4634EQ2 | AppliancePartsPros.com, the model number you posted. Gene.
__________________
Professional appliance repair in Orange County, California. |
Quote:
The article in one of our previous posts will explain in details How To Check The Gas Valve Coils.
__________________
hi there Gene the problrm that I have is my electric dryer Whirp is not working I checked the electric panel amd also the belt seems fine My guess is that the motor is shock my drfyer is 5 years old and I do not not how 2 use a ohmmeter or multimmeter ( I have something with these labes DCV< ACV< BATT< MA< OMEGA SIGN < AND TWO SYMBOLS ? so I am really confused how to find out the problem by the way the model is LEQ9598LWO
__________________
Quote:
What is the complete model number of the oven? Gene.
__________________
LinkBack to this Thread: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/4810-how-check-continuity-ohmmeter.html
| Posted By | For | Type | Date |
| Bosch Dishwasher Control Module (266746) | ApplianceJournal.com | This thread | Refback | 03-04-2008 05:17 PM |
| I need a Maytag man...or a Whirlpool man actually - Maryland Shooters | This thread | Refback | 02-04-2008 06:22 PM |
| I need a Maytag man...or a Whirlpool man actually - Maryland Shooters | This thread | Refback | 02-04-2008 06:15 PM |
| Digg - How To Check Continuity With Ohmmeter | This thread | Refback | 02-04-2008 02:04 AM |
| Display Modes | |
| How to Check Washer Motor & Capacitor | mickey11 | Washer Repair | 2 | 06-15-2008 10:09 AM |
| To check defrost heater | don419 | Refrigerator & Freezer Repair | 2 | 02-26-2008 09:51 PM |
| Check Valve for Kitchenaid Dishwasher | mark.sapienza@acco.com | Dishwasher Repair | 3 | 01-01-2008 01:49 PM |
| how to check thermo fuse and thermostat | lilphil | Dryer Repair | 0 | 11-20-2007 08:43 AM |
| How can I check the relay and/or cap | frepair | Refrigerator & Freezer Repair | 1 | 10-18-2007 08:37 PM |
