Discuss
How To Check Continuity With Ohmmeter
 in
If you can post a pictures of the heating coil and the control panel - it might help for more accurate
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » How To Check Continuity With Ohmmeter
LinkBack (4) Thread Tools Search this Thread Display Modes
  #11 (permalink)
Old 03-19-2008, 03:50 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
If you can post a pictures of the heating coil and the control panel - it might help for more accurate advise.
__________________
  #12 (permalink)
Old 03-19-2008, 06:18 PM
thiendia thiendia is offline
Junior Member
thiendia is on a distinguished road
Thumbs up
Quote:
Originally Posted by Gene View Post
Hi thiendia,
The problem with your dryer caused by a bad gas valve coils . No doubt about it.
- The part number for the coil kit is AP3094251
Hi Gene,
The part came! Super fast!
I replaced it and the dryer worked very well!
Thanks a million times for your help!
  #13 (permalink)
Old 03-19-2008, 07:42 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm glad you were able to fix it.
__________________
  #14 (permalink)
Old 07-16-2008, 01:59 PM
w2002s w2002s is offline
Junior Member
w2002s is on a distinguished road
Default Wire Hardness
how to check the wires in a wall oven for shorts(frigidare FEB24S5ABB)
  #15 (permalink)
Old 10-24-2008, 03:49 PM
brianosmi brianosmi is offline
Junior Member
brianosmi is on a distinguished road
Default
Great post on checking continuity - I have always had a hard time understanding how to properly use one of these meters so I thank you for taking the time to put this together.
Much appreciated,
__________________
Brian
  #16 (permalink)
Old 12-27-2008, 02:06 PM
Davidr Davidr is offline
Junior Member
Davidr is on a distinguished road
Default Dryer does not Heat (Whirlpool)
I have replaced the Heating Element and Thermostate next to the heating element and it still does not heat Please HELP
  #17 (permalink)
Old 12-27-2008, 02:42 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Davidr,
Can you be more specific on the problem? What is the complete model number of the unit?
__________________
  #18 (permalink)
Old 01-03-2009, 04:01 PM
heloego heloego is offline
Junior Member
heloego is on a distinguished road
Default Whirlpool Model LER4634JQ1 Turns/Blows, but no Heat
Electric Dryer.
I've just performed the following Checks:
Element p/n 279838/3403585 (Heating Inlet) ...Good Continuity @ 11.4 ohms (Schematic says should be 7.8 to 11.8 ohms)
Voltage...Zero Volts across terminals, 120v to Ground (Element housing).
Thermal Cut-off p/n 3977393 (Heating Inlet, Top) ...Good Continuity
Voltage
Hi-Limit Thermostat p/n 3977767 (Heating Inlet, at Element) ...Good Continuity
Voltage...Zero Volts across terminals, 120v to Ground.
Thermal Fuse p/n 3392519 (Exhaust Outlet) ...Good Continuity
Internal Bias Thermostat p/n 3387134 (Exhaust Outlet) ...Good Continuity
Voltage...Zero Volts across Large terminals, 120v to Ground. Small Terminals Infinity/OPEN.
Continuity looks good, but I'm not getting 240v at any point.
Found the Wiring Schematic in the upper compartment containing the Start Switch and Timer.
According to the Continuity Chart at the top of the Schematic, with the Timer set to "Auto-Reg/High" I should be reading an open circuit between BK-BU and BU-V. I read a closed circuit between BK and BU (as I said, the circuit read closed). The next column contradicts it by saying the BK-BU circuit should be closed. I get the same results with the Timer in the "Timed-Reg/High" position.
HUH???
Am I reading the chart wrong?
My understanding of the caption "BK-BU-V" is: BK(Black) to BU(Blue), BU to V(Violet).
Is this correct, or am I missing something here?
I maintain a $2.5 million helicopter, and regularly use Schematics, but this Whirlpool Continuity Chart has me confused due to the above.
Or do I in fact have a bad Timer?
  #19 (permalink)
Old 01-04-2009, 01:51 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by heloego View Post
...Element p/n 279838/3403585 (Heating Inlet) Voltage...Zero Volts across terminals, 120v to Ground (Element housing)...
Did you disconnect the wires from the heating element prior to the test?
Did you read 120VAC between each wire to ground or only one of them? If only one then which one? The dryer should run at time of this test.
Check the timer for continuity between the "BK" & "R" terminals at any cycle (the wires have to be removed).
Be careful not to electrocute yourself.
__________________
  #20 (permalink)
Old 04-03-2009, 01:02 PM
Ernie Shipley Ernie Shipley is offline
Junior Member
Ernie Shipley is on a distinguished road
Default checking ohm meter readings
This article answered my question on test results with my ohm meter ,great site,great article for those of us who only use ohm meters occasionaly. thanks,Ernie
Reply
LinkBacks (?)
LinkBack to this Thread: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/4810-how-check-continuity-ohmmeter.html
Posted By For Type Date
Bosch Dishwasher Control Module (266746) | ApplianceJournal.com This thread Refback 03-04-2008 05:17 PM
I need a Maytag man...or a Whirlpool man actually - Maryland Shooters This thread Refback 02-04-2008 06:22 PM
I need a Maytag man...or a Whirlpool man actually - Maryland Shooters This thread Refback 02-04-2008 06:15 PM
Digg - How To Check Continuity With Ohmmeter This thread Refback 02-04-2008 02:04 AM
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How to Check Washer Motor & Capacitor mickey11 Washer Repair 2 06-15-2008 10:09 AM
To check defrost heater don419 Refrigerator & Freezer Repair 2 02-26-2008 09:51 PM
Check Valve for Kitchenaid Dishwasher mark.sapienza@acco.com Dishwasher Repair 3 01-01-2008 01:49 PM
how to check thermo fuse and thermostat lilphil Dryer Repair 0 11-20-2007 08:43 AM
How can I check the relay and/or cap frepair Refrigerator & Freezer Repair 1 10-18-2007 08:37 PM
