| » How To Check Continuity With Ohmmeter |
Ads By Google
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
You are welcome Todd. Keep us posted.
__________________
I was told to test the control board to see if it sends 120 volts on the bake relay. I read the "how to use a multi meter" but i'm still unsure how to test this. I have a frigidaire pleb30s8ccc wall oven 220 plug. Do I leave the unit plugged in to do this and what to points would I connect with the meter?
Hello,
What seems to be a problem with the oven? Gene.
__________________
The first thing I would do is check the thermals fuse (#119 at the diagram) for continuity. This fuse can be reset by pushing the red button in the center of the fuse.
Here are the breakdown diagrams and Parts for Frigidaire PLEB30S8CCC Wall Oven - AppliancePartsPros.com Gene.
__________________
Does it in Broil mode? If it does and the problem is only Bake, then turn of the power to the oven and pull out the Bake heating element. Remove the wires from the heating element and check the element for continuity.
If it is open, replace the Bake heating element. If it shows continuity, then the problem is a bad control board. You don't have to do any more tests to prove it. This statement is correct only if Broil works. - The Bake heating element Part number: 318255006 - The oven control board Part number: 318010700 Gene.
__________________
| Display Modes | |
LinkBack to this Thread: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/4810-how-check-continuity-ohmmeter.html
| Posted By | For | Type | Date | |
| Bosch Dishwasher Control Module (266746) | ApplianceJournal.com | This thread | Refback | 03-04-2008 04:17 PM | |
| I need a Maytag man...or a Whirlpool man actually - Maryland Shooters | This thread | Refback | 02-04-2008 05:22 PM | |
| I need a Maytag man...or a Whirlpool man actually - Maryland Shooters | This thread | Refback | 02-04-2008 05:15 PM | |
| Digg - How To Check Continuity With Ohmmeter | This thread | Refback | 02-04-2008 01:04 AM | |
| How To Check Washer Parts For Continuity | Admin / APP Team | Washer Repair | 7 | 02-26-2012 11:51 AM |
| How To Check Dryer Parts For Continuity | Admin / APP Team | Dryer Repair | 32 | 03-14-2009 01:18 PM |
| How To Check Dishwasher Parts For Continuity | Admin / APP Team | Dishwasher Repair | 1 | 12-01-2008 08:32 PM |
| How To Check Refrigerator Parts For Continuity | Admin / APP Team | Refrigerator & Freezer Repair | 11 | 10-13-2008 05:21 PM |
