Discuss
Frigidaire Electric Oven/Range Problem
 in
A little under a year ago, the oven/range stopped heating. My wife was in the middle of cooking supper and
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Frigidaire Electric Oven/Range Problem
  #1 (permalink)
Old 06-09-2012, 07:04 AM
Junior Member
stevo7fgg is on a distinguished road
Question Frigidaire Electric Oven/Range Problem
Model Number: FEFL79ECE   Brand: Frigidaire   Age: 1 - 5 years
A little under a year ago, the oven/range stopped heating. My wife was in the middle of cooking supper and using both the range and oven when both stopped heating. The display/speed bake fan/timer all still worked - in fact, everything appears to be working, but nothing will heat up at all. I read some posts on here to try to diagnose the problem, and after a couple of days researching was going to use a multimeter for the first time to try to diagnose. I verified the voltage at the outlet, and then plugged it in and turned on one of the burners to check continuity, but it worked! Everything worked as if nothing had happened and continued to do so until last night when it did the same thing. This morning it is working again. This time it was left plugged in and just rechecked it this morning to find it working. What could be causing this? Thanks!
Related Models
Frigidaire FEFL79ECE Frigidaire/range
Frigidaire FEFL79FCA Frigidaire/electric Range
Frigidaire FEFL79FCB Frigidaire/range
Frigidaire FEFL79FCC Frigidaire/range
Frigidaire FEFL79GBA Frigidaire/range
Frigidaire FEFL79GCA Frigidaire/range
Frigidaire FEFL79GQA Frigidaire/range
Frigidaire FEFL79GSA Frigidaire/range
Frigidaire FEFL79HBA ELECTRIC RANGE
Frigidaire FEFL79HBB ELECTRIC RANGE
Frigidaire FEFL79HCA ELECTRIC RANGE
Frigidaire FEFL79HCB ELECTRIC RANGE
Frigidaire FEFL79HQA ELECTRIC RANGE
Frigidaire FEFL79HQB ELECTRIC RANGE
Frigidaire FEFL79HSA ELECTRIC RANGE
Frigidaire FEFL79HSB ELECTRIC RANGE
Frigidaire FEFL79JBA ELECTRIC RANGE
Frigidaire FEFL79JBB ELECTRIC RANGE
Frigidaire FEFL79JCA ELECTRIC RANGE
Frigidaire FEFL79JCB ELECTRIC RANGE
Frigidaire FEFL79JCC ELECTRIC RANGE
Frigidaire FEFL79JCE ELECTRIC RANGE
Frigidaire FEFL79JQA ELECTRIC RANGE
Frigidaire FEFL79JQB ELECTRIC RANGE
Frigidaire FEFL79JSA ELECTRIC RANGE
Frigidaire FEFL79JSB ELECTRIC RANGE
Frigidaire FEFL88ABA Frigidaire/electric Range
Frigidaire FEFL88ABB Frigidaire/electric Range
Frigidaire FEFL88ABC Frigidaire/electric Range
Frigidaire FEFL88ACA Frigidaire/electric Range
Frigidaire FEFL88ACB Frigidaire/electric Range
Frigidaire FEFL88ACC Frigidaire/electric Range
Frigidaire FEFL88ASA Frigidaire/electric Range
Frigidaire FEFL88ASB Frigidaire/electric Range
Frigidaire FEFL88ASC Frigidaire/electric Range
Frigidaire FEFL89CCA Frigidaire/electric Range
Frigidaire FEFL89CCB Frigidaire/electric Range
Frigidaire FEFLM600DQA Frigidaire/electric Range
Frigidaire FEFLM600DSA Frigidaire/electric Range
Frigidaire FEFLM605DBB Frigidaire/electric Range
Frigidaire FEFLM605DBD Frigidaire/electric Range
Frigidaire FEFLM605DCB Frigidaire/electric Range
Frigidaire FEFLM605DCC Frigidaire/electric Range
Frigidaire FEFLM605DCD Frigidaire/range
Frigidaire FEFLM605DCE Frigidaire/electric Range
Frigidaire FEFLM605DCG Frigidaire/range
Frigidaire FEFLM605DCH Frigidaire/range
Frigidaire FEFLM605DCJ Frigidaire/range
Frigidaire FEFLM605DQB Frigidaire/electric Range
Frigidaire FEFLM605DQD Frigidaire/electric Range
Frigidaire FEFLM605DSB Frigidaire/electric Range
Frigidaire FEFLM605DSD Frigidaire/electric Range
Frigidaire FEFLM66EBA Frigidaire/electric Range
Frigidaire FEFLM66EBB Frigidaire/electric Range
Frigidaire FEFLM66ESA Frigidaire/electric Range
Frigidaire FEFLM66ESB Frigidaire/electric Range
Frigidaire FEFLM66ESC Frigidaire/range
Frigidaire FEFLMC55FCA Frigidaire/electric Range
Frigidaire FEFLMC55FCB Frigidaire/range
Frigidaire FEFLMC55FCC ELECTRIC RANGE
Frigidaire FEFLMC55GCA ELECTRIC RANGE
Frigidaire FEFLMC55GCC ELECTRIC RANGE
Frigidaire FEFLMC55HCA ELECTRIC RANGE
Frigidaire FEFLMC55HCC ELECTRIC RANGE
Frigidaire FEFLMC55HCE ELECTRIC RANGE
Frigidaire FEFLZ87GCA ELECTRIC RANGE
Frigidaire FEFLZ87GCB ELECTRIC RANGE
Frigidaire FEFLZ87GCC ELECTRIC RANGE
Frigidaire FEFLZ87GCD ELECTRIC RANGE
Frigidaire FEFS52DQA Frigidaire/electric Range
Frigidaire FEFS52DQB Frigidaire/range
Frigidaire FEFS52DQC Frigidaire/range
Frigidaire FEFS52DQD Frigidaire/range
Frigidaire FEFS52DSA Frigidaire/electric Range
Frigidaire FEFS52DSB Frigidaire/range
Frigidaire FEFS52DSC Frigidaire/range
Frigidaire FEFS52DSD Frigidaire/range
Frigidaire FEFS66DQA Frigidaire/electric Range
Frigidaire FEFS66DQB Frigidaire/range
Frigidaire FEFS66DQC Frigidaire/range
Frigidaire FEFS66DQD Frigidaire/range
Frigidaire FEFS66DQF Frigidaire/range
Frigidaire FEFS66DQG Frigidaire/range
Frigidaire FEFS66DQH Frigidaire/range
Frigidaire FEFS66DQJ Frigidaire/range
Frigidaire FEFS66DSA Frigidaire/electric Range
Frigidaire FEFS66DSB Frigidaire/range
Frigidaire FEFS66DSC Frigidaire/range
Frigidaire FEFS66DSD Frigidaire/range
Frigidaire FEFS66DSF Frigidaire/range
Frigidaire FEFS66DSG Frigidaire/range
Frigidaire FEFS66DSH Frigidaire/range
Frigidaire FEFS66DSJ Frigidaire/range
Frigidaire FEFS68CJBA Frigidaire/electric Range
Frigidaire FEFS68CJBB Frigidaire/electric Range
Frigidaire FEFS68CJBC Frigidaire/electric Range
Frigidaire FEFS68CJSA Frigidaire/electric Range
Frigidaire FEFS68CJSB Frigidaire/electric Range
Frigidaire FEFS68CJSC Frigidaire/electric Range
Frigidaire FEFS68CJTA Frigidaire/electric Range
Frigidaire FEFS68CJTB Frigidaire/electric Range
Frigidaire FEFS68CJTC Frigidaire/electric Range
Frigidaire FEGB24S5ASE GAS OVEN
Roper FEP210EN0 ELECTRIC RANGE
Roper FEP210EN1 ELECTRIC RANGE
Roper FEP210EN2 ELECTRIC RANGE
Roper FEP210EN3 ELECTRIC RANGE
Roper FEP210EN4 ELECTRIC RANGE
Roper FEP210EN5 ELECTRIC RANGE
Roper FEP210EN6 ELECTRIC RANGE
Roper FEP210EQ2 ELECTRIC RANGE
Roper FEP210EQ3 ELECTRIC RANGE
Roper FEP210EQ4 ELECTRIC RANGE
Roper FEP210EQ5 ELECTRIC RANGE
Roper FEP210EW0 ELECTRIC RANGE
Roper FEP210EW1 ELECTRIC RANGE
Roper FEP210EW2 ELECTRIC RANGE
Roper FEP210EW3 ELECTRIC RANGE
Roper FEP210EW4 ELECTRIC RANGE
Roper FEP210EW5 ELECTRIC RANGE
  #2 (permalink)
Old 06-09-2012, 09:31 AM
Member.
letsride2384 is on a distinguished road
Default wow
First off never test anything plugged in ouch and second pull out the bake and broil elements and test they may be bad, and if good check your infinite timer switch.
  #3 (permalink)
Old 06-10-2012, 03:09 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Here is the wiring diagram
http://manuals.frigidaire.com/prodin.../316441422.pdf
As you can see the stove top elements and the oven elements are basically separated in the unit so it sounds like there is a problem with the power going to the unit.
The display/speed bake fan/timer all use 120 volts (half the line L1 to Neutral) but the elements require the full line L1 to L2) so it sounds like you are loosing L2 voltage.
Turn off the breaker and check for poor/loose connections at the terminal strip in the unit and the wall receptacle.
IF OK then check the line (power) cord to the unit for continuity. Wiggle the prongs and cord a bit while doing this in case the problem is intermittent which it sounds like it is.
If OK check the power connections in the breaker box.
If OK I would replace the wall receptacle as that is the most likely culprit.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchen Aid Electric Range, Oven Control Problem pza Oven Repair (including Ranges and Cooktops) 1 12-25-2011 08:01 PM
Frigidaire Electric Range - Oven just blew - Top works HELP Kris&Tara Oven Repair (including Ranges and Cooktops) 1 04-04-2011 05:04 AM
Frigidaire Range Oven Problem bgarrett6 Oven Repair (including Ranges and Cooktops) 1 01-26-2011 02:46 PM
Frigidaire electric smoothtop range - element problem digglife Oven Repair (including Ranges and Cooktops) 2 09-04-2009 03:24 PM
Electric Range oven and clock problem lancair90 Oven Repair (including Ranges and Cooktops) 0 03-18-2009 08:32 AM
