| » Maytag Wall Oven |
Model Number: CWG302 Brand: Maytag Age: Less than 1 year
Hello,
Would like to know if anybody has had this problem? I turn on the oven and the igniter comes on to an orange tint but the gas burners do not kick on. I have used a match to try and light the oven on by the igniter and still the burner does not kick on. I have a gas stove next to it and works fine and they run off of the same gas line. Could this be a regulator problem or something else completely? Any assistance is greatly appreciated. Ads By Google Related Models |
Hi.
The ignitor in order to open the gas has to "pull" 3.25Amp. If it's any less then that it wont work. The oven ignitor Part number: 12400035 Here are the breakdown diagrams and Replacement parts for Maytag CWG302 WALLOVEN- STD GAS | AppliancePartsPros.com Thank you. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Simon,
Thank you for the reply. I thought it might be the igniter but was not sure that there as an actual sensor / thermal couple (I assume) that was also attached to it to allow the gas to flow in. I will replace the igniter this weekend and will let you know the results. I'm hoping that is all it is as I would like to avoid purchasing a new over or hefty repair bill. Thanks again !!!! |
Hi.
There is no any sensors attached to the ignitor. The safety gas valve has a coil inside, rated to open the gas at 3.25amp. Simon.
__________________
| Display Modes | |
| maytag wall oven error code F5 | net2net69 | Oven Repair (including Ranges and Cooktops) | 1 | 05-03-2012 05:02 PM |
| maytag wall oven F3 code | eric-krupp | Oven Repair (including Ranges and Cooktops) | 0 | 05-13-2011 07:00 PM |
| Maytag wall oven | eric-krupp | Oven Repair (including Ranges and Cooktops) | 0 | 04-17-2011 11:31 AM |
| Maytag 30" Wall Oven | xklc01 | Oven Repair (including Ranges and Cooktops) | 0 | 09-12-2009 03:41 PM |
| Maytag Gas Wall Oven Will Not Heat | jpecobird1 | Oven Repair (including Ranges and Cooktops) | 1 | 07-01-2009 07:46 PM |
