Discuss
jenn-air w130 oven replace door hinge
 in
The door on my oven doesn't close tightly, and I thought perhaps the hinges could be the issue. I found
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » jenn-air w130 oven replace door hinge
  #1 (permalink)
Old 06-07-2012, 02:00 PM
Junior Member
leatherlips is on a distinguished road
Default jenn-air w130 oven replace door hinge
Model Number: w130   Brand: Jenn-Air   Age: More than 10 years
The door on my oven doesn't close tightly, and I thought perhaps the hinges could be the issue. I found the replacement part number, but I'm wondering if there is anywhere to find how to perform the replacment.
I've seen how some ovens are very easy to replace the hinge, as the hinge is part of the door, and when lifted off, it's easy to access. On this model, the hinge is part of the oven "frame" so I will have to remove pieces/parts of the oven, but I'm not sure which parts.
Any help would be appreciated!
Ads By Google
Related Models
Jenn-Air W130 Walloven - S/c Ele
Jenn-Air W130-C Walloven - S/c Ele
Jenn-Air W130W Walloven - S/c Ele
Jenn-Air W130W-C Walloven - S/c Ele
Jenn-Air W131B Walloven - S/c Ele
Jenn-Air W131B-C Walloven - S/c Ele
Jenn-Air W131W Walloven - S/c Ele
Jenn-Air W131W-C Walloven - S/c Ele
Jenn-Air W132B Walloven - S/c Ele
Jenn-Air W132W Walloven - S/c Ele
Jenn-Air W136 Walloven - S/c Ele
Jenn-Air W136-C Walloven - S/c Ele
Jenn-Air W136W Walloven - S/c Ele
Jenn-Air W136W-C Walloven - S/c Ele
Jenn-Air W140 Walloven - S/c Ele
Jenn-Air W141 Walloven - S/c Ele
Jenn-Air W141-C Walloven - S/c Ele
Jenn-Air W142 Walloven - S/c Ele
Jenn-Air W142-C Walloven - S/c Ele
Jenn-Air W146 Walloven - S/c Ele
Jenn-Air W146-C Walloven - S/c Ele
Magic Chef W14EA1 Washer - Top Loading
Magic Chef W14EN1 Washer - Top Loading
Magic Chef W14EY1 Washer - Top Loading
Magic Chef W14HA1 Washer - Top Loading
Magic Chef W14HN1 Washer - Top Loading
Magic Chef W14HY1 Washer - Top Loading
Magic Chef W14JA1 Washer - Top Loading
Magic Chef W14JN1 Washer - Top Loading
Magic Chef W14JY1 Washer - Top Loading
Jenn-Air W156 Walloven - S/c Ele
Jenn-Air W156-C Walloven - S/c Ele
Jenn-Air W156B Walloven - S/c Ele
Jenn-Air W156B-C Walloven - S/c Ele
Jenn-Air W156W Walloven - S/c Ele
Jenn-Air W156W-C Walloven - S/c Ele
Jenn-Air W181 Walloven - S/c Ele
Jenn-Air W188 Walloven - S/c Ele
Jenn-Air W188-C Walloven - S/c Ele
Jenn-Air W188W Walloven - S/c Ele
Jenn-Air W188W-C Walloven - S/c Ele
Amana W18C3HES Room Air Conditioner
Magic Chef W18DA2 Washer - Top Loading
Magic Chef W18DN2 Washer - Top Loading
Magic Chef W18DY2 Washer - Top Loading
Magic Chef W18EA1 Washer - Top Loading
Magic Chef W18EA2 Washer - Top Loading
Magic Chef W18EN1 Washer - Top Loading
Magic Chef W18EN2 Washer - Top Loading
Magic Chef W18EY1 Washer - Top Loading
Magic Chef W18EY2 Washer - Top Loading
Magic Chef W18FA1 Washer - Top Loading
Magic Chef W18FA1C Washer - Top Loading
Magic Chef W18FA2 Washer - Top Loading
Magic Chef W18FN1 Washer - Top Loading
Magic Chef W18FN1C Washer - Top Loading
Magic Chef W18FN2 Washer - Top Loading
Magic Chef W18FY1 Washer - Top Loading
Magic Chef W18FY1C Washer - Top Loading
Magic Chef W18FY2 Washer - Top Loading
Magic Chef W18GA1 Washer - Top Loading
Magic Chef W18GN1 Washer - Top Loading
Magic Chef W18GY1 Washer - Top Loading
Magic Chef W18HA1 Washer - Top Loading
Magic Chef W18HN1 Washer - Top Loading
Magic Chef W18HY1 Washer - Top Loading
Magic Chef W18JA1 Washer - Top Loading
Magic Chef W18JN1 Washer - Top Loading
Magic Chef W18JY1 Washer - Top Loading
Jenn-Air W198 Walloven - S/c Ele
Jenn-Air W198-C Walloven - S/c Ele
Jenn-Air W198W Walloven - S/c Ele
Jenn-Air W198W-C Walloven - S/c Ele
Jenn-Air W200 Walloven - S/c Mwave Ele
Jenn-Air W204 Walloven - S/c Mwave Ele
Magic Chef W204KA Washer - Top Loading
Magic Chef W204KV Washer - Top Loading
Magic Chef W204KW Washer - Top Loading
Jenn-Air W205 Walloven - S/c Mwave Ele
Magic Chef W205KA Washer - Top Loading
Magic Chef W205KAC Washer - Top Loading
Magic Chef W205KGA Washer - Top Loading
Magic Chef W205KGV Washer - Top Loading
Magic Chef W205KGW Washer - Top Loading
Magic Chef W205KV Washer - Top Loading
Magic Chef W205KW Washer - Top Loading
Magic Chef W205KWC Washer - Top Loading
Jenn-Air W206B Walloven - S/c Ele
Jenn-Air W206B-C Walloven - S/c Ele
Magic Chef W206KA Washer - Top Loading
Magic Chef W206KV Washer - Top Loading
Magic Chef W206KW Washer - Top Loading
Jenn-Air W206W Walloven - S/c Ele
Jenn-Air W206W-C Walloven - S/c Ele
Magic Chef W207KA Washer - Top Loading
Magic Chef W207KAC Washer - Top Loading
Magic Chef W207KKW Washer - Top Loading
Magic Chef W207KV Washer - Top Loading
Magic Chef W207KW Washer - Top Loading
Magic Chef W207KWC Washer - Top Loading
Magic Chef W208KA Washer - Top Loading
Magic Chef W208KV Washer - Top Loading
Magic Chef W208KW Washer - Top Loading
Magic Chef W209KA Washer - Top Loading
Magic Chef W209KAC Washer - Top Loading
Magic Chef W209KV Washer - Top Loading
Magic Chef W209KVC Washer - Top Loading
Magic Chef W209KWA Washer - Top Loading
Magic Chef W20DA3 Washer - Top Loading
Magic Chef W20DA4 Washer - Top Loading
Magic Chef W20DN3 Washer - Top Loading
Magic Chef W20DN4 Washer - Top Loading
Magic Chef W20DY3 Washer - Top Loading
Magic Chef W20DY4 Washer - Top Loading
Magic Chef W20EA2 Washer - Top Loading
Magic Chef W20EA3 Washer - Top Loading
Magic Chef W20EA4 Washer - Top Loading
Magic Chef W20EN2 Washer - Top Loading
Magic Chef W20EN3 Washer - Top Loading
Magic Chef W20EN4 Washer - Top Loading
  #2 (permalink)
Old 06-09-2012, 09:41 AM
Member.
letsride2384 is on a distinguished road
Default wow
Check to see if clips on hindge pop out and door will pull off and check to see if it has springs attatched,
  #3 (permalink)
Old 06-09-2012, 10:20 AM
Junior Member
Default
Thank you for the reply.
The once I remove the door, the hinge remains attached to the oven (not the door). The springs are not visible (they are inside the oven "frame" somewhere).
I tried finding a service manual that might give a better idea on dis-assembly, but have been unsuccessful.
  #4 (permalink)
Old 06-09-2012, 01:01 PM
Member.
letsride2389 is on a distinguished road
Default ok
Pull out the bottom drawer if you have one and look underneath on the sides to locate the springs.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn-Air Oven Door Hinge audiomidiman Oven Repair (including Ranges and Cooktops) 0 05-05-2011 05:14 AM
replace oven door hinge!! tbandme Oven Repair (including Ranges and Cooktops) 15 11-28-2010 10:07 PM
replace oven door hinge brcmarzette Oven Repair (including Ranges and Cooktops) 0 11-22-2010 09:50 AM
Jenn-Air w130 Door Assembly??? mholt Oven Repair (including Ranges and Cooktops) 0 12-06-2009 09:07 AM
Jenn Air oven door hinge replacement robclark Oven Repair (including Ranges and Cooktops) 0 09-03-2009 10:12 AM
