Discuss
Weak Spark on Thermador Cooktop
 in
Our cooktop has some igniters that produce an intermittent spark and a couple that don't spark at all (without help).
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Weak Spark on Thermador Cooktop
  #1 (permalink)
Old 06-05-2012, 12:53 PM
Junior Member
cwilliamrose is on a distinguished road
Default Weak Spark on Thermador Cooktop
Model Number: SGCS456RS   Brand: Thermador   Age: More than 10 years
I had the unit apart to clean it, fix a spark switch that wasn't staying engaged with the valve and getting out of index (continuous sparking), etc. The o-rings were shot, the pads were dirty and there was corrosion between the pads and the lid. All that is now resolved and I believe the grounds are all good now. None of this has resolved the spark issues.
All the igniters will spark if I hold a screwdriver close while touching the pad or the lid (makes no difference) but some of the sparks are weak even with that help. The center burners seem to have the strongest spark. The spark wires look good as do the igniter "plugs". The spark is triggered equally well with any of the six burner controls so I think the switches are OK. I believe this has been an issue for some time.
I could swap some of the igniter plugs around and see if the problem follows them. Or I could get a spark controller if that's the likely cause. Or I could get new wires if I had a part number (I haven't found that number yet) and they're still available.
What's the most likely culprit here?
Thanks..........
Related Models
Thermador SGCS456RS STEEL GAS COOKTOPS WITH FULL SERVICE GRATES
Thermador SGCS456RS SN 9803
Thermador SGCS456RW STEEL GAS COOKTOPS WITH FULL SERVICE GRATES
Thermador SGCS456RW SN 9803
Thermador SGCV36 COOKTOP
Thermador SGCV3601 COOKTOP
Thermador SGCV36G01 COOKTOP
Thermador SGCV36G02 COOKTOP
Amana SGD22TL REF - SXS/I&W
Amana SGD22TW REF - SXS/I&W
Amana SGD26VL REF - SXS/I&W
Amana SGD26VW REF - SXS/I&W
Amana SGD521SBL REF - SXS/I&W
Amana SGD521SBW REF - SXS/I&W
Amana SGD521SW REF - SXS/I&W
Whirlpool SGDS800HQ0 GAS DRYER
Whirlpool SGDS800JQ0 GAS DRYER
Whirlpool SGDS800JQ1 GAS DRYER
Whirlpool SGDS800JQ2 GAS DRYER
Whirlpool SGDS800MQ0 29"GAS DRYER
Whirlpool SGDS800MQ1 29"GAS DRYER
Whirlpool SGDX600HQ0 DRYER
Whirlpool SGDX600JQ0 DRYER
Whirlpool SGDX600JQ1 DRYER
Whirlpool SGDX600JQ2 DRYER
Whirlpool SGDX600MQ0 29"GAS DRYER
Whirlpool SGDX600MQ1 29"GAS DRYER
Frigidaire SGER341AS0 Frigidaire/dryer
Frigidaire SGER341AS1 Frigidaire/electric Dryer
Frigidaire SGGR341AS0 Frigidaire/dryer
Frigidaire SGGR341AS1 Frigidaire/gas Dryer
Frigidaire SGGR341AS2 Frigidaire/gas Dryer
 SGM365 COOKTOP
Thermador SGN30B GAS COOKTOP
Thermador SGN30S GAS COOKTOP
Thermador SGN30W GAS COOKTOP
Thermador SGN36GB GAS COOKTOP
Thermador SGN36GS GAS COOKTOP
Thermador SGN36GW GAS COOKTOP
Thermador SGNCV36GB GAS COOKTOP
Thermador SGNCV36GS GAS COOKTOP
Thermador SGNCV36GW GAS COOKTOP
Roper SGP335XW0 Range (gas)*
Roper SGP335XW1 Range (gas)*
Roper SGP335XX2 Range (gas)*
White Westinghouse SGQ2152HS0 DRYER
White Westinghouse SGQ2152HS1 DRYER
White Westinghouse SGQ2170KS0 DRYER
 SGQ7000FS0 ELECTROLUX/DRYER
White Westinghouse SGR231CQ0 White Westinghouse/dryer
White Westinghouse SGR231CS0 White Westinghouse/dryer
White Westinghouse SGR231HQ0 DRYER
White Westinghouse SGR231HQ1 DRYER
White Westinghouse SGR231HS0 DRYER
White Westinghouse SGR231HS1 DRYER
White Westinghouse SGR341AQ0 Dryer - W.west
White Westinghouse SGR341AQ1 Dryer - West/grupo Gomo
White Westinghouse SGR341AQ2 White Westinghouse/gas Dryer
White Westinghouse SGR341AQ3 White Westinghouse/gas Dryer
White Westinghouse SGR341AQ4 White Westinghouse/gas Dryer
White Westinghouse SGR341AQ5 White Westinghouse/dryer
White Westinghouse SGR341AS0 Dryer - W.west
White Westinghouse SGR341AS1 Dryer - West/grupo Gomo
White Westinghouse SGR341AS2 White Westinghouse/gas Dryer
White Westinghouse SGR341AS3 White Westinghouse/gas Dryer
White Westinghouse SGR341AS4 White Westinghouse/gas Dryer
White Westinghouse SGR341AS5 White Westinghouse/dryer
White Westinghouse SGR341CC0 White Westinghouse/dryer
White Westinghouse SGR341FC0 White Westinghouse/dryer
White Westinghouse SGR351CQ0 White Westinghouse/dryer
White Westinghouse SGR351CS0 White Westinghouse/dryer
White Westinghouse SGR351FQ0 White Westinghouse/dryer
White Westinghouse SGR351FS0 White Westinghouse/dryer
White Westinghouse SGR351HQ0 DRYER
White Westinghouse SGR351HQ1 DRYER
White Westinghouse SGR351HS0 DRYER
White Westinghouse SGR351HS1 DRYER
White Westinghouse SGR641HQ0 DRYER
White Westinghouse SGR641HQ1 DRYER
White Westinghouse SGR641HS0 DRYER
White Westinghouse SGR641HS1 DRYER
Thermador SGS/X304ZB
Thermador SGS/X304ZS
Thermador SGS/X304ZW
Thermador SGS/X365ZB
Thermador SGS/X365ZS
Thermador SGS/X365ZW
Thermador SGS304ZB
Thermador SGS304ZS
Thermador SGS304ZW
Thermador SGS30B GAS COOKTOP
Thermador SGS30S GAS COOKTOP
Thermador SGS30W GAS COOKTOP
Thermador SGS365ZB
Thermador SGS365ZS
Thermador SGS365ZW
Thermador SGS36GB GAS COOKTOP
Thermador SGS36GS GAS COOKTOP
Thermador SGS36GW GAS COOKTOP
Whirlpool SGS375HQ0 30" GAS FREESTANDING, SELF-CLEAN RANGE
Whirlpool SGS375HQ5 GAS RANGE
Whirlpool SGS375HQ6 GAS RANGE
Whirlpool SGS375HQ7 COOKING PRODUCT - GAS
Roper SGS395XX0 Range (gas)*
Whirlpool SGS395XX1
Whirlpool SGS395XX2
Thermador SGS456ZS
Thermador SGSCV36GB GAS COOKTOP
Thermador SGSCV36GS GAS COOKTOP
Thermador SGSCV36GW GAS COOKTOP
Thermador SGSX304ZB
Thermador SGSX304ZS
Thermador SGSX304ZW
Thermador SGSX365ZB
Thermador SGSX365ZS
Thermador SGSX365ZW
  #2 (permalink)
Old 06-07-2012, 11:52 AM
Junior Member
Default
I found that the caps are important to the igniter performance as they sit closer to the igniter than do the pads. With the caps in place all the burners spark consistently and light well now. The original problem was most likely poor grounds.
Thanks.....
  #3 (permalink)
Old 06-07-2012, 02:02 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
That is precisely the most common reason for weak sparks - bad ground. So many spark modules were replaced for no reason and all because miss diagnostic.
Congratulations on this success.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #4 (permalink)
Old 06-07-2012, 02:41 PM
Junior Member
Default
Thanks,
I think the problem started with the o-rings failing. Four were completely missing, the other two were hard and crumbled easily with some sections missing. Because the die cast pads are in direct contact with the stainless top there is a galvanic condition ready for a little moisture. That moisture was supplied during the cleaning of the top, spills, etc. There was visible light-colored powder between the two parts on several of the burners. I bead blasted the bottoms of the pads and scraped the area around the venturi tube holes to bright metal on both sides and the top was completely polished to remove minor scratches, discoloration, etc. As long as it stays dry under the pads the corrosion shouldn't be a big problem.
  #5 (permalink)
Old 06-07-2012, 02:55 PM
Expert
Default
The work you've done should be a perfect sample of solving this problem.
Thank you for shearing the information.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Spark on Igniter for top burner Spark is WEAK or sometimes NO spark!! mobfather Oven Repair (including Ranges and Cooktops) 0 02-11-2011 10:10 AM
Gas cooktop 2 weak igniters 3 good ones selinken Oven Repair (including Ranges and Cooktops) 0 03-09-2010 05:31 PM
Thermador no burner spark jjeaton2 Oven Repair (including Ranges and Cooktops) 1 04-22-2009 01:15 PM
no spark thermador cooktop abrooks Oven Repair (including Ranges and Cooktops) 0 12-03-2008 12:11 PM
weak spark on left side igniters art Oven Repair (including Ranges and Cooktops) 0 11-08-2007 05:51 AM
