| » oven does not reach proper temperature |
Model Number: 3968vvv Brand: Magic Chef Age: More than 10 years
oven temperature does not reach correct temperature when set on the digital temperature read out on control panel. information seems to indicate the temperature sensor may be the problem. what are the steps needed to take to determine the problem and what replacement is necessary? thanks in advance
Hi.
You need to check the oven temperature sensor resistance. Set your multimeter to the highest setting and check the sensor. Normal reading at room temperature should be 1 - 1.1 Kohm. If the sensor OK - then most likely it's the control board. The sensor Part number: 12001656 Here are the breakdown diagrams and Replacement parts for Magic Chef 3968VVV RANGE-S/C F/S T/SVR/BOOSTER EL | AppliancePartsPros.com Thank you. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
A lot depends on how "does not reach correct temperature " is interpreted.
If you put an oven thermometer in the oven and when the oven comes ready (preheat off) the actual oven temperature is low then the sensor is the most likely cause as Simon said. If the unit stays in preheat and never comes ready then it could be that one of the elements is not coming on. Most units switch back and forth between the elements in preheat and bake. This could be a blown element or the control board.
__________________
| Display Modes | |
| Oven doesnt' reach temperature | cmarkleski | Oven Repair (including Ranges and Cooktops) | 3 | 10-20-2010 11:17 AM |
| Oven won't reach temperature | tcfroman | Oven Repair (including Ranges and Cooktops) | 0 | 10-10-2010 09:11 AM |
| Oven does not reach set temperature | dcmjcook | Oven Repair (including Ranges and Cooktops) | 0 | 03-07-2010 05:23 AM |
| Oven Lights but doesn't reach proper Temp | blottom | Oven Repair (including Ranges and Cooktops) | 0 | 10-20-2009 05:53 AM |
| Oven won't reach temperature | bbatt | Oven Repair (including Ranges and Cooktops) | 0 | 12-05-2008 12:20 PM |
