| » Igniter repair |
Model Number: JGSP44BEY2BB Brand: GE Age: 5 - 10 years
Hi. I've Read Some Of The Posts On Similar Questions And Your Answers Seemed To Be Very Helpful. Perhaps You Can Help With Our Ge Profile Model Jgsp44bey2bb.
After Our Stove Top Was Cleaned, Probably With Water And Some Detergent Like Soft Scrub, The Right Front Burner Won't Click Or Ignite. This Burner Can Be Lit Manually With A Match. All The Other Three Burners Click And Ignite. 1) Do You Think Just Replacing The Electrode Could Solve This? 2) Would Replacing It With One Of The Working Electrodes Be A Way To Check? If Yes, What Would Be The Steps To Take? 3) If No, What Do You Recommend And What Would Be The Exact Steps To Take? A Diagram And Any Video Would Be Appreciated. Thanks So Much For Your Help. Peter Ads By Google Related Models |
Hi Peter,
I would suspect the ignition switch for this burner rather than the igniter because it's sitting on the gas valve shaft and can be easy damaged (shorted) with any liquid. One more reason why I do think so is because it does not click when you turn it on. - The ignition switch Part number: WB24T10071 Here are the breakdown diagrams and Surface burner replacement parts for General Electric JGSP44BEY2BB Gas range | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Unfortunately I don't have such video.
__________________
| Display Modes | |
| Bosch oven igniter repair | soonerhokie | Oven Repair (including Ranges and Cooktops) | 1 | 09-04-2011 05:39 PM |
| Just replaced failed igniter switch on Stove, now igniter on before gas flowing | Isotonic | Oven Repair (including Ranges and Cooktops) | 0 | 03-19-2011 11:14 AM |
| Gas dryer with new fuse, thermostat & igniter. Igniter did NOT glow & no heat | yzhong | Dryer Repair | 1 | 08-10-2009 04:03 PM |
| Removing dryer cabinet to repair igniter | Mikeofba | Dryer Repair | 1 | 07-27-2007 10:48 PM |
