Discuss
electric oven over heats
 in
When I set the oven temp to 350 or any temp for that matter, it over heats and burns up
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » electric oven over heats
  #1 (permalink)
Old 06-04-2012, 11:31 AM
Junior Member
Fleet10 is on a distinguished road
Default electric oven over heats
Model Number: CW6830ACB   Brand: Maytag   Age: More than 10 years
When I set the oven temp to 350 or any temp for that matter, it over heats and burns up the food. Could it be the thermostat?
Ads By Google
Related Models
Crosley CW7000A Washer - Top Loading
Crosley CW7000Q Washer - Top Loading
Crosley CW7000W Washer - Top Loading
Crosley CW7500Q Washer - Top Loading
Crosley CW7500W Washer - Top Loading
Amana CW76T Mwave - Cntrtp / Stand Alone
Crosley CW8000A Washer - Top Loading
Crosley CW8000W Washer - Top Loading
Amana CW8202W2 Washer - Top Loading
Amana CW8203W Washer - Top Loading
Amana CW8203W2 Washer - Top Loading
Amana CW8403W Washer - Top Loading
Amana CW8413W2 Washer - Top Loading
Crosley CW8500W Washer - Top Loading
Amana CW9003 Washer - Top Loading
Amana CW9003W Washer - Top Loading
Amana CW9203W Washer - Top Loading
Amana CW9203W2 Washer - Top Loading
Amana CW9203W3 Washer - Top Loading
Crosley CW9500W Washer - Top Loading
Crosley CW9505W Washer - Top Loading
Whirlpool CWA1700W0
Whirlpool CWA1700W1
Whirlpool CWA1700W2
Whirlpool CWA2000W0
Whirlpool CWA2000W1
Whirlpool CWA2000W2
Whirlpool CWA2004W0
Whirlpool CWA2004W1
Whirlpool CWA2004W2
Whirlpool CWA2500W0
Whirlpool CWA2500W1
Whirlpool CWA2500W2
Whirlpool CWA3500W0
Whirlpool CWA3500W1
Whirlpool CWA3500W2
Maytag CWE1000 Walloven - S/c Ele
Whirlpool CWE1700W0
Whirlpool CWE1700W1
Whirlpool CWE2100W0
Whirlpool CWE2100W1
Maytag CWE400 Walloven - Std Ele
Maytag CWE401 Walloven - Std Ele
Maytag CWE402 Walloven - Std Ele
Maytag CWE4020ACB Walloven - Std Ele
Maytag CWE4020BCB Walloven - Std Ele
Maytag CWE4200ACB Walloven - Std Ele
Maytag CWE450 Walloven - Std Ele
Maytag CWE451 Walloven - Std Ele
Maytag CWE470 Walloven - S/c Ele
Maytag CWE4700ACB Walloven - S/c Ele
Maytag CWE4700ACE Walloven - S/c Ele
Maytag CWE4700BCB Walloven - S/c Ele
Maytag CWE4700BCE Walloven - S/c Ele
Maytag CWE4800ACB Walloven - S/c Ele
Maytag CWE4800ACE Walloven - S/c Ele
Maytag CWE4800ACS Walloven - S/c Ele
Maytag CWE500 Walloven - Std Ele
Maytag CWE501 Walloven - Std Ele
Maytag CWE502 Walloven - Std Ele
Maytag CWE5020ACB Walloven - Std Ele
Maytag CWE5020BCB Walloven - Std Ele
Maytag CWE5200ACB Walloven - S/c Ele
Maytag CWE5200ACE Walloven - S/c Ele
Maytag CWE550 Walloven - S/c Ele
Maytag CWE5500ACB Walloven - S/c Ele
Maytag CWE5500ACE Walloven - S/c Ele
Maytag CWE5500BCB Walloven - S/c Ele
Maytag CWE5500BCE Walloven - S/c Ele
Maytag CWE5800ACB Walloven - S/c Ele
Maytag CWE5800ACE Walloven - S/c Ele
Maytag CWE5800ACS Walloven - S/c Ele
Maytag CWE600 Walloven - S/c Ele
Maytag CWE601 Walloven - S/c Ele
Maytag CWE602 Walloven - S/c Ele
Maytag CWE6020ACB Walloven - S/c Ele
Maytag CWE6200ACB Walloven - S/c Ele
Maytag CWE6200ACE Walloven - S/c Ele
Maytag CWE6200ADB Walloven - S/c Ele
Maytag CWE6200ADE Walloven - S/c Ele
Maytag CWE6230ACB Walloven - S/c Ele
Maytag CWE6230ACE Walloven - S/c Ele
Maytag CWE6230ADB Walloven - S/c Ele
Maytag CWE6230ADE Walloven - S/c Ele
Maytag CWE6800ACB Walloven - S/c Ele
Maytag CWE6800ACE Walloven - S/c Ele
Maytag CWE6830ACB Walloven - S/c Ele
Maytag CWE6830ACE Walloven - S/c Ele
Maytag CWE700 Walloven - S/c Ele
Maytag CWE7000ACB Walloven - S/c Ele
Maytag CWE7000ACE Walloven - S/c Ele
Maytag CWE701 Walloven - S/c Ele
Maytag CWE7800ACB Walloven - S/c Ele
Maytag CWE7800ACE Walloven - S/c Ele
Maytag CWE7830ACB Walloven - S/c Ele
Maytag CWE7830ACE Walloven - S/c Ele
Maytag CWE900 Walloven - S/c Ele
Maytag CWE9000ACB Walloven - S/c Ele
Maytag CWE9000ACE Walloven - S/c Ele
Maytag CWE9000BCB Walloven - S/c Ele
Maytag CWE9000BCE Walloven - S/c Ele
Maytag CWE9000BCM Walloven - S/c Ele
Maytag CWE9000BDB Walloven - S/c Ele
Maytag CWE9000BDE Walloven - S/c Ele
  #2 (permalink)
Old 06-04-2012, 12:30 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
The model number you posted is not correct.Please, check it again.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 06-04-2012, 02:03 PM
Junior Member
Default My Maytag wall oven model number CWE6830ACB is overheating.
I generally set the oven to 350 degrees. It is over heating and burning food. Any thoughts?
Thanks.
  #4 (permalink)
Old 06-04-2012, 02:04 PM
Junior Member
I generally set the oven to 350 degrees. It is over heating and burning food. Any thoughts? The model number is CWE6830ACB
Thanks.
  #5 (permalink)
Old 06-04-2012, 02:51 PM
Expert
Default
Hi.
The oven temperature is controlled by the sensor and control board.
Check the sensor's resistance. At room temperature the resistance should be 1 - 1.1 kohm.
If it's different - replace the sensor Part number: 12001656
It's better be the sensor - the control board is no longer available.
Here are the breakdown diagrams and Replacement parts for Maytag CWE6830ACB WALLOVEN- S/C ELE | AppliancePartsPros.com
Thank you.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Electric dryer heats, then shuts off larryRudolf Dryer Repair 1 12-06-2011 08:30 PM
Kenmore Electric Cooktop heats very slowly Richie1111 Oven Repair (including Ranges and Cooktops) 1 12-02-2011 07:44 AM
whirlpool electric dryer heats but not really hot brandi1109 Dryer Repair 1 01-06-2011 02:53 AM
Electric Stove Lights Work But Nothing Heats harriscz Oven Repair (including Ranges and Cooktops) 0 12-30-2009 11:59 AM
Cook top electric burner over heats kdice2 Oven Repair (including Ranges and Cooktops) 3 08-21-2009 05:06 PM
