Discuss
Whirlpool elec oven not heating
 in
Our oven has suddenly stopped heating as it should. It's an ancient (came w/home built in 89) Whirlpool that wont
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool elec oven not heating
  #1 (permalink)
Old 06-03-2012, 04:08 PM
Junior Member
rap77 is on a distinguished road
Unhappy Whirlpool elec oven not heating
Model Number: RS6300XKW   Brand: Whirlpool   Age: More than 10 years
Our oven has suddenly stopped heating as it should. It's an ancient (came w/home built in 89) Whirlpool that wont get above about 150 degrees.
Can't afford new oven. How can I repair this one?
Thanks!
Ads By Google
Related Models
Whirlpool RS6300XKW0
Whirlpool RS6300XKW1
Whirlpool RS6300XKW2
Whirlpool RS6300XKW3
Whirlpool RS6300XVN0
Whirlpool RS6300XVN1
Whirlpool RS6300XVN2
Whirlpool RS6300XVW0
Whirlpool RS6300XVW1
Whirlpool RS6300XVW2
Whirlpool RS6305XYN2
Whirlpool RS6305XYN3
Whirlpool RS6305XYN4
Whirlpool RS6305XYN5
Whirlpool RS6305XYN6
Whirlpool RS6305XYW0
Whirlpool RS6305XYW1
Whirlpool RS6305XYW2
Whirlpool RS6305XYW3
Whirlpool RS6305XYW4
Whirlpool RS6305XYW5
Whirlpool RS6305XYW6
Whirlpool RS630PXBH0
Whirlpool RS630PXBH1
Whirlpool RS630PXK0
Whirlpool RS630PXK1
Whirlpool RS630PXK2
Whirlpool RS630PXK3
Whirlpool RS630PXV0
Whirlpool RS630PXV1
Whirlpool RS630PXV2
Whirlpool RS630PXYH0
Whirlpool RS630PXYH1
Whirlpool RS630PXYH2
Whirlpool RS630PXYH3
Whirlpool RS630PXYH4
General Electric RS647G*05 Electric range
General Electric RS647G*H1 Electric range
General Electric RS647G*J1 Electric range
General Electric RS647G*J2 Electric range
General Electric RS647G*J3 Electric range
General Electric RS647G*J4 Electric range
General Electric RS647G*J5 Electric range
General Electric RS647G*J6 Electric range
General Electric RS647G*J8 Electric range
Whirlpool RS660BXBH0
Whirlpool RS660BXBH1
Whirlpool RS660BXBH2
Whirlpool RS660BXK0
Whirlpool RS660BXK1
Whirlpool RS660BXK2
Whirlpool RS660BXK3
Whirlpool RS660BXK4
Whirlpool RS660BXV0
Whirlpool RS660BXV1
Whirlpool RS660BXV2
Whirlpool RS660BXYH0
Whirlpool RS660BXYH1
Whirlpool RS660BXYH2
Whirlpool RS660BXYH3
Whirlpool RS6700XKW0
Whirlpool RS6700XKW1
Whirlpool RS6700XKW2
Whirlpool RS6700XKW3
Whirlpool RS6700XKW4
Whirlpool RS6700XVN0
Whirlpool RS6700XVW0
Whirlpool RS670PXK0
Whirlpool RS670PXK1
Whirlpool RS670PXK2
Whirlpool RS670PXK3
Whirlpool RS670PXK4
Whirlpool RS670PXV0
Whirlpool RS6750XV1
Whirlpool RS6750XVN0
Whirlpool RS6750XVN1
Whirlpool RS6750XVN2
Whirlpool RS6750XVW0
Whirlpool RS6750XVW1
Whirlpool RS6750XVW2
Whirlpool RS6755XYN0
Whirlpool RS6755XYN1
Whirlpool RS6755XYN2
Whirlpool RS6755XYN5
Whirlpool RS6755XYN6
Whirlpool RS6755XYN7
Whirlpool RS6755XYW0
Whirlpool RS6755XYW1
Whirlpool RS6755XYW2
Whirlpool RS6755XYW5
Whirlpool RS6755XYW6
Whirlpool RS6755XYW7
Whirlpool RS675PXBH0
Whirlpool RS675PXBH1
Whirlpool RS675PXBH2
Whirlpool RS675PXBQ0
Whirlpool RS675PXBQ1
Whirlpool RS675PXBQ2
Whirlpool RS675PXEB0
Whirlpool RS675PXEB2
Whirlpool RS675PXEQ0
Whirlpool RS675PXEQ2
Whirlpool RS675PXEZ0
Whirlpool RS675PXEZ2
Whirlpool RS675PXGB0
Whirlpool RS675PXGB10
Whirlpool RS675PXGB12 30" Drop - in Electric Oven Self Clean
Whirlpool RS675PXGB14 30" Drop - in Electric Oven Self Clean
Whirlpool RS675PXGB15 30" Drop - in Electric Oven Self Clean
Whirlpool RS675PXGB4
Whirlpool RS675PXGB5
Whirlpool RS675PXGB6
Whirlpool RS675PXGB7
Whirlpool RS675PXGB8
Whirlpool RS675PXGB9
Whirlpool RS675PXGQ0
Whirlpool RS675PXGQ10
Whirlpool RS675PXGQ12 30" Drop - in Electric Oven Self Clean
Whirlpool RS675PXGQ14 30" Drop - in Electric Oven Self Clean
Whirlpool RS675PXGQ15 30" Drop - in Electric Oven Self Clean
  #2 (permalink)
Old 06-04-2012, 08:18 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Pull the range out of the wall. Remove the rear panel and check the wires connected to the Bake and Broil heating elements. Post the results.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 06-06-2012, 06:12 PM
Junior Member
Default back of my electric range
Okay, I pulled out my range, an insert btw, and removed the rear cover. I saw nothing out of order. Here is a picture from the cell phone. It warms up, just not enough to bake/broil anything in it. What next? Thanks for the help!
  #4 (permalink)
Old 06-06-2012, 06:49 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Disconnect the wires from the Bake heating element. Check for 120 VAC between each wire and the ground while the selector switch set for Bake and the thermostat set on 350°F. Check for 240 VAC between these wires with the same controls setting.
Post the results.
__________________
  #5 (permalink)
Old 06-07-2012, 05:31 PM
Junior Member
Default
Looking at the picture I posted, left blue wire has 121.8 volts, right blue wire has 01.1 volts and together they have 122.9 volts. I'd say something is wrong based on what you said I should have found.
  #6 (permalink)
Old 06-08-2012, 05:53 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm afraid you did check the wrong wires. The Bake element is the bottom one and per your picture the wires connected to it are red.
__________________
  #7 (permalink)
Old 06-12-2012, 02:25 PM
Junior Member
Default red wire check
Okay, finally got back to the oven.
Red wires check as follows.
Left = 122.6 (+/-)
Right = 120.1 (+/-)
Both = 243.5 (+/-)
This seems to be in tolerance for the bake element (bottom).
The top element had one with hardly any voltage at all.
Thanks for your help. My wife is ill w/me because I've drug this out so long.
  #8 (permalink)
Old 06-12-2012, 04:32 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Sounds like the Bake (bottom) heating element itself is the culprit.
- The Bake element Part number: 308180
Part number: 308180
P.S. To get (and check) voltage to the top element (Broil) you have to turn the selector switch on Broil.
__________________
  #9 (permalink)
Old 06-12-2012, 07:39 PM
Junior Member
Default
Gene, I'm trusting you on that, seeing that my training on this was in high school, in 1976 & 77. But it doesn't make since to me. Does the voltage to each side of the element have to be exactly 120 and the total exactly 240? I figured "in the ballpark" was a good thing.
Thank you again for your assistance!
  #10 (permalink)
Old 06-13-2012, 05:16 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The voltage is never the same. It's fluctuating depends on many different things. If the voltage is within 5% range, it's considered normal.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool elec oven overheats then locks jeanking Oven Repair (including Ranges and Cooktops) 1 05-23-2011 01:17 PM
whirlpool dble oven cntrl-elec LWOOD Oven Repair (including Ranges and Cooktops) 0 05-21-2011 02:43 PM
Frigidaire Elec Oven Elements not Heating shagen Oven Repair (including Ranges and Cooktops) 2 04-06-2010 11:41 AM
whirlpool elec. oven control panel j4ester Oven Repair (including Ranges and Cooktops) 1 11-24-2009 04:04 AM
whirlpool gold elec., dryer not heating. bowman Dryer Repair 0 02-22-2009 09:43 AM
